My official Scout 80 build up thread.. - Page 8 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-30-2006, 07:25 PM   #176 (permalink)
"All Weeee Drive!"
MochaMike's Avatar
Member # 6450
and D18/20s.
62 IH Scout, Built to wheel.
MochaMike is offline   Reply With Quote Quick reply to this message
Old 08-30-2006, 07:38 PM   #177 (permalink)
R290's Avatar
Member # 46467
Originally Posted by Creepy196
It was worth a try...
BTW- Since you're planning on runnin' a twin stick setup (three including the 203), did you remove the interlock pills from the D300? If not, better do it now...
This Mod
73 IH Scout
R290 is offline   Reply With Quote Quick reply to this message
Old 08-30-2006, 08:02 PM   #178 (permalink)
Brandon's Avatar
Member # 6
Send a message via ICQ to Brandon
so do I need to do anything to the 300 or ??
EDIT
found this..
http://www.4x4wire.com/tech/dana300/#FWDHi
At this point I don't think I will mess with it, all it stops me from doing is FWD hi range..
This Space for rent!
Brandon is offline   Reply With Quote Quick reply to this message
Old 08-31-2006, 02:31 AM   #179 (permalink)
Creepy196's Avatar
Member # 21558
EDIT
found this..
I don't have experience with D300s. I do know that it's an 'improved' D20. The twin-stick D20 in my Scout 800 wouldn't shift into FWD-low with the pills in place. The choices available were RWD-low (left stick forward), N (duh), 4WD-Low (both sticks forward), RWD-Hi (left stick back), and 4WD-Hi (both sticks back). It wouldn't let me move the right stick (front axle) forward or backwards when the left stick(rear axle) was in the middle (N) possition. The interlocks only allowed the F stick to be moved from neutral to whatever possition the R stick was already in. If the F stick was in neutral I could move the R stick whichever way I chose. Remember that these movements are for the sticks, not the shift rods which of course move in the opposite direction.
I agree that FWD-Hi isn't all that usefull for most non-comp wheeling. However, FWD-Low is usefull at times, especialy if you have a Detroit in the rear. With the pills out, I can shift both axles independantly. Of course, there's a danger involved as stated in the 4X4Wire article!
I haven't twin-sticked a D20 that wasn't already twin-stick from the factory. Maybe the interlock notches on single-stick D20 shift rods (and therefore D300 shift rods) are diferent than those on twin-stick D20 shift rods. It would make sense as the rod notches affect the 'sequencing' of the shift rods in a single-stick setup.
Great...now I've gotta pull the shifter assembly off of a spare single-stick D20 and start playing with the shift rods to see if I can get it in FWD-low with the pills still in there!
Before you bolt the case in the rig you may wanna see if you can shift it into FWD-low (if you care for that option). If you don't need to engage the front axle without engaging the rear (you do have ARBs instead of Detroits afterall) then just say "screw it" and bolt the sucker up!
Creepy196 is offline   Reply With Quote Quick reply to this message
Old 08-31-2006, 09:18 AM   #180 (permalink)
Harvester of Sorrow's Avatar
Member # 11615
Send a message via Yahoo to Harvester of Sorrow
I run a Dana20 that is twin sticked...I have been using the shit out of FRONT HI lately for doing digs around tight corners, root notches, lifting up and around tight trees...
With the auto I prefer FRONT HI over FRONT LO because of spin-up...less torque loading on the front joints...and on the front drive shaft.
Just my .02cents...As either way...being twin sticked is better than not being.
Harvester of Sorrow is offline   Reply With Quote Quick reply to this message
Old 09-06-2006, 11:06 PM   #181 (permalink)
Brandon's Avatar
Member # 6
Well gee on flat ground I could fit about a 2 3/4" driveline (tranny interference) but then if it flexes..
This would work much better with a drivers side drop tcase and a drivers side diff.. hmmmm
Wonder if I should mess with swapping tubes (not exactly fun)
Old 09-07-2006, 01:20 AM   #182 (permalink)
Creepy196's Avatar
Member # 21558
Oh Crap...
I see a modified tranny crossmember, small diameter/thick wall driveshaft, and a modified tranny pan in your future. Bumpstops also look to be your friend. You could mod the crossmember so that it jogs up towards the top of the PS frame rail at the tranny mounting pad. That'd give you a few more inches of clearance. I can't remember what lives inside that area of the tranny pan. Hopefully there's some dead space...
Would it realy be that much better with the pumpkin on the driver's side? From the pics it doesn't look much different on that side to me, other than your engine's offset a little to the passenger side. OTOH, that offset would help a bit, and you can get the housing farther up under the DS spring, bringing the driveshaft yoke closer to the wheel (as Ford intended it of course)...
Old 09-07-2006, 07:51 AM   #183 (permalink)
Brandon's Avatar
Member # 6
that crossmember was temporary so that is not a problem, and yea - if I can modify the pan life will be much better. I need to pull it to see..
Your right on with the engine offset helping and all..
If I could just find a Ford HP D60..
I could clock the case differently but I don't see that helping. As it is I have to cut that big plate on the 203 (yoke won't rotate, it interferes)
Old 09-08-2006, 07:07 AM   #184 (permalink)
chandall's Avatar
Member # 66
Send a message via ICQ to chandall Send a message via AIM to chandall
Start over
2007 Wrangler Rubicon JK on 38 MTR's and Raceline Beadlocks, 5.38's, 4.5" Synergy Coils with Clayton Arms, 5.7 Hemi, Atlas 5.0, Clayton Skids, Dynatracs, ARBs, RCV's, Reid knuckles, PSC Hydro, Poison Spyder armor, Custom "Strange Built" full cage, Fox 2.0 Shocks, Rescue Green with Half Doors
chandall is offline   Reply With Quote Quick reply to this message
Old 09-08-2006, 03:15 PM   #185 (permalink)
Brandon's Avatar
Member # 6
I pulled the pan - plenty o clearance (who needs the pan, right?). I'll get my drivelines to Jess next weekend and hopefully pick them back up the following weekend
Old 09-09-2006, 08:40 AM   #186 (permalink)
Banned
Snoopy's Avatar
Member # 5650
Looking good.
Snoopy is offline   Reply With Quote Quick reply to this message
Old 09-10-2006, 12:44 PM   #187 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Brandon-
Looks like you got the doubler all worked out then. I am watching your build closely, I have a '65 Scout 80 sitting on jackstands in the garage, no big build planned, yet...I am just working on just getting it driveable for now, and gather parts for later.
guidolyons is offline   Reply With Quote Quick reply to this message
Old 09-10-2006, 07:24 PM   #188 (permalink)
Brandon's Avatar
Member # 6
yea, I need to clearance the plate to fit the way it is clocked but it is going to work out well. I didn't want to have to guess on clocking, this way I just picked what I wanted and bolted it together..
Old 09-10-2006, 07:57 PM   #189 (permalink)
Member # 35721
dont know if your still having problems with that cross member fitting but you should take a look at ORD's website they had to take a stock crossmember and cut and weld some more pieces so it could go up and over the front output shaft... fyi
73 Scout II,350tbi,700r4,twin sticked np205,4:1klune,60f,14b,4link fr/rr,coilovers fr,42"pitbulls
ih4ever is offline   Reply With Quote Quick reply to this message
Old 09-10-2006, 10:57 PM   #190 (permalink)
Brandon's Avatar
Member # 6
I feel like I have posted it a million times - that crossmember was just for mockup!!
I do need to make a permanent one but that was just something that slid along the top of the frame so the drivetrain was "hung"
I'm not worrked about one but I'll see what they did. I've made quite a few different ones in different rigs though
Old 09-10-2006, 11:15 PM   #191 (permalink)
Member # 56574
I would have worked on the clocking instead of the pan fabricating.
63 Scout 80, 350 sm465 kluneV np205, 1 tons, 42" Pitbulls
scout254 is offline   Reply With Quote Quick reply to this message
Old 09-10-2006, 11:48 PM   #192 (permalink)
Brandon's Avatar
Member # 6
well the shaft crosses under the pan so clocking it higher would only make it interfere more..
Besides, it's still higher than the 203 so clocking it up higher really wouldn't gain much
Old 09-11-2006, 12:09 AM   #193 (permalink)
Member # 56574
I know you want ground clearance... but I was thinking clocking down a hair.
Old 09-11-2006, 09:10 PM   #194 (permalink)
chandall's Avatar
Member # 66
You should think about a beefier crossmember. I really think that one may be a little under built.
I'd hate to have to tow you out on account of chinsey engineering.
Old 09-11-2006, 09:15 PM   #195 (permalink)
Brandon's Avatar
Member # 6
u funny
BTW top shot
Old 09-15-2006, 01:50 PM   #196 (permalink)
Brandon's Avatar
Member # 6
driveline time, you guys running 300's only running 1310 joints in your driveline or is there a flange that will slip in to use a 1350 etc?
Old 09-15-2006, 02:42 PM   #197 (permalink)
BLK Scout 800's Avatar
Member # 29630
Send a message via MSN to BLK Scout 800 Send a message via Yahoo to BLK Scout 800
You of all people should know how badass toyota u-joints are Let me look around for the # of the guys that make the toyota flange for a Dana300 and dana 44. 1350 joints are much weaker than stock ''toyo'' joints for toyota trust me........
*EDIT* 1-909-629-9002
"Truth is, everybody is going to hurt you; you just gotta find the ones worth suffering for." -Bob Marley
BLK Scout 800 is offline   Reply With Quote Quick reply to this message
Old 09-15-2006, 02:59 PM   #198 (permalink)
Brandon's Avatar
Member # 6
interesting, that thought never occurred to me even though that is what my drivelines have right now since I ran a toy case to the same axles in my last rig..
Old 09-15-2006, 03:45 PM   #199 (permalink)
Member # 29630
Your kidding me
Old 09-15-2006, 04:01 PM   #200 (permalink)
Brandon's Avatar
Member # 6
I owe you some or something, you just saved me a ton o $$$
