Scout 4-link build - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-07-2009, 08:15 PM   #26 (permalink)
bamacpl's Avatar
Member # 123708
been a while.....I had to go out of town & my house flooded while I was gone & I had to re-format my HD & lost most of my pics.......here are a few pics I took the other day.
bamacpl is offline   Reply With Quote Quick reply to this message
Old 04-07-2009, 08:23 PM   #27 (permalink)
bamacpl's Avatar
Member # 123708
A few more of the links & the rear truss
Old 04-07-2009, 09:11 PM   #28 (permalink)
BLK Scout 800's Avatar
Member # 29630
Send a message via MSN to BLK Scout 800 Send a message via Yahoo to BLK Scout 800
Sick
"Truth is, everybody is going to hurt you; you just gotta find the ones worth suffering for." -Bob Marley
BLK Scout 800 is offline   Reply With Quote Quick reply to this message
Old 04-08-2009, 07:19 AM   #29 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Get some! Is that your TIG work on the links?
I know you are obviously not done, but I'd box the front of the lower link mount on the frame with a chunk of square tubing cut at an angle so there is a "ramp" on it so it doesn't get hung up as easily.
Looks like you have the task well in hand, lookin' good.
guidolyons is offline   Reply With Quote Quick reply to this message
Old 04-08-2009, 08:23 AM   #30 (permalink)
bamacpl's Avatar
Member # 123708
Ya, welded them with a Maxstar 200 STR. Unfortunately, I am far from done!!! I just threw em' up there to check a few things. I am going to add a few gussets, & box all the lower link mounts.....also gotta do some re-work on the rear truss. brake lines, re route exhaust, damn!!!!!! gotta a lot to do!!!
Old 04-18-2009, 05:02 AM   #31 (permalink)
bamacpl's Avatar
Member # 123708
Got the rear all linked up & all mounts tacked(will post pics tonight)
Going to mount the 12" coilovers on the rear as soon as I finish trimming wheel wells! making slow progress!!!! It takes longer than I had anticipated making all the link mounts, shock tabs & hoops etc.....
Old 04-18-2009, 07:45 AM   #32 (permalink)
Buck Dodson's Avatar
Member # 35185
You got that right...
Looks good
Buck Dodson
Chief Scout of Suthern Orygun
A Scout II trapped in an 800 body...
So you think you want to build a 3-link Build
Buck Dodson is offline   Reply With Quote Quick reply to this message
Old 04-18-2009, 06:45 PM   #33 (permalink)
bamacpl's Avatar
Member # 123708
Old 04-20-2009, 08:04 AM   #34 (permalink)
Banned
Snoopy's Avatar
Member # 5650
Please gusset the out of that.
Snoopy is offline   Reply With Quote Quick reply to this message
Old 04-20-2009, 10:51 AM   #35 (permalink)
Member # 13467
Should you not just tack all those mounts in before cycling the suspension and checking for binding?
[QUOTE=Willyswanter's Dad;8398776]I'm trying to find spinner caps that will fit the wheels so when I'm stuck it will look as though I'm still wheeling[/QUOTE]
Ben Segrest is offline   Reply With Quote Quick reply to this message
Old 04-20-2009, 12:32 PM   #36 (permalink)
bamacpl's Avatar
Member # 123708
Ya, they are all just tacked, except for the tabs on the axles.....They should be ok in the current position(hopefully)!!! Rear truss, & frame link mounts are all just tacked.
Gonna mount the hoops & shocks this week, cycle everything & we'll see?
Old 04-20-2009, 05:29 PM   #37 (permalink)
bamacpl's Avatar
Member # 123708
rear coilovers
Mocked up the rear coilovers today......this is what I'm thinking, obviously just mocked up going to add bracing, gussets & gonna connect the two rear hoops with a monte carlo bar.
Old 04-20-2009, 07:28 PM   #38 (permalink)
Member # 5982
I'd notch a 90 in it so it sits on the top corner of the frame rail. Good see you adding gussets to the weak frame.
Was that a comment meant to hurt?
RU Dysfuncational http://thisdysfunctional.org/forum
jdjanda is offline   Reply With Quote Quick reply to this message
Old 04-20-2009, 07:34 PM   #39 (permalink)
bamacpl's Avatar
Member # 123708
90' for sure!!!!
Old 04-20-2009, 10:04 PM   #40 (permalink)
Member # 29630
Nothin says hardcore build like huggies in the background
J/K Sweet build man
Old 04-21-2009, 04:56 AM   #41 (permalink)
bamacpl's Avatar
Member # 123708
LOL!!!!!!!! Ya, I noticed that too!!! That's the wifes fail safe way for me to take out the garbage.....throw it where it's in my way & it's guaranteed to get taken out.
Old 04-21-2009, 07:47 AM   #42 (permalink)
Banned
Snoopy's Avatar
Member # 5650
Huggies...
Old 04-21-2009, 08:33 AM   #43 (permalink)
bamacpl's Avatar
Member # 123708
snoopy.....I know you gotta have some huggies laying around your shop somewhere......
Old 04-21-2009, 04:30 PM   #44 (permalink)
Banned
Snoopy's Avatar
Member # 5650
One or two.
Old 04-22-2009, 08:23 AM   #45 (permalink)
Member # 125028
Thumbs up
Madman fabrication with those HUGGIES their! They are great for soaking up spills!!!! Looks good...
Rokkrawler is offline   Reply With Quote Quick reply to this message
Old 04-22-2009, 01:17 PM   #46 (permalink)
Member # 1956
Is that a stock Scout II width rear axle?
What size tires you running?
Jerry Brown: If Trump is elected, we'll build a wall around California! MAGA!
Shadow man is offline   Reply With Quote Quick reply to this message
Old 04-22-2009, 01:36 PM   #47 (permalink)
bamacpl's Avatar
Member # 123708
ya, stock width.....35" tires. There's plenty of room for the coilovers outside the frame rails, gonna run some wheel spacers just to help increase with stability. We'll see?
Old 05-05-2009, 07:26 PM   #48 (permalink)
bamacpl's Avatar
Member # 123708
2" wheel spacers
Where would be a good place to get some 2" wheel spacers?
Old 05-05-2009, 07:57 PM   #49 (permalink)
chris fresh's Avatar
Member # 69678
lotta options/thickness's on ebay.bought a set of 1.5's for 8 lug chebby for 90 clams shipped
78 SII very healthy 327,th-350,np205,35''boggers
71 800B LT-1,400,203/205,FF14,d-60,42'' rockers on beadlocks
To my great friend rob,RIP buddy we'll never forget you.
chris fresh is offline   Reply With Quote Quick reply to this message
Old 06-01-2009, 05:28 AM   #50 (permalink)
bamacpl's Avatar
Member # 123708
FINISHED!!!!!
Drove it around a lil yesterday. The rear tires rub the coilovers a little, the wheel spacers should be here in a week or two? As of now that seems to be the only problem I've encountered so far.......As soon as the spacers get here I'm gonna twist it up a little bit & I'll post some pics & numbers for those interested.
