4 door xj with 60/70 with coilovers - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-14-2016, 06:03 PM   #1 (permalink)
nickjc13's Avatar
Member # 89107
Well, I've lurked around here for a few years looking at all of the different builds. I finally decided to step it up on my build. Before I was running a trussed locked/d30 and 8.8 with bds 4 link in the front and bds leaf springs in the rear with 36" iroks.
Here are the Plans:
Front coilovers
79 ford kingpin 60 with 1 Reid knuckle
5:13 gears
Welded
35 spline outers
35 spline Yukon hardcore locking hubs
Artec full truss with ram mount
Trac bar mount
Psc double ended full hydro
Disc brake brackets and rotors setup to clear 15" rims (even though I will no longer be using 15s)
79 ford e350 Dana 70 rear.
Diy disc brake brackets and rotors/calipers setup to clear 15" rims
5:13 gears
Detroit locker
Yukon cut to fit chromoly shafts
Leaf spring swap
Anti wrap
Tires:
38.5 maxis creepy crawlers
16" stazwork double beadlocks
Inside:
Cage
Corbeau rs seats
Pics to follow
nickjc13 is offline   Reply With Quote Quick reply to this message
Old 01-14-2016, 09:44 PM   #2 (permalink)
Member # 565306
why a 70 rear instead of a 14 bolt?
Baláke is offline   Reply With Quote Quick reply to this message
Old 01-14-2016, 10:34 PM   #3 (permalink)
Member # 166467
Sounds like he got matching axles out of a donor vehicle
ranger4.0 is offline   Reply With Quote Quick reply to this message
Old 01-14-2016, 11:05 PM   #4 (permalink)
nickjc13's Avatar
Member # 89107
I bought them from a friend who bought them from a friend who ran them. Hence why only one Reid. But now knowing what I know I should have sold the rear end or trashed it and got a 60. The original owner liked to mud ride and ride through a lot of water. One shaft came out like butter the other shaft was hell. After trying everything I could, we cut the center pin out of the carrier. Put a rail road iron through the other side and whaled on it. Shaft wouldn't come out. Heated up, still nothing, ended up having to cut out the carrier and then cutting through the carrier/bearing/ and shaft just to get the main part of the shaft out. Then once I got the shaft out, I could not get the spindle nut off of that side. The spindle was mushroomed perfectly. I hear this can be from running the wrong hubs but I am not sure. I had to grind the mushroom down to get the spindle nut off. Then once I got that i had to pay someone to cut off the bad part of the spindle in order to spin the new nut on. I am still looking for a thinner spindle nut to possibly double nut the spindle.
Old 01-15-2016, 05:24 PM   #5 (permalink)
nickjc13's Avatar
Member # 89107
I have to get the pics off the back up hard drive but here are a few before and during pics .
Before the rebuild
Every Part with the exception of rims/tires for the rebuild:
Before the tear down:
Old 01-15-2016, 05:32 PM   #6 (permalink)
nickjc13's Avatar
Member # 89107
Seats and Cage:
Old 01-15-2016, 05:36 PM   #7 (permalink)
nickjc13's Avatar
Member # 89107
Setting up the rear:
Old 01-15-2016, 05:38 PM   #8 (permalink)
Member # 584881
Looks good Nick!!!!
PharmD2B31 is offline   Reply With Quote Quick reply to this message
Old 01-15-2016, 05:39 PM   #9 (permalink)
Member # 584881
I would have done a Dana 60 or a 14 bolt. Probably the Dana 60 due to locker choices. 😁
Old 01-15-2016, 05:43 PM   #10 (permalink)
nickjc13's Avatar
Member # 89107
I will have to re organize this thread once I can get on a computer. Too hard to do it on an iPad. But here is a teaser front end pic.
Old 03-04-2016, 08:58 AM   #11 (permalink)
Member # 95849
sorry for the thread hijack, but how do you like the BDS 4 link front??
tjbuggie is offline   Reply With Quote Quick reply to this message
Old 03-08-2016, 04:49 PM   #12 (permalink)
nickjc13's Avatar
Member # 89107
I like it all but the fact that the front uppers still use a bushing mounted on the axle like the factory. It has made it a pain in the ass. And I hate that I still have to run a trac bar. Id much rather be fully triangulated but I did not want to have to build a crossmember so this was the next best option.
I will be finishing this thread very soon. Jeep is almost complete.
Old 03-08-2016, 04:52 PM   #13 (permalink)
nickjc13's Avatar
Member # 89107
Originally Posted by PharmD2B31 View Post
I would have done a Dana 60 or a 14 bolt. Probably the Dana 60 due to locker choices. ��
quit being a smart ass. Ha Just because you know the problems I have been having with this axle.
Old 04-08-2016, 11:14 AM   #14 (permalink)
nickjc13's Avatar
Member # 89107
is anyone interested in seeing the rest of this build? It is basically finished and I brought it to Choccoloco Mountain for a shake down run. If there is interest I will do the build thread.
Old 04-08-2016, 11:32 AM   #15 (permalink)
nickjc13's Avatar
Member # 89107
Old 04-09-2016, 10:36 AM   #16 (permalink)
Member # 565306
I wanna see how the 4 link fits up front
Old 04-09-2016, 01:22 PM   #17 (permalink)
Member # 151814
Post it up lots of people read the threads but never comment lots of people lurk here to see 1 ton jeeps.
a1racer is offline   Reply With Quote Quick reply to this message
Old 05-03-2016, 09:35 AM   #18 (permalink)
Member # 485946
post up some more pictures
94cheapjeep is offline   Reply With Quote Quick reply to this message
Old 05-06-2016, 08:55 PM   #19 (permalink)
Member # 621857
I'm in the process of gathering parts to do a 94 Cherokee. I'd like to see how you did yours.
Bamaguy84 is offline   Reply With Quote Quick reply to this message
Old 05-13-2016, 11:11 PM   #20 (permalink)
Member # 227791
Nice work Nick.
Looks like it came out pretty good. Post up some more pictures of your build. More pictures are always good. Helps people develop their own idea how to get something done.
AKIQPilot is offline   Reply With Quote Quick reply to this message
Old 05-21-2016, 03:07 PM   #21 (permalink)
CherryXJ's Avatar
Member # 657882
Post it up! I'd love to see it as I am dreaming of my 4-link but not sure how I am going to do it yet
CherryXJ is offline   Reply With Quote Quick reply to this message
Old 05-21-2016, 04:03 PM   #22 (permalink)
Member # 400633
Really want to see how you did the coilovers.
CobraMarty is offline   Reply With Quote Quick reply to this message
Old 06-10-2016, 09:09 AM   #23 (permalink)
nickjc13's Avatar
Member # 89107
I will post some later today, I just got back from my honeymoon so that's the reason why I haven't responded.
Old 08-17-2018, 07:12 PM   #24 (permalink)
Member # 556290
What happened to this thread? I really wanna see the coil mounts and link setup
jeepman2250 is offline   Reply With Quote Quick reply to this message
Old 11-05-2019, 10:12 PM   #25 (permalink)
nickjc13's Avatar
Member # 89107
I honestly forgot about this for the longest time. I can post pictures if people would like to see it.
HQ-Offroad Contact- 228-233-5175
Rock Krawler Teraflex RCV PSC Yukon Poison Spyder Ruffstuff Radflo FOX BFGoodrich Nitto MAXXIS PRP Nitro Currie OX ARB Detroit Rigid KING Raceline Trailready Dirty Life CTM Dynatrack G2 Wilwood TMR and many other brands. We can get our hands on pretty much everything!
