Any one with a wood stove?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-18-2009, 08:23 PM   #1 (permalink)
Member # 76297
We have a Brass Flame KS-805, we have no owners manual. we are wondering how to work this thing, without burning down our house.
traci6878 is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 08:26 PM   #2 (permalink)
PRegner's Avatar
Member # 50212
Make sure you put the fuel inside the stove before igniting it...
"Sic gorgiamus allos subjectatos nunc"
"Islam in a man is more dangerous than rabies in a dog"
PRegner is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 08:26 PM   #3 (permalink)
trampas's Avatar
Member # 5433
Place smaller pieces of wooden material inside and then ignite.
Add larger pieces as flames grow.
What are we supposed to do with nature, just stare at it? Is it like porn with leaves?
:Philipoff2:
trampas is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 08:27 PM   #4 (permalink)
Member # 16282
First off you need something non-combustible beneath it and behind it...
Is that single wall pipe? If so, how is it run through the ceiling?
mgmorrison is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 08:30 PM   #5 (permalink)
Member # 848
First things first...get the chimney cleaned and inspected. Burn dry wood.
SNOWTREK.org
Nobody is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 08:30 PM   #6 (permalink)
Banned
4Mogger's Avatar
Member # 33748
run a correctly sized chimney brush down the stovepipe first. Get a magnetic thermometer to keep on the pipe so that you can see if you are getting it too hot. Looks like single wall pipe to me, old school style. I heat 100% with wood in my house, the main house has three wood stoves so we go through a lot of wood. But it is worth it to me, the atmosphere and we do about half of the cooking on it as well.
4Mogger is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 08:31 PM   #7 (permalink)
Member # 76297
UHHHH I dunno if that is a single wall pipe it goes up to the ceiling then there is a big black box and it comes out thru the roof.
Its on concrete blocks, the stove is definatly not new to the house. It has been here a while.
We have a fire going in it now, but when we close the door the fire goes out.
Old 10-18-2009, 08:32 PM   #8 (permalink)
trampas's Avatar
Member # 5433
open the............................................... ........................................
FLUE
:Philipoff2:
Old 10-18-2009, 08:32 PM   #9 (permalink)
Member # 29177
Open the vent on front of the door
Blind Driver is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 08:33 PM   #10 (permalink)
Member # 69243
There should be a "draft" on the stove somewhere to let air in
operose is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 08:44 PM   #11 (permalink)
Member # 2347
look's like single wall till the top and then it step's to triple wall ?
I would slide a piece of sheet metal under it to act as a fire barrier then build a brick/stone pad for it to sit on. The air gap behind it look's to be 6+ inch's but you should have some sort of fire barrier there as well.
First and fore most go get a temperature gauge for the pipe ! Home depot, Lowe's Tractor supply all sell them. I usually buy 2 each year and put them in 2 separate spot's. one WILL eventually go bad if you get it hot enough, wich we've all done.
If it's going out, look for a vent and open it ?
For wood you should have a damper in the Flu above the stove.
You can leave the vent open to get air for the fire to burn and close the damper so it doesn't draw a huge draft and burn to fast.
Matt " Achmed "
Team Quadratec #105
Thanks to, Rausch Creek Offroad Park
Clayton Offroad
Profender Suspension
AtoZ Fabrication
Dave's Offroad Supply
Rolo Motorsports
k5king is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 08:52 PM   #12 (permalink)
Member # 19022
Send a message via AIM to p575
pictures are deceiving, not sure how much space is behind that thing...i'd shoot for at least 18 inches between it and the wall...my stove is a different set up, but i know with a bigger blower, the heat output literally quadrupled. so, if you can get some kind of a fan/blower to move air ACROSS that thing, not THROUGH it, you will be light years ahead of the game. if the fire is going out when you shut the door, there is a flue somewhere in the chimney, if its not within a few feet of the stove, thats probably not the problem. there may be a cap or obstruction on/in the chimney as well. if the stove isn't smoking up your house, neither of these is likely the problem. (think engine here; air goes in at the door or carb. burns in the stove or cylinder, exits through the chimney or exhaust.)
there is probably some kind of "valve" on the doors, usually a big metal knob on a screw that you can turn out to open it, this is called a damper, and it basically acts as the throttle butterfly. open it, and fire should burn.
semper fidelis
official pit chef for Will Carter #52x.
yeah, i cook...
p575 is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 08:55 PM   #13 (permalink)
Member # 76297
What kind of tempatures should we look for on the chimmeny? Stove?
Old 10-18-2009, 08:55 PM   #14 (permalink)
Banned
4Mogger's Avatar
Member # 33748
Hopefully you figured out how to open the vent that allows the stove to pull air in... you will also need to figure out a way for air to get into your house to be sucked into the stove. I have a 2" pipe that runs through the basement wall underground about 50 feet or so until it comes up above ground for a vent to allow air into the house.
Old 10-18-2009, 08:56 PM   #15 (permalink)
Member # 76297
there is 9inches between the stove and the wall.
Old 10-18-2009, 08:56 PM   #16 (permalink)
Banned
4Mogger's Avatar
Member # 33748
200* to a max of about 400* is optimal IF it is single wall. This would be within about 2 to 3 feet up the pipe from the stove.
Old 10-18-2009, 08:58 PM   #17 (permalink)
Member # 19022
something like this will probably get you a lot of heat!
http://www.northlineexpress.com/item...sp?ic=5VZ-HR-6
semper fidelis
yeah, i cook...
Old 10-18-2009, 09:00 PM   #18 (permalink)
Member # 76297
Yes, we figured out the vent, it was a little okay alot rusty, took some wrenching to get it moving. There is a window right behind the unit so we can crack that for air. we dont have a basement... this is california. We barely get below freezing.
Old 10-18-2009, 09:03 PM   #19 (permalink)
Member # 76297
Its a Double wall says my bf.
I keep telling him to get on here to answer the questions. LOL
Old 10-18-2009, 09:18 PM   #20 (permalink)
Banned
4Mogger's Avatar
Member # 33748
Sound good, just watch the stovepipe temps they can go up in just a few minutes several hundred degrees.
Old 10-18-2009, 09:26 PM   #21 (permalink)
Richard's Avatar
Member # 233
i hope you have good insurance , most states require 48" away from any window , and so many inches from any combustible such as a wall
[COLOR="Red"]The Weather Is Here , Wish You Were Beautiful[/COLOR]
Richard is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 09:47 PM   #22 (permalink)
TLCObsession's Avatar
Member # 3245
You won't need to use it much since you have Mexican pavers on the floor and palm trees out the window.
Never subscribe to a conspiracy theory when the stupidity theory will suffice.
TLCObsession is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 10:12 PM   #23 (permalink)
Member # 76297
Oh those palm trees are gone, they were way to close to the house. And were in Fallbrook, it gets pretty cold here. not freezing but into the low 30's during the winter.
Old 10-18-2009, 10:14 PM   #24 (permalink)
IDASHO's Avatar
Member # 83932
What, not familiar with the Top-Down burn tech?
The way I build a fire, you dont have to add more fuel for hours.
IDASHO is offline   Reply With Quote Quick reply to this message
Old 10-18-2009, 10:47 PM   #25 (permalink)
Member # 103512
Minimum distance for the rear is 9" so your good to go on that. Minimum clearence for a double wall non air cooled pipe is 18". The tile underneath needs to be 3/8th" thick and extend atleast 16" in front of the stove
Your stove was made by leenox
RdRash is offline   Reply With Quote Quick reply to this message
