TANK 1 TON XJ - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-27-2015, 05:52 PM   #76 (permalink)
Member # 481602
Originally Posted by nickjc13 View Post
your still running leaves in the rear right? are you still running stock gas tank? I have a dana 70 im looking to install and worried about clearance with the gas tank.
Yes still on leafs and yes stock gas tank. The rear is stretched a little just barely clears the cover
t_ank is offline   Reply With Quote Quick reply to this message
Old 10-27-2015, 05:53 PM   #77 (permalink)
Member # 481602
Well the other night got final welding on the hoops and mounts. Just need to do cross bar and some paint
Old 11-07-2015, 09:44 PM   #78 (permalink)
Member # 519137
I read back in the thread and you said that you're running spacers but your front axle has been narrowed. My question is what BS are you running on your new beadlock rims? Are you still running spacers? Are you running spacers all around or just the front? I'm running a 60/14 combo and I want to keep the narrowest width as possible, I'm thinking 17x9 rims with 39x13.5x17 tires (chewed up rollers I got for free). I'm basically looking to replicate your setup.
Greeny806 is offline   Reply With Quote Quick reply to this message
Old 11-11-2015, 03:36 PM   #79 (permalink)
Member # 589009
do you have more pictures of the shock hoop install. started my build a few months ago and pretty much going to have the same set up as you. not sure how to go about setting up the front shocks. and how much did you stretch it? looks good!
1-Ton_XJ is offline   Reply With Quote Quick reply to this message
Old 11-11-2015, 05:20 PM   #80 (permalink)
Member # 158281
Build looks great! Always loved a full body XJ with tons and 40's.
I would suggest a cross brace for the shock hoops though. Keep it from shifting too much force on a single hoop. I'm no expert, just opinion based! Look forward to more
M&M Offroad chassis, LS1,TH350, Atlas, Tons, 42's
hitman_1b is offline   Reply With Quote Quick reply to this message
Old 11-12-2015, 09:24 AM   #81 (permalink)
Member # 481602
Thanks man I like the full body of it too. I put a cross brace in I'll snag a pic one day.
Old 11-12-2015, 09:26 AM   #82 (permalink)
Member # 481602
I was originally running 2in spacers when I was using my build wheel and tire combo. Cuz he had a big backspacing. I am not currently using spacers. And have not check the backspacing on these wheels. I'll check that out for ya when I take the wheels of this weekend.
Old 11-12-2015, 09:36 AM   #83 (permalink)
Member # 481602
No on hand I'll be painting everything this week I'll grab a few pictures.
Set your axle and jeep to ride height.
Decide how much up and down travel you want
Measure to where you like your hoops to be with your up and down travel and ride height in mind
Pick your shock from your measurments and needs
Buy your material Dom and mounts unless your making them.
You'll need to cut into the inner fender well also for hoop and shock clearance
Tac weld everything and do a little flexing with it make sure things clear don't bind ect
It's stretched over stock probably like 2-3 in up front
Old 11-12-2015, 09:38 AM   #84 (permalink)
Member # 481602
Jeep work good this weekend
Old 11-12-2015, 12:14 PM   #85 (permalink)
Member # 589009
Awesome man! Thanks for the info! Looks awesome! Those 14"? I have 2.0 14" radflos
Old 11-12-2015, 12:16 PM   #86 (permalink)
Member # 481602
These are 16in fox 2.0. I got a good deal on them. Only have 4 up as that all would allow for clearance but it works well
Old 11-12-2015, 12:24 PM   #87 (permalink)
Member # 589009
Ok. Like the build! Hoping to get going on mine soon! Seeing yours all done got me motivated again lol
Old 11-12-2015, 07:56 PM   #88 (permalink)
Member # 481602
Get at it and have fun with it
