my 800 build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-02-2006, 10:20 PM   #1 (permalink)
chris fresh's Avatar
Member # 69678
my 800 build
heres the 400/ 203/ 205
had to trim
but plan on building a aluminum center console anyway ( tranny hump)
chris fresh is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 08:41 AM   #2 (permalink)
Harvester of Sorrow's Avatar
Member # 11615
Send a message via Yahoo to Harvester of Sorrow
what company did you use for the adapter for the doubler?
The trimming required doesn't look *that* bad...very interesting...
Harvester of Sorrow is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 02:24 PM   #3 (permalink)
binderbound's Avatar
Member # 18592
Send a message via AIM to binderbound
How are you going to mount your seats? Runing tube over that thing is gonna be a pain if you tie into the cage.
binderbound is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 02:35 PM   #4 (permalink)
Member # 11615
My seats are already tied to the cage and fairly high...By the time I would be able to do something like this in reality...My rig will probably already be buggified...or this would be part of the buggification process...
But I like how it is not "TOO" much longer than a standard TH400 and Dana20:::
Really only looks like about 6" longer...
Old 08-03-2006, 02:58 PM   #5 (permalink)
Member # 18592
Did you see where his output is? Its like 12" farther back than yours. But, you dont know where his engine is located in the bay compared to your either. i'm guessing its a few inches farther back than yours. Also, his trans is about 4" taller than the old hump. Running seat bars is gonna be a bitch, no way around it.
Old 08-03-2006, 03:01 PM   #6 (permalink)
Member # 69678
jed's machining, real nice guy. he sent me the adapter, all the gasgets,hardware,new side cover for the 203.
i sent him my 203 out put shaft and he cut it,resplined it,comes with the new 90mm bearing
and also the new 32 spline input shaft for my 205 case.
everything you need from bearings to seals to gagets.
instructions were kinda fuzzy because they have been copied about a million times. but it's realy self explanatory
it was my first one and had no problems at all
Old 08-03-2006, 03:07 PM   #7 (permalink)
Member # 69678
funny thing is- that pic is real deceiving. the factory cover goes on right now without touching, don't get me wrong, it's close, but doesn't touch.
also the whole thing is about 2 inches higher than need be,just fabbed the new crossmember lastnight.
everything now is above the bottom of the frame rail by about a half inch
i plan on fabbin somekind of full skid plate to cover the bottm
Old 08-03-2006, 03:18 PM   #8 (permalink)
Member # 69678
i also gained length on the whole thing from the electric fan set up wich robs roughly 3'' inches and the adapter takes up 3 and change. so between the radiator,fans,LT-1, 400 trans, two large cases and the adapter........that's what i got. i've managed to use all possible length and width on this project so i could run 1 ton drive train, but i'm real happy with the fit so far
Old 08-03-2006, 03:27 PM   #9 (permalink)
Member # 69678
heres the frame off veiw
Old 08-03-2006, 03:28 PM   #10 (permalink)
Member # 69678
note the fresh PVC drive shafts. crazy strong............for a minute
Old 08-03-2006, 03:51 PM   #11 (permalink)
"All Weeee Drive!"
MochaMike's Avatar
Member # 6450
Do to rust & my 465/D18 I had to do the same..
I'll be swapping a doubler in this winter, so we'll see where it goes from there.
PS... Seats tied into the cage was pretty easy...
62 IH Scout, Built to wheel.
MochaMike is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 04:58 PM   #12 (permalink)
Member # 69678
sorry H.O.S the price was 720 for everything shipped
Old 08-03-2006, 05:04 PM   #13 (permalink)
Member # 69678
yeah mike, i've done all the metal work over the last year, completely new rear floors from tail gate to front seats all out of one peice of 14 gauge, yeah no seems, had a buddy bend it up in his brake,kinda tricky to do but do-able and the front floors are the same 14 gauge the frame work under the rear floor is all new made out of 1 1/4 11 gauge tube, the tailgate was completely rotted except for the stamped scout part,so i cut it out and made a new frame for it, now it's a swing out
it never ends
theres always somethin to do
Old 08-03-2006, 05:26 PM   #14 (permalink)
Member # 69678
new tail gate
Old 08-03-2006, 05:55 PM   #15 (permalink)
Member # 32403
the build is great, I am picking up a 800 this weekend to build. 350/400/203/205
HP 60 front 14 bolt rear. 44"tsl's. my buggy is coming apart this winter to build more of a trail rig. what springs are you running? I was thinking of 44044 front and rear and getting rid of my coils.
reuben is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 05:56 PM   #16 (permalink)
Banned
Snoopy's Avatar
Member # 5650
Oh my, that isn't that clean scout you had a big ago is it?
Snoopy is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 06:02 PM   #17 (permalink)
Brandon's Avatar
Member # 6
Send a message via ICQ to Brandon
had to trim
for reference I still need to add my 300 behind my 203, not sure if I will have to cut out the back yet or not. Ordered my adapter today
Clean build, how about some overall pics?? Is your 203 "clocked"?
This Space for rent!
Brandon is offline   Reply With Quote Quick reply to this message
Old 08-03-2006, 06:05 PM   #18 (permalink)
Member # 69678
snoop which truck are you referin to? not my scout 2 are ya? sure yer not thinkin of mike fresh? with the 68 800 b on 35'' mtr's
this truck has gotten all new floors
new rear corners built from scratch
new tailgate from scratch
new inner fender wells
i've owned clean trucks, this one was a disaster 3 years ago
Old 08-03-2006, 06:09 PM   #19 (permalink)
Member # 69678
brandon, yes it's clocked but it's the 205 or whatever case that gets clocked, guy asked me if i would like the rotated option and i said yeah, it gets the bottom of the case flat
Old 08-03-2006, 06:24 PM   #20 (permalink)
Brandon's Avatar
Member # 6
sometimes people flip the 203 or lay it flat, just curious if you did that but I guess yours is just like mine.
thx
Old 08-03-2006, 06:30 PM   #21 (permalink)
Member # 69678
my 203 was bolted to the 400 trans and wasn't the problem, once you lose the whole rest of that huge case. my 205 would have hug down if i didn't have jed clock the adapter brack to rol the 205 up
Old 08-03-2006, 06:37 PM   #22 (permalink)
Member # 69678
reuben i'm runnin 3'' wrangler lift springs up from and stock f-40 rear springs,they were free and a freind ran the same set up
same tires and rims
same axles and they worked realy well. they will do for now, but eventualy i'm goin 4 link front and rear
freind of mine just won 4 bilstein 9100 external resivior shocks from a kid in a poker game and has no use for them so i traded the shocks for a 150 dollar gas grill and he's happy as can be.....................can you say sweeeeettt!!!!
i will never try and have smart freinds again.LOL
Old 08-03-2006, 06:50 PM   #23 (permalink)
Member # 69678
hey brandon!!! heres the closest thing i have for over all pics at the moment untill i get the shop regrouped this weekend
Old 08-03-2006, 06:51 PM   #24 (permalink)
Member # 69678
check it
Old 08-03-2006, 06:59 PM   #25 (permalink)
Member # 69678
motor shot
