Scout II BUILD with Rockwells, Cummins 12V, and 46" Claws - Page 20 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-26-2019, 10:07 PM   #476 (permalink)
Blak Falken's Avatar
Member # 206164
Here's a few updated underhood pics with all of this work done:
Check out my YouTube channel:
Check out my build thread:
Blak Falken is offline   Reply With Quote Quick reply to this message
Old 07-26-2019, 10:09 PM   #477 (permalink)
Member # 206164
OK, here's a few more pics of the whole truck, it's close. Been putting off the wiring job but its coming up soon, not much left on the list
Old 07-26-2019, 10:11 PM   #478 (permalink)
Member # 206164
Here's a few pics from when I had the front end up in the air to bleed out the PSC hydraulic system. Turning the steering and having fun with it.
Old 07-26-2019, 10:13 PM   #479 (permalink)
Member # 206164
And one more of the whole truck, with the front end barely off the ground while bleeding out the hydro steering.
Old 07-26-2019, 10:20 PM   #480 (permalink)
Member # 206164
Originally Posted by waterhorse View Post
Everything looks very clean and "show worthy". About the only thing I question is the air cleaner. Will there be some kind of "cold air" ducted to it?
Thanks man, I appreciate it! Attention to detail is kind of my thing, makes for a slower build but the devil is in the details and I'm a bit of a perfectionist (for better or worse -- haven't quite decided)
I had originally planned on building a cold air box around the air filter with external ducting but there just simply wasn't enough room so I'll be relying on the larger intercooler to hopefully make up the difference.
That air filter is huge and space is very limited with the intercooler piping etc so close by.
I do plan to install these louvers I designed and laser cut in the hood whenever I finally start back on the Scout again. Should really help to vent the underhood heat and keep heatsoak down...
I would eventually like to laser or waterjet and TIG weld replacement (same sized) louvers out of Aluminum.
Old 08-10-2019, 03:32 AM   #481 (permalink)
runit02's Avatar
Member # 213253
Love the attention to detail and great pics. That 6b fits nicely.
runit02 is offline   Reply With Quote Quick reply to this message
Old 08-10-2019, 06:50 AM   #482 (permalink)
Member # 181868
For some reason, the louvers didn't come up in my sub. They look great. Can't wait to see them on the truck.
Project : Amphibious HEMTT
Old 09-15-2019, 07:15 AM   #483 (permalink)
Member # 704449
Great build! How tall is it to the bottom of the doors?
Dmaddoxboss is offline   Reply With Quote Quick reply to this message
Old 09-17-2019, 06:55 PM   #484 (permalink)
Member # 206164
Thanks! It's definitely a tight squeeze but can be made to fit well with some work.
For reason, the louvers didn't come up in my sub. They look great. Can't wait to see them on the truck.
Thanks! Haven't had the time to install the louvers yet but I'll keep everyone posted, going to have to pull the hood off to cut the holes in it without sending sparks everywhere.
Thanks! It's about 40" to the bottom of the doors from ground level.
Old 09-19-2019, 02:16 PM   #485 (permalink)
Member # 867678
Those look great and heavy.
Bolt2019 is offline   Reply With Quote Quick reply to this message
Old 09-19-2019, 02:18 PM   #486 (permalink)
Member # 867678
Great job on the install.
Old 09-19-2019, 02:21 PM   #487 (permalink)
Member # 56430
Build is amazing.
But your intercooler looks to be major blocking the radiator airflow, and the electric fan seems too small to accomplish proper airflow thru the smallish radiator. Hope I'm wrong.
:Your Signature: cannot include the words; Your, Signature.
Treeclimber is offline   Reply With Quote Quick reply to this message
Old 09-19-2019, 07:22 PM   #488 (permalink)
Member # 206164
Originally Posted by Treeclimber View Post
Build is amazing.
Thanks! I didn't attempt any air flow or heat transfer calcs but I think it should be OK. Time will tell. The Griffin radiator is a circle track radiator, its 26" wide x 19" tall and 3" thick. Per Griffin it is rated for 450 RWHP with the 1" tubes. The 1.25" tube version is rated for 650 RWHP, may have to upgrade to the 1.25" tube version if any overheating problems, my understanding is that the the overall dimensions are the same.
I don't think airflow will be much of a problem. The intercooler covers maybe 50% of the surface area of the radiator (see below pics). The fan is rated for 2,400 CFM, would have certainly liked more flow but couldn't fit dual fans. 2 smaller diameter fans couln't provide the air flow of the larger single 17" diameter fan. From what I read, a lot of people have had success with this fan cooling built big blocks in hot summer areas (TX, AZ, CA, etc), we'll see.
Old 09-19-2019, 07:32 PM   #489 (permalink)
Member # 206164
Build is amazing.
Also, in relation to airflow, just a comparison -- I've got a fully bulletproofed 6.0 Power Stroke that I recently installed upgraded (larger) Mishimoto trans cooler and CSF intercooler into. Just for reference, pics are below comparing stock to aftermarket. I also installed a Mishimoto aluminum radiator, and believe it or not the core of the Mishimotor radiator is thinner than the OEM. I was initially concerned about this especially since upgrading to larger trans cooler and intercooler that would further impede flow to the radiator.
With the Power Stroke 6.0L, the AC condenser, Trans Cooler and Intercooler all sit in front of the radiator, almost covering 100% of it. The core support sits right above the intercooler and blocks the remaining surface area of the radiator. Sure the mechanical fan can pull higher CFM but there still is pressure and flow drop through all these. Air flow isn't impacted significantly enough to cause any overheating issues in this configuration.
I routinely tow a 14k lb trailer through mountain grades (Sierra's, Siskiyou Pass, etc) and have never had an overheating issue. Recently did the 300+ miles of towing mountain passes of Southern OR into CA and no issue with heat. Lower engine oil and coolant temps. Lower trans temps. Lower IAT and EGT temps.
First two pics are comparing larger Mishimoto trans cooler to smaller OEM trans cooler and larger CSF intercooler to OEM intercooler.
Last 2 pics showing AC condenser, trans cooler, intercooler and radiator.
There is also a small power steering cooler in front of the AC condenser.
Also, not planning on doing any towing with the Scout
Old 10-02-2019, 02:45 PM   #490 (permalink)
76scoutII's Avatar
Member # 147458
Wow, what an amazing, epic build!!! Your fab/engineering skills are top notch, as mentioned, one of the best builds ive ever followed be it on tv shows or builds on forums, this one takes the cake!!!
I am a cnc machinist/programmer and know my way around solidworks, have worked with many mechanical engineers, and youve got most of them beat. "It works on paper" or "it works in the solid model" doesnt always mean its gonna work or be able to be manufactured easily in the real world. That takes real hands on experience and learning from your own fuck ups. again, you got some major skills and ability here. Getting things from cad software to an actual perfect fit takes a lot of patience, experience, and skill.
I love the attention to detail, down to brake lines and all the little finishing touches. I especially dig the lil side "projects" where you made custom 45 or 90 deg fittings, and the custom tube beader vice grips are just bitchin. I wish i woulda thought of that!! Major major props to one of the baddest build threads ever, and THE baddest 5 ton scout out there!!! Man i hope i run into you at a scout show someday, or even better, on the trail!!!
76 Scout II 392IC, SOA, D60F/60HD, H1's 37's
OBA w/ Reelcraft 50' retractable hose, train horn
76scoutII is offline   Reply With Quote Quick reply to this message
Old 10-08-2019, 05:46 PM   #491 (permalink)
Member # 1956
Very happy for you for getting it done. You have lots of patience!
The forest was shrinking, but the trees kept voting for the axe because itís handle was made of wood
Shadow man is offline   Reply With Quote Quick reply to this message
Old 10-26-2019, 07:00 AM   #492 (permalink)
budget76's Avatar
Member # 38264
Send a message via AIM to budget76
Ditto. There's been a couple incredible builds I've followed on Pirate. This one is up there for sure
76 Scout, 85 Toy. 94 Cherokee ALL SOLD
Resident Web-Wheeler
budget76 is offline   Reply With Quote Quick reply to this message
