Waggy D44 swap - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-01-2019, 12:02 PM   #1 (permalink)
GFY Racing's Avatar
Member # 136091
Location: Back in the good 'ol U S of A after three long deployements!
Waggy D44 swap
Figured I'd contribute to this section. Nothing crazy, but it was all built in my garage. I picked up a waggy 44 from CL a couple of years ago and finally got around to finishing the swap recently. There are inherently two issues with using this housing.
1. The bolt pattern needs to be converted to a 5x4.5
2. The housing is setup for leaf springs. The main issue here is the caster angle is negative when setup for the XJ.
My goal was to swap this housing into the XJ using the ruffstuff 3 link heim kit and 1 ton steering. This necessitated building a crossmemeber.
New to me housing
Cleaning off factory control arm mounts. The passenger side came off without any tearing of the unibody. The drivers side, not so much...
First attempt at building a crossmember
Welding nuts to the backside of the frame stiffeners. I should have just done all 4 on each side instead of trusting the factory tapped holes, so now I have that issue to deal with.
Fighting for the right for SORRY PIECES OF SHIT to protest at soldier's funerals.
1989 XJ on 35s Work in Progress
GFY Racing is offline   Reply With Quote Quick reply to this message
Old 02-01-2019, 12:16 PM   #2 (permalink)
GFY Racing's Avatar
Member # 136091
Mocking up the housing. Spring perches have to be mounted as far out as possible to line up with the springs.
MASSIVE 1.25" heims from ruffstuff. Way overkill for a D44.
Old 02-01-2019, 12:24 PM   #3 (permalink)
GFY Racing's Avatar
Member # 136091
After mocking up the housing, it was obvious the inner Cs would have to be turned. Let the good times begin!
Cutting the factory welds. Took quite a while. I don't remember how many disks we went through.
Tried using the BFH to remove the Cs. Finally my cousin had a brilliant idea of using some 0.25 plate and the 20 ton HF press. Worked
Inner Cs removed.
Cs tacked back on to mock it up again.
Finished welding the Cs back on. Took 3 or 4 passes if I remember correctly.
Caster ended up right around 5.5-6 degrees.
Old 02-01-2019, 12:33 PM   #4 (permalink)
GFY Racing's Avatar
Member # 136091
While I was working on getting the axle ready for the XJ, I decided to use the kit from ECGS to convert the axle to 5x4.5. The kit is complete and includes everything from the spindles out, not including the hubs.
I was working upstairs when I heard the fedex truck pull up. The driver apparently wasn't having a good day and droped the box at the front door. By the time I made it downstairs he was already gone. This is what I was left with.
I got on the phone right away with ECGS. Those guys have badass customer service. They sent out another order the same day.
Once the new, unfucked, parts came in I was able to get the axle mocked up with the tires.
Old 02-01-2019, 12:37 PM   #5 (permalink)
GFY Racing's Avatar
Member # 136091
More mockup pictures.
Old 02-01-2019, 08:46 PM   #6 (permalink)
Member # 53453
Too bad you're so far away, I've got a set of Yukon 4340 shafts and Superjoints for that axle, and I'd damn near give them to you, because I'm never going to use them.
DirtyComanche is offline   Reply With Quote Quick reply to this message
Old 02-02-2019, 05:47 AM   #7 (permalink)
GFY Racing's Avatar
Member # 136091
Waggy D44 swap
How much would shipping be to Leander TX?
Old 02-02-2019, 06:41 AM   #8 (permalink)
GFY Racing's Avatar
Member # 136091
Decided to rework the crossmember. Ended up cutting off the mounting plates on the sides. Instead of flush mounting with the crossmember, I notched the crossmember about 1/3 of the way down at a slight angle.
I notched the control arm mounts to give another inch of clearance. Because the heims are so large, I ended up notching the crossmember as well. Turned out better than I expected. Nevermind the shitty tack welds.
Nearly finished aside from paint and the plate for the upper control arm mount. Between notching the transmission mount and the lower control arm mounts, I gained 2" of clearance for the lower arms.
Random shot of the tierod. I used ruffstuff's y-link kit and flipped the tierod. Instead of re-reaming the taper, I used their tapered inserts and drilled the knuckles out. The knuckles are drilled out to 7/8". I borrowed a buddies 1/2" corded drill and easily drilled them out. None of this "oh boo hoo, I nearly broke my arm when the bit caught" that others love to whine about.
Old 02-02-2019, 06:47 AM   #9 (permalink)
GFY Racing's Avatar
Member # 136091
Final flex shots. Currently there 10" of travel before the springs start to drop out. I'm hoping to find some dual rate TJ springs to use to give some more droop eventually, but it's not a priority right now. For the time being I'll just run some limit straps.
Not much flex in the rear currently. I'm running brand new 3.5" RE springs with their 1" shackle, so with some more weight and breaking them in they should do a bit better.
This is the most recent picture of the front end. As it sits now, both the drag link and track bar are parallel.
More trimming is needed.
Old 02-11-2019, 08:09 AM   #10 (permalink)
GFY Racing's Avatar
Member # 136091
One issue I'm running into is turning radius. I had to mount the driver side link a little further out due to interference with the housing. As a result, the tire contacts the link before hitting the steering stop. I've temporarily addressed this by using a longer bolt until I have time to come up with a better solution.
Driver side at full lock
Passenger side at full lock
Interestingly the passenger side is hitting the internal stering stop before the stop on the knuckle or hitting the link, giving me less turning radius when making left hand turns.
Old 02-13-2019, 10:35 AM   #11 (permalink)
Member # 183091
I’m curious to see what you think of the RE 3.5” springs. I’ve been thinking of getting some of those with a 2” shackle.
89 XJ
Whitesnake is offline   Reply With Quote Quick reply to this message
Old 02-13-2019, 01:36 PM   #12 (permalink)
GFY Racing's Avatar
Member # 136091
I've only put about 50 miles on them so far, none of which are offroad. I'll report back when I get a chance. But that being said, no complaints aside from the obvious lack of flex. I'm hoping that will get a bit better as they break in.
Old 02-13-2019, 01:43 PM   #13 (permalink)
the freeak's Avatar
Member # 41185
Attachment 2919382
Attachment 2919384
Is your pitman arm centered when the steering box is centered?
If not, center it, and you'll probably need a longer drag link, and a longer (eye to eye) pitman to accommodate the new steering geometry.
EDIT- you can file out the "keys" on the pitman arm to allow clocking it on the sector shaft.
Here's a link you may find helpful: https://www.pirate4x4.com/forum/gene...reference.html
RIP SCREWZER2
the freeak is offline   Reply With Quote Quick reply to this message
Old 02-13-2019, 01:47 PM   #14 (permalink)
GFY Racing's Avatar
Member # 136091
I know it SHOULD be, but won't hurt to double check. Thanks for the input.
Old 02-13-2019, 02:02 PM   #15 (permalink)
whitneyj's Avatar
Member # 135947
The rear will flex a lot better if you were able to move the shackle to a better angle. I had a very similar setup in 2009 and ended up cutting out the factory rear shackle box and building my own that moved the shackle bolt forward. Made all the difference in the world. I know there are companies that offer bolt on shackle relocation kits as well, but that's not as fun
Swap looks good.
Place banana in your ear.
Observe that there are no alligators around.
Conclude bananas placed in ears keep alligators away.
whitneyj is offline   Reply With Quote Quick reply to this message
Old 02-13-2019, 02:37 PM   #16 (permalink)
GFY Racing's Avatar
Member # 136091
Thanks man. I'm hoping to address that in the next few months. Right now I've got way to many projects going on so it'll have to suffice. I'm sure I'll find some time this summer when it's hot enough to make working on it painful
Old 02-27-2019, 10:09 AM   #17 (permalink)
Member # 548137
looks like you pushed the axle forward about 2 inches but used centered spring mounts. your coils bowed at all?
denverd1 is offline   Reply With Quote Quick reply to this message
Old 03-01-2019, 08:24 PM   #18 (permalink)
GFY Racing's Avatar
Member # 136091
No, the coils are as straight as they were before the axle swap.
Old 03-01-2019, 11:49 PM   #19 (permalink)
Member # 548137
What tire size bro? 37?
Sent from my SAMSUNG-SM-G930A using Tapatalk
Old 03-02-2019, 08:37 AM   #20 (permalink)
GFY Racing's Avatar
Member # 136091
35s
Unfortunately itís going to be a bit before I can actually wheel it. The motor has developed a knock so the oil pan is getting dropped this weekend
Old 03-15-2019, 04:17 AM   #21 (permalink)
Member # 863064
You Have any more updates on your project?
Boogs1970 is offline   Reply With Quote Quick reply to this message
Old 04-01-2019, 05:19 AM   #22 (permalink)
GFY Racing's Avatar
Member # 136091
Not on the D44. It's sidelined due to a small hicup in the engine break in. This is 75 miles into it. I'll be updating my other thread in non hardcore.
Name:  rod bearings.jpg
Old 04-01-2019, 10:32 AM   #23 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Eeek. What are you thinking caused the premature wear?
Action Fab is offline   Reply With Quote Quick reply to this message
Old 04-01-2019, 10:35 AM   #24 (permalink)
GFY Racing's Avatar
Member # 136091
Best guess is oil starvation. I haven't torn it apart anymore than this, and really don't plan to. Looking into other power options at this point.
Old 04-03-2019, 07:42 PM   #25 (permalink)
GFY Racing's Avatar
Member # 136091
For anyone interested in the motor fiasco, I picked up an LQ4 from an 05 H2 that will be here in a week or so. I'll be updating my build thread in the non-hardcore section.
Similar Threads
Ultimate Wrangler Build Ups and Swaps thread gtxracer Jeep - Hardcore Tech 364 09-28-2017 04:54 AM
Barnes 4WD Solid Axle Swap Kits Barnes 4wd Suspension 46 05-02-2017 06:05 PM
79 waggy D44 front into a 86cj7 steering questions CutterN55 Jeep - Non Hardcore 2 03-17-2014 10:55 PM
Front d44 from a waggy into a ZJ Riot1987 Jeep - Cherokee 11 12-06-2013 06:26 AM
Waggy D44 Ball Joint Issue - Camber Sleeve CaddMan Jeep - Non Hardcore 0 03-23-2012 02:22 PM
