'67 Scout 800 spring-over-axle conversion Q's. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-05-2006, 07:01 PM   #1 (permalink)
Member # 77329
I recently purchased a '67 Scout 800 w/ 266 V8 and 4 spd. manual tranny. I am trying to get an idea as to how much entire spring over axle conversion project will cost. I have been told I will need to modify steering and brake lines. Does anyone know what exactly is required for the brake and steering modifications? Also, is there any other parts or modifications that I have not mentioned please let meknow. If anyone has any recommendations to do this service in the So Cal area I would really appreciate it. Also, any advice or suggestions would be greatly appreciated.
Thanks,
Richard G.
rgraham09 is offline   Reply With Quote Quick reply to this message
Old 08-05-2006, 09:38 PM   #2 (permalink)
Member # 74418
Front drive shaft, check out www.dandcextreme.com and look at the buildup section.
[B][COLOR="Lime"]Where there monkeys? Some terrifying space monkeys maybe got loose?[/COLOR][/B]
79 Traveler - 345 4bbl auto d20 d44's 3.73
64 model 80 - in 800 pieces but still good looking
30.06 M1 Garand - one ass kickin IH
Trukker is offline   Reply With Quote Quick reply to this message
Old 08-05-2006, 11:21 PM   #3 (permalink)
Brandon's Avatar
Member # 6
Send a message via ICQ to Brandon
that depends on to what level you take it. On the cheap side you relocate the metal lines, simply weld perches on top of your axles and possibly modify drivelines. Total cost less than 2 bills.
I wouldn't put those dinky springs back on a build up rig though, I'd be swapping the entire suspension, and I wouldn't run those stock axles so I'd ditch those and then your going to need to set your caster and then and then and then..
This Space for rent!
Brandon is offline   Reply With Quote Quick reply to this message
Old 08-05-2006, 11:33 PM   #4 (permalink)
binderbound's Avatar
Member # 18592
Send a message via AIM to binderbound
If your asking these questions, its way out of your league. Take it to IHonly and warm up the Visa.
binderbound is offline   Reply With Quote Quick reply to this message
Old 08-06-2006, 06:22 AM   #5 (permalink)
SSGTWC's Avatar
Member # 10775
Send a message via Yahoo to SSGTWC
I suggest you head over to the Binder Bulletin and start doing some serious research.
[QUOTE=CAMO;4]
[B]
build what ya can with what you have and plan on redoing it a few dozen times as you learn the required skills
[/B][/QUOTE]
Never, underestimate the amount of stupidity in people!
SSGTWC is offline   Reply With Quote Quick reply to this message
