Telltale signs of Teralow 4:1 case failure? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-20-2019, 03:33 AM   #1 (permalink)
Member # 118010
'98 XJ, 2.5, AX5, Teralow case with 4:1and 2 low. When you drive it there is the occasional slip, not like clutch slip, more like gears losing mesh for a split second slip but no grinding noise when said slip occurs. I wasn't aware of Teralow case issues as a whole, ie the planetary gears/cage that seemed to plague so many until after I got this thing and the slippage surfaced and I started searching.
So is what I'm experiencing and early sign of Teralow failure or some other unknown?
[I]Yolk=the yellow part of an egg, not anything rig related [/I]:shaking:
makemeknowit is offline   Reply With Quote Quick reply to this message
Old 11-21-2019, 10:00 PM   #2 (permalink)
Member # 159257
Why not pull it, take it apart and check it out? You could remove just the back half of the case if you didn’t want to pull it and just want to check things out.
[QUOTE=trampas] Let's all gather round and have us a nice e-fight :laughing: [/QUOTE]
H8DWINGS is offline   Reply With Quote Quick reply to this message
Old 11-22-2019, 04:39 AM   #3 (permalink)
Member # 118010
I will when I can get it back in the garage. Ftoy on jackstands right now until I get rear diff back in next week in time for last ride on toy axles. Then it's off to the shop for ton swap.
Old 11-22-2019, 10:23 AM   #4 (permalink)
freerider15's Avatar
Member # 23795
Send a message via AIM to freerider15
The telltale sign is that it's a Teralow.
I've yet to see one still working that wasn't sounding like it wasn't having issues.
It's not a matter of if, but when with those things.
XJ Based Buggy: 42's, Tons, Full Hydro, ORI's and a fukkton of tube...
freerider15 is offline   Reply With Quote Quick reply to this message
Old 12-04-2019, 03:59 PM   #5 (permalink)
Member # 7624
Send a message via AIM to offroadman83
According to my buddy running one with a 4 cylinder.......a telltale sign of one failing is buying one............
2000 tj with stuff
offroadman83 is offline   Reply With Quote Quick reply to this message
Old 12-04-2019, 04:04 PM   #6 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Have you run it second gear? If so it's fucked. They used a bronze bushing in the planetary that was not rated for enough RPM.
If yours are anything like mine. It will make noise right out of the crate and will fail without giving notice while on the first trail of a place that's further than you've ever traveled to get to.
Action Fab is offline   Reply With Quote Quick reply to this message
