40"s Rim Suggestions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-17-2018, 06:09 PM   #1 (permalink)
Scouty's Avatar
Member # 681
Planning to run a set of 40x17x13.50s Maxxis Creepy Crawlers on my Scout II. I have a set of H2 rims I want to use but am not sure if the tires will rub on the front springs due to the backspacing. Springs are stock width apart. Anybody run H2s with 40's on their Scout? I guess I could use wheel adapters/spacers but a good set could cost as much as buying a set of new rims with less backspacing. Trying to decide which way to go before I mount the tires on the rims. Any feedback would be appreciated.
"Anything Less is Just A Pile of Chit"
Scouty is offline   Reply With Quote Quick reply to this message
Old 06-23-2018, 06:05 PM   #2 (permalink)
dantheman27's Avatar
Member # 105852
I know you are looking for an answer from people who have ran your combo, but would it really be so hard to make a tire/wheel combo from scraap plywood and lumber to check your clearance? Its your rig, do what you want; but i would check for myself with something cheap before buying wheel$ my 0.02
dantheman27 is offline   Reply With Quote Quick reply to this message
Old 06-24-2018, 10:12 AM   #3 (permalink)
Member # 83301
Stock chevy width spring spacing? I would imagine you will rub. h2's are pretty narrow.
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
Old 06-24-2018, 04:05 PM   #4 (permalink)
YotaAtieToo's Avatar
Member # 25632
Fwiw, I had my 41.5 pit bulls on 17" KMC's with 4.75" bs and they didn't rub the leafs at stock gm spacing. To be fair I think I have a little angle left the way I set up my steering.
YotaAtieToo is online now   Reply With Quote Quick reply to this message
Old 06-25-2018, 01:12 PM   #5 (permalink)
Member # 165240
You may have to just mount one up and bolt it on to confirm if it will clear the leaf springs, etc. The only way to know for sure with your particular set up. Those wheels have 5 5/8" backspacing, so it will be close and most likely hit the springs. Your hubs will also stick out and be prone to damage, even it you have the low profile Yukon Hard Core's or drive flanges. In my experience, the H2 wheels are also very prone to burping air at lower pressures on both inner and outer beads.
ScoutBurton is offline   Reply With Quote Quick reply to this message
Old 06-25-2018, 04:04 PM   #6 (permalink)
Scouty's Avatar
Member # 681
Thanks for the feedback. I'm leaning towards different rims mostly because of the potential damage to the hubs. I can think of a few wheeling situations where I used my tires to keep me away from a rock wall and if I had these H2 rims the hubs would have taken a beating. I also like the added width wheels with less backspacing give the truck, seems to give it more stability in pucker situations. My current boggers are on 15" wheels with a reverse 2.75 backspacing, puts the width at 98 inches, that's a little too wide but very stable.
Old 08-20-2018, 04:35 PM   #7 (permalink)
R290's Avatar
Member # 46467
https://www.summitracing.com/parts/b...8035/overview/
Or some dodge 2500 rims
73 IH Scout
R290 is offline   Reply With Quote Quick reply to this message
Old 11-07-2018, 09:35 PM   #8 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Been running 37s on H2 rims D60/14B on my 1965 Scout no issues.
guidolyons is offline   Reply With Quote Quick reply to this message
Old 11-08-2018, 09:26 AM   #9 (permalink)
Harvester of Sorrow's Avatar
Member # 11615
Send a message via Yahoo to Harvester of Sorrow
37 x 12.5 x 17's on H2 rims here. No rubbing on the springs of my front Chevy full width. I do have my steering stops dialed out a bit.
Steering stops are out farther to mainly keep the front Dana44 joints happier. They are also out to ensure that my hydro-assist steering ram isn't pushing against the arms.
Went wheeling on Oct. 27th and this is from that weekend.
Be sure to run RUBBER valve stems with the H2's. Metal stems will snap in the rocks or on trees....on the above wheeling trip I lost 2 metal valve stems within 50 feet....
Harvester of Sorrow is offline   Reply With Quote Quick reply to this message
