Maybe Vapor Lock? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-14-2014, 12:45 PM   #1 (permalink)
Member # 155295
Maybe Vapor Lock?
Here it goes- 345 engine- after about 20 minutes it starts to stumble like it's gas starved- this is all at idle- the idle RPM's go down to slightly under 500 (after being at around 600 and running smooth) and the engine bay is REALLY hot- like the fenders are really warm- the temp is about 200-210 degrees and I have to put my foot on the gas to keep it running- it has been about 12 years since I have changed the thermostat and the upper rad hose seems spongy and REALLY hot- the fuel line runs next to the thermostat housing btw- any ideas or add info needed?
oldretiredguy is offline   Reply With Quote Quick reply to this message
Old 11-18-2014, 10:13 PM   #2 (permalink)
R290's Avatar
Member # 46467
Sounds like it warms up and then starts running rough. I had a bad egr valve . I plugged the vac line and the issue went away.
I would test and look at all the temp vacuum sensors.
Or it could be your carb just needs to be adjust to 600 when the engine is warm?
73 IH Scout
R290 is offline   Reply With Quote Quick reply to this message
