Brake drum bi ding after bearing change, rear D44. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-04-2018, 11:18 AM   #1 (permalink)
Newbie
Member # 852646
Ran into a issue after installing new rear bearings on a D44 from a late 70s Scout ii
Got both the rear axles out, old bearings off and new timkin bearings and seals pressed on, both axles installed nicely with new 1/4 retainer plates. Used a press to separate the bearings and install the new ones. I did one side at a time, to eliminate any chance of getting the axles and drums mixed up.
Truck is on axle stands, both t-case and gear box are in neutral.
Both axles spin freely without brake drums or wheels on.
Both axles spin freely with both brake drums on.
Both axles spin freely with both brake drums on and only the passenger side wheel on.
Neither axle spins freely with the drivers side wheel on.
If I back the wheel nuts off off on the drivers side both axles will spin, but they bind up when the drivers side (only the drivers side) wheel is tightened. Passenger side is fine, only happening on the drivers side.
Best set I can figure is the drivers side axle is now sitting about 1/8 inwards from the previous bearing setup, and the brake drum is binding either against the brake cover plate, or the outer lip of the brake shoes are binding against the drum face.
no idea how to fix this other than a spacer between the axle flange and the inside of the brake drum. Not sure if thats the safest route.
Anyone ever have have to deal with something like this before?
Iron mike71 is offline   Reply With Quote Quick reply to this message
Old 11-06-2018, 02:52 PM   #2 (permalink)
Harvester of Sorrow's Avatar
Member # 11615
Send a message via Yahoo to Harvester of Sorrow
I would take it all back off and re-check your bearing install.
I havn't had a 44 rear for a really long time, so I don't recall the stacking order, or the plate thickness...
BUT since you are binding when you suck the drums to the axle...that is your answer.
Harvester of Sorrow is offline   Reply With Quote Quick reply to this message
