war pony build - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-31-2008, 06:21 PM   #126 (permalink)
budget76's Avatar
Member # 38264
Send a message via AIM to budget76
how'd I forget the damn picture
76 Scout, 85 Toy. 94 Cherokee ALL SOLD
Resident Web-Wheeler
budget76 is offline   Reply With Quote Quick reply to this message
Old 03-31-2008, 08:01 PM   #127 (permalink)
Member # 105834
I thought it was my computer
war pony is offline   Reply With Quote Quick reply to this message
Old 04-01-2008, 08:54 AM   #128 (permalink)
R290's Avatar
Member # 46467
OK I spent like 1 minute on this. Looks like you will need to stretch the fender a bit base on those tire sizes
Budget76 the clone tool is your friend
73 IH Scout
R290 is offline   Reply With Quote Quick reply to this message
Old 04-01-2008, 05:38 PM   #129 (permalink)
Member # 105834
Thanks R290, nice trick. I plan to go up 4" and back 4" and section 4" from center. Brandon noted for the section , wish he could have told me sooner it would have happend on the front as well.
Old 04-03-2008, 02:33 PM   #130 (permalink)
Brandon's Avatar
Member # 6
Send a message via ICQ to Brandon
ha ha, I actually thought you did your work based on my pictures already - so your much more "original" than I thought
This Space for rent!
Brandon is offline   Reply With Quote Quick reply to this message
Old 04-03-2008, 05:39 PM   #131 (permalink)
Member # 105834
Each time we think we are original, all we need to do is go back 30 years. But I do like the section you did , and I do plan to use your idea, so you do deserve the props for it. thanks again. Did you ever get time to lift your body off?
Old 04-04-2008, 06:07 PM   #132 (permalink)
Brandon's Avatar
Member # 6
nope, finishing an addition on the house still, other than that the only scout work I am doing is Cub Scouts with my son... Scout. Getting close to a stopping point on the house though, and getting ready to get back tow work on the Scout! Err rig that is..
Old 04-07-2008, 06:42 AM   #133 (permalink)
Member # 105834
I got started on the back end, mocha mike had posted some pics, exploded veiws of body panles. I think it was about bulk head config. It was helpfull to see what I was cutting before I was cutting.
Old 04-07-2008, 06:49 AM   #134 (permalink)
Member # 105834
I cut a pie sec. and also folded back the tab on the corner, when you dove tail in you lose over all length. this made up that space.
Old 04-07-2008, 06:53 AM   #135 (permalink)
Member # 105834
I had some 14 gauge already broke in a 90 so it came in handy, then I left it outside til I got the rust to mach.
Old 04-07-2008, 06:57 AM   #136 (permalink)
Member # 105834
Now I need to deal with the Q panle
Old 04-07-2008, 12:14 PM   #137 (permalink)
Banned
Snoopy's Avatar
Member # 5650
Very nice.
Snoopy is offline   Reply With Quote Quick reply to this message
Old 04-07-2008, 06:44 PM   #138 (permalink)
budget76's Avatar
Member # 38264
looks like some S2 tale lights will fit in there nice, if you're planning on running lights that is.
Old 04-07-2008, 06:52 PM   #139 (permalink)
rockthedog's Avatar
Member # 19510
awesome dan!
that last pic is a quality photo
however you should have taken all that crap out of the truck first.
77fj40, 1 TON
530-268-9494
tlca# 12281
semi_budget 1ton build
linking the rear
rockthedog is offline   Reply With Quote Quick reply to this message
Old 04-07-2008, 07:51 PM   #140 (permalink)
Member # 105834
Maybe the oval sealed trailer type light with led lights and rubber gromet.
Old 04-07-2008, 07:52 PM   #141 (permalink)
Member # 105834
Originally Posted by rockthedog View Post
awesome dan!
You are so right But thanks for taking the pic
Old 04-08-2008, 06:26 PM   #142 (permalink)
Member # 105834
Newbie question; dose anyone have a year pref for GM steering column? To swap out for the stock one. It looked like snoopy had an 80s type in on one of his builds. I have a 74 just wondering if the newer one is better?
Old 04-08-2008, 06:34 PM   #143 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
I think the '74 you have will be fine, I used one from an '87 Chebby. I don't think there is that much difference. Had to enlarge the hole in the dash just a bit ~1/8".
Not finished yet, though:
Attachment 364132
Attachment 364133
guidolyons is offline   Reply With Quote Quick reply to this message
Old 04-08-2008, 06:38 PM   #144 (permalink)
Member # 105834
thanks, Did you do anything other than the rag joint?
Old 04-08-2008, 06:47 PM   #145 (permalink)
guidolyons's Avatar
Member # 56050
*edit...not much difference length wise, rag joint spline count is different. Steering column end should be the same 1"-48spl
Depends on the spline count of the steering box you are using. I'm using all the stock Chevy stuff, I got lucky, and the rag joint from the '87 steering column matched the small 30 spline on the '95 IFS PS box I'm using.
I should have some more pics later this week, I hope to get the PS conversion/GM column swap finished up. The actual GM ignition switch lands right on the firewall and might take some trimming to fit, but for now I'm keeping the dash switch. I'm not planning on using the GM ignition switch. I figure 2 ignition switches should keep would be thieves confused
Mocha Mike swapped in a GM column in his S80 also.
What steering box are you using? Hopefully the rag joint splines match, if not, you can get the appropriately splined ujoint from Speedway motors or Summit, Jegs, etc
Originally Posted by speedwaymotors
Mustang II Manual, 9/16"-26 Spline
GM Manual, Mustang II Power, 3/4"-36 Spline
Vega, Corvair GM Rack, 5/8"-36 Spline
Big GM Pre 1978, 13/16"-36 Spline
Small GM P/S 1978 & Later, 3/4"-30 Spline
Wilwood, Sweet Jaguar, MGB, 3/4"-48 Spline
Corvette, Citation Rack, 17MM DD
GM Column, 1"-48 Spline
GM Column, 1" DD
Ididit, Flaming River Column, 1" DD
Attachment 364136
Old 04-08-2008, 07:04 PM   #146 (permalink)
Member # 105834
Thanks guidolyoins, I am some what familiar with 3/4 shaft weld ons, from racing days gone buy. Have you ever rebuilt a column ? , shortend , bushings,etc.?
Old 04-11-2008, 07:24 PM   #147 (permalink)
Member # 105834
Can I get a jury of eight ? , Should I put another light in yes/no , if yes clear / red / amber ?
Old 04-11-2008, 08:33 PM   #148 (permalink)
Buck Dodson's Avatar
Member # 35185
I think it looks good.
Are you planning on a back up light?
Buck Dodson
Chief Scout of Suthern Orygun
A Scout II trapped in an 800 body...
So you think you want to build a 3-link Build
Buck Dodson is offline   Reply With Quote Quick reply to this message
Old 04-11-2008, 10:21 PM   #149 (permalink)
rockthedog's Avatar
Member # 19510
killer dan! .......i'll try to stop by and check it out
77fj40, 1 TON
530-268-9494
tlca# 12281
linking the rear
Old 04-11-2008, 10:34 PM   #150 (permalink)
guidolyons's Avatar
Member # 56050
Tail light looks good.
Does the light you have do tail light, brake light, and turn all in one?
If so, just add 1 back up light on each side, if not, I would add 2 small round below it in the same center line as the brake light. 1 amber (turn) and 1 clear (back up).
