Member # 576794
4.7 stroker question/flywheel and clutch question
Ok, guys, I hope someone can point me to the right direction. I am starting with a 4.0 engine from a 2001 XJ. I want to stroke it so I'm planning on using the 4.2 crank and rods. I will be mating it to a AX15 I have sitting in the shop from a 1989 XJ. I know there are different flywheels (internal vs. externally balanced) so which one should I use? Same for the clutch and pressure plate...Do I use the ones for the 2001 engine or for the 1989 AX15? I know I have to use the earlier pilot bearing because the shaft size is smaller. Just not sure with the rest of it. Thanks for any help.
Member # 77571
You want the FW from the 2001. It has the notches for the crank sensor whereas the 4.2 does not. Clutch would be the 4.0 external slave also. 94ish up.
You might want to check further. The 4.2 crank yes but the shorter 4.2 rods no. Head over to jeepstrokers.org and post up. You will find plenty of good info on building your stroker right. The Guru is Russ Pottenger. He has the parts and knowledge you want. https://www.facebook.com/Bishop-Bueh...8948051907539/ His contact info is all over strokers if your not a FB fan.
Sent with smoke signal. Last edited by jsawduste; 10-30-2019 at 09:55 AM. |
Sponsored Links |
Member # 77571
Russ Pottenger
Bishop-Buehl Racing Engines Work (626) 967-1000 Cell (626) 673-2203 Email/PayPal: [email protected]
Sent with smoke signal. |
Member # 576794
Thanks, I really appreciate it. I'll check him out. Just to clarify on the clutch though you're saying I should use the 94 up clutch even though my AX15 is 89 with internal slave? Thanks again, I'll head over to jeepstrokers and FB to check him out.
Member # 77571
My bad, thought the bellhousing/clutch was same vintage as the engine. Reread and your using the 89 Internal slave. seriously consider upgrading to external.
Member # 576794
Thanks,
I've looked at that. I may go ahead and do it. I was going to keep the internal setup because the OEM mopar units seem to have a good track record and the cheap ones crap out really quick. Since no one seems to carry the mopar unit anymore I think I'll just save face and change to external slave. |
Thread Tools | |
Display Modes | |
