Cummins R2.8 Trooper 2001 (new member) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-25-2019, 10:24 PM   #1 (permalink)
Member # 864786
Hi everyone!
New to this group but appreciate the value of a good forum.
Curious what the Isuzu experts might be able to tell me. Been looking for the right rig for a Cummins R2.8 build and just found it. Had narrowed it down to the Trooper and FJ80, finally found a Trooper with a good body and interior.
Couple things I'm trying to figure out (Trooper is in transit to me) on the 2001
What is the axle width?
Is the transfer case any good?
I don't really want the auto. Any known manual swaps that work well where I might not have to change T-case and drivelines?
Passenger side offset on the front driveline, correct?
What is the rear axle in the 2001? ratio?
It sounds like the rear axle is pretty good, so if I can find the right trans and passenger side t-case combo (Toyota R150?) I might be able to keep the Isuzu front and rear axles. Need to figure out what gear ratios would work.
AvalancheAK is offline   Reply With Quote Quick reply to this message
Old 02-28-2019, 09:07 AM   #2 (permalink)
Member # 864786
Isuzu must be a quiet corner of the forum?
Picking up the Troop today and will get a measuring tape on it.
Still curious on axle ratio. Ive heard 4.3, 4.5. Not sure what it should be on a 2001 Auto.
Are these transfer cases generally solid? Ive heard the manual trans is good. Is the t-case the same between the auto and the manual and an Isuzu manual trans could be swapped easily without changing t-case and drivelines? (when I converted my Ram from 48RE auto to G56 manual the t-case input shaft was different and the whole case and thus drivelines was 2 rearward)
Old 02-28-2019, 10:51 AM   #3 (permalink)
Member # 16384
Send a message via AIM to paulevans76
Case is considered solid, same for manual or auto
Width is 63"ish.
Auto is trash in these, 4L30e. No way behind the R2.8. The manual that came in these is the AR5, a decent unit, which can be found, but autos were way more common.
Axle ratio should be 4.30 in the 98+, same for manual and auto.
91 Isuzu Trooper Y-link/coil SAS
35" Grabber X3's, tera low, d44's: RCV's, OX, detroit, 5.38's
paulevans76 is offline   Reply With Quote Quick reply to this message
Old 02-28-2019, 04:32 PM   #4 (permalink)
Member # 864786
Thank you!
Some good info to move forward
Picked her up this morning. Bought her sight unseen. 120K on it. Body and interior is really nice, just dirty. Starter is stuck on, which I knew when purchasing. Going to try to jack up motor and replace starter I think just to see how the rig handles and drive it a bit (if the rest works). Undercarriage is jam packed full of mud. . Going to take some serious pressure washing.
Old 02-28-2019, 11:43 PM   #5 (permalink)
Member # 864786
Going to do a little browsing for an AR5 manual.
Is there another version of the T-case that has a 2wd option? Mine is the full time 4x4 torque lock unit. I could run hubs in free but...
Better pic
Old 03-01-2019, 05:33 AM   #6 (permalink)
Member # 685034
wish you were not so far away--i have a trooper with the ar5 that has a bad engine and a beat body. i'm in southwest NC.
Kriptonite is offline   Reply With Quote Quick reply to this message
Old 03-01-2019, 09:47 AM   #7 (permalink)
Member # 864786
I can ship it. We have to ship everything living up here anyway. Is it a full time 4wd t-case? How many miles on the trans? Id have to confirm the 2.8 can be adapted to the AR5, but if so that would be a good option.
Old 03-01-2019, 11:31 AM   #8 (permalink)
Member # 685034
235000 miles on the trans and tcase. part time case. 2hi 4hi 4low v6 engine.
1996 year model you might want to check and make sure the ar5 came in that year.
Old 03-02-2019, 08:43 AM   #9 (permalink)
Member # 864786
Looks like 1998 onward..
Old 03-03-2019, 07:06 AM   #10 (permalink)
Member # 16384
I had a nice reply typed up and lost it.
1st off, apologies, I forgot about the torque on demand (TOD) cases that came in the later auto models. The case is robust but no real 2wd option I guess. They have a vacuum actuated front axle, so that's some other bits to delete/replace.
The MUA5 manual in the pre 98 models is just as tough as the AR5, as long as the owner kept motor oil in it and the case as RX'ed and not gear oil. The MUA5 has an integrated tcase, and the models with the auto had an adapter to a removable version of the unit. I believe the AR5 can with that removable version behind it.
The MUA5 would likely hold up as well as the AR5 and came with a few bell housing patterns, one of which is the gm fwd 60* pattern, which may be more easily adapted. OD in the MUA5 is .81, close to the trooper version AR5.
If you don't need the drivetrain to be Isuzu parts, you probably have way more easier options. Do you need it to be manual, are you keeping the IFS or swapping in a solid axle? What is the main purpose of the rig going to be?
There's a lot of manual swap info at planetisuzoo.com forums, they are much more active than this section.
Old 03-03-2019, 11:50 AM   #11 (permalink)
Member # 864786
Thanks for the info. Ill check out that forum.
Id like it to be a manual, but havent fully ruled out an auto yet either. If I go auto Id probably go with a 6L80E with a nice tall overdrive. One of the problems with most of the manuals Im finding is that overdrive is going to be pretty low for the diesel.
My preference is to retain the IFS, and thus a passenger side transfer case like Isuzu or Toyota. If I end up going to a solid axle then Id have all sorts of options and probably end up with a whole Jeep drivetrain.
Rig is going to be a daily driver, road trip, Expedition, and mild off road rig. Id like to be able to hit 65 or 70 without the Cummins screaming. Cummins has a nice gear ratio calculator for transmission sizing.
Old 03-04-2019, 08:20 AM   #12 (permalink)
Member # 16384
Roger. I think adapting the 6l80 would be awesome, but potentially expensive and a bit of work. They seem to like to communicate only with their original generation motors, but I'm sure the aftermarket is coming around. The 4l60/700r4 is only a 4 speed but the OD is .7. AW4/A340 is like .75.
Old 03-08-2019, 11:32 AM   #13 (permalink)
Member # 864786
Got a new starter in today, which was “fun”. Rig starts right up, engine seems to run well and doesn’t have any clatter. The oddities:
Engine won’t turn off when I turn the key off. Literally turn the key off and take it out and it keeps running. It shuts off the stereo and a couple other things, but not the gauges/fuel/ECU. In park, parking brake on, headlights off, even tried opening door. Had to pull ECU fuse, then it’s all good and I can put fuse back a few seconds later. Some relay seems to be staying latched somewhere...
4WD is not working. Seems like a have a tiny bit of traction on the front but as soon as much torque is applied there is nothing. Tried 4WD Auto, low range, etc. “check” will blink when it’s in 4WD auto for a while. Not sure exactly how the TOD is supposed to work but.. Vaccum line to the axle somewhere to check?
Weird wire bridge inside in the fuse box - see pic 1
Wire spliced into ECU harness that looks like it could be connected to battery but isn’t - pic 2/3/4
Any known fixes or bypasses (security??) that these wires might be doing? The truck has aftermarket non RFID keys which makes me things the security is bypassed somehow..
Thanks!!
Similar Threads
1964 Volvo Amazon r2.8 Cummins 5.9LJ Vehicles and Trailers For Sale 1 01-25-2019 09:33 AM
2001 cummins Dually Project Ideas? Cool Guy Levi Dodge 27 04-03-2013 06:18 PM
piggy HGTD: can't figure out shit rolls downhill, hilarity ensues kastein General Chit-Chat 70 08-19-2012 09:50 PM
Trooper Pulls Over Mayor, Mayor Pulls Over Trooper - WTF pepe General Chit-Chat 39 02-02-2012 02:51 PM
test redcheetah Testing 1 01-13-2012 06:38 PM
