*Pics* J. B. Custom Fab Twin Sticks Scout D300 installation - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-23-2006, 03:31 PM   #1 (permalink)
no strings on me
YellowIH's Avatar
Member # 12036
I know the twin stick thing has been covered to death, and this may not be hardcore tech, but here is my project on the install of the J.B. Conversions, http://www.jbfab.net/ , Scout D300 Twin-Stick conversion:
This kit is *supposed* to be specifically made for the Scout D300, but it did/has required some customizing. It also mandates a removal of the transfer case from the vehicle...unless you drill a good sized hole in the transmission tunnel. Which I was tempted to do after I installed the D300 the first time to replace the D20....only to find that the twin-stick fulcrum bolt cannot be installed with the t/c in the Scout. Great....grrr..
Business end that the D300 bolts to, and a shameless plug for the RPT Tranny mount. Great product.
Here is the twin-stick installed on the Dana 300, with the sticks custom bent to work in the Scout. I have a 2" body lift and poly body mounts, FWIW.
Fulcrum up close. I added an extra washer for clearance reasons to the H-N-L shifter:
Shift rail adapters:
Interior image:
Clearance from transmission tunnel that allows use of stock shifter hole:
Had to remove the passenger side exhaust to make it work.
Installed pic of the shifter:
My custom dash from last spring:
More to come once I get it all installed. I know you are on pins and needles.
/ SS'd 73 IH Scout II & stuff / Μολὼν λάβε /
/ Resident Attorney at Law
YellowIH is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 08:57 PM   #2 (permalink)
no strings on me
YellowIH's Avatar
Member # 12036
Here are pics of the installed product:
I'm happy with the product. Wish the sticks were longer...but that's part of the 2" body lift. Easy to reach and shift. Nifty sticker for the shift pattern too.
Would not say its a bolt on product. (You gotta pull the t/c out....unless the BL caused the bolt install issues.) I think no matter what the stick would need to be heated and bent.
Good "bolt-on" product as far as a Scout goes though.
Old 08-02-2006, 10:31 PM   #3 (permalink)
BLK Scout 800's Avatar
Member # 29630
Send a message via MSN to BLK Scout 800 Send a message via Yahoo to BLK Scout 800
Did it come with the boot and all the other start to finish stuff?
"Truth is, everybody is going to hurt you; you just gotta find the ones worth suffering for." -Bob Marley
BLK Scout 800 is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 10:43 PM   #4 (permalink)
www.jbfab.net
JB Custom Fab.'s Avatar
Member # 62303
Just let us know what the adjustment are that you had to make.........and we will make the changes!
It is our goal to have the best possible products.
Thank you for your feedback.
Jon
Made in America (by Americans)
JB Custom Fab. is offline   Reply With Quote Quick reply to this message
Old 08-02-2006, 10:48 PM   #5 (permalink)
Member # 35721
if you really wanted the sticks to be longer you could by some more solid steal bar and machine the inside of it to screw around the top of the shifters then you would have some longer sticks... my np 205 twins sticks stick out plenty, but then again i only have a 1 inch body lift
my .02 cents
73 Scout II,350tbi,700r4,twin sticked np205,4:1klune,60f,14b,4link fr/rr,coilovers fr,42"pitbulls
ih4ever is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 08:38 AM   #6 (permalink)
Harvester of Sorrow's Avatar
Member # 11615
Send a message via Yahoo to Harvester of Sorrow
Have you wheeled with it yet?
I know that in *my* rig I would not be able to reach the sticks if they were that low and straight up...I would have to ask the passenger to shift them.
With shoulder harness on and or with regular wheeling you might find that you will be lengthening those sticks...the more front digs/burns you start doing or Rear Low driving on the trail the more shifting you will be doing. Lots of bending over to touch the knobs...
Looks like a decent product over all though...
Harvester of Sorrow is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 08:43 AM   #7 (permalink)
no strings on me
YellowIH's Avatar
Member # 12036
Yes.....I may have used my own shiny self cutting screws though....
Old 08-03-2006, 08:56 AM   #8 (permalink)
no strings on me
YellowIH's Avatar
Member # 12036
I am mainly a web wheeler....there I said it.
I may pull them later on and add to the stick lower down. Do not like the idea of the funky looking add-on where I can see it and be pissed every time I look at it because I knew I could have did a better job with the install.
I've been practicing on the street "speed" shifting it....and it does take some getting used to.
Old 08-03-2006, 09:06 AM   #9 (permalink)
no strings on me
YellowIH's Avatar
Member # 12036
Jon
I had to heat and bend the sticks lower point and upper part of the sticks b/c they were hitting the passenger side of the stock shifter hole.
I have been told that the scout 300's have a different clock downward than the Scout D20's. This could be the problem. Maybe someone will chime in. Doug Scott, TN's resident Scout expert told this to me the other day.
Maybe that's why the sticks were hitting the passenger side.
I'd like them longer too....even without a body lift.
Also should put in the instructions that you may have to remove the t/c to install. I did....but again, that may be because of the bodylift.
My thoughts. Good product.
