Wheeling Update 10/27/2018 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-26-2018, 09:19 PM   #1 (permalink)
Harvester of Sorrow's Avatar
Member # 11615
Send a message via Yahoo to Harvester of Sorrow
We have a wheeling area near me that was re-opened up for a couple of years now with much work between the user group and the DNR. It is gated at night and has "regular business hours"...
All the trails are "man made" with the work being planned, designed, and excavated with the approval of the DNR. Unfortunately, people are still fucking dickwads and are creating bypasses, illegal tie-ins, off trail entry points, etc. So we have work parties that help clean up and maintain the trails.
Here we are heading out to the top of one of the trails to drop in from the high side and start working on placing logs to create a curb of sorts. This helps to keep people from sliding too far off of the trail when slick and sliding towards the downhill side.
Part of the group here doing a bit of rock bar work and log moving.
This section of trail is pretty great. It was really starting to suffer from dig outs and not being able to climb up the horizontal log step in the background. So we rock bar and maneuvered some pretty big stones into place to create a still difficult, but more usable lead in. I'll post video later of the finished approach.
We did some wheeling and crawling around for a bit during and after the work. Here is my younger 18yo son in the front and his little Filipino buddy who has never really been in the mountains, let alone in a 4x4, or on a trail. He really shit himself in a couple spots.
When I assembled the Hummer or H2 rims and the Federal Couragia MT's together I used short metal valve stems...FUUUUUCCCCKKKK. With the massive 5.5 inch backspacing the valve stem as well as the hubs are left out close to the face of the rims. As a result the valve stems are like fingers just waiting to grab rocks.
The front passenger valve stem got snapped right as I was spanking the newly reworked climb in the photo above. The Scout did a great job of picking the boulder on the driver's side and then dropped the passenger side over. It was just enough for the valve stem to kiss the new big rock there...FUUUUUUUCCCCKKKK.
I bought an 8 pack of rubber valve stems but left them in the toolbox back at the tow rig. Luckily a fellow on the trail had a spare. I drove it far enough to break the outer bead and then we strapped it to a tree to take the pressure off the tire.
Harvester of Sorrow is offline   Reply With Quote Quick reply to this message
Old 11-26-2018, 09:35 PM   #2 (permalink)
Member # 11615
With my quick air tank pressurizing my beer in my keg fridge...a fellow in the group had a small compressor and we reseated the bead.
Then 50 FUCKING FEET after getting that tire fixed, I lost the valve stem on the driver's side rear. I lost it in the very last little section of the trail. The section isn't even fucking hard and I only had to reset my line one time because I was hanging on my rear diff. I ended up just saying fuck it and gassed out to the gravel section after the trail. I drove it down the 1/2 mile down the dirt road and just fucking loaded it on the trailer.
Got the rig home and in the garage. Then the next night I went ahead and broke the bead down and put a rubber valve stem in. I used my Suburban and the curb to get the bead off the rim.
After I confirmed I didn't trash the tire driving it on the rim... I went ahead and remounted. I also used the opportunity to check the torque on my rear wheel spacers. Always a good idea to check them every once and awhile. All good!
Hopefully the trails in the area won't see tooo much damage over the winter and we can have a great spring season.
Old 11-30-2018, 07:54 AM   #3 (permalink)
Registurd Abuser
'71 800B's Avatar
Member # 34995
Looks like a good time!
The only thing I did related to wheeling was to order a 7/8" Heim tie rod kit from Ruff Stuff. The 1 ton Tre's won't stay tight. I had one trip where I found both castle nuts split. The only thing keeping them together was the cotter pins. I replaced the nuts, went wheeling and found a stripped nut.
The tapered holes in the high steer arms are now egg shaped but not larger than 3/4" so the kit I ordered will fix it.
Other than that I've been working on the wifes Christmas house display. Turning Styrofoam sheets into mountains and feeding one of our puppies. We have a puppy that might have Hydrocephalus and liver issues. She is losing weight and it looks like we might lose her. She is down to 1.35 pounds.
Also pulled the tent trailer out and cleaned it up so we can sell it.
Also got signed up for Wheeling Warriors again. I got put on Roller Coaster but am on the list to be moved to Compressor or Denver creek if someone drops out.
'71 800B is offline   Reply With Quote Quick reply to this message
