Old Skool CJ Build - Page 7 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-12-2011, 10:22 AM   #151 (permalink)
Member # 203189
Originally Posted by yjwrangler95 View Post
I finally got into the garage to work on the jeep last night, the frame is 26, skidplate and lower link mounts at 23. That is with 5 inches of up travel in the front, 7ish in the rear, 111.5" wheel base, and 43 SX's. I have zero approach and departure angle's with the wheelbase and tires. The top of the cage at the highest point is 83 and the lowest is 80. My cage is higher at the Apillar and slopes rearward a bit. Its not a low rider at all, but it is 85" wide in the rear and 87" in the front. Its just a big jeep that look proportional.
I got the frame plates cleaned up and tacked/welded. Have a ton of welding to do. Hopefully I will have some more pics up soon with some tech....
thanks for the measurements. I just got my frame stretched 12". Im reworking my front truss on one side for some added clearance. I think my frame is going to end up similar height to yours and very similar build. Just a big ass jeep that looks right. lol. Nice build and your miles ahead of me. I have motor mounts coming in this week and should get all the drive train in and really start to get the 4 link set up. Looks like 112-114" for wheel base right now.
dirtywrench1 is offline   Reply With Quote Quick reply to this message
Old 12-12-2011, 11:16 AM   #152 (permalink)
Member # 63526
Huber, those frame plates are !! I cant wait to hear that 5.3 spin those tires up snot rocket hill.
When's the cage due back? I could prolly get up the hill in the next couple weeks to help out with time off coming over the holidays.
Bizeeb65 is offline   Reply With Quote Quick reply to this message
Old 12-13-2011, 06:01 AM   #153 (permalink)
quaylefarmer's Avatar
Member # 19355
I would burn in those frame plates with the flux core set on STUN
The Bolt-On Billionaire
quaylefarmer is offline   Reply With Quote Quick reply to this message
Old 12-13-2011, 11:42 AM   #154 (permalink)
yjwrangler95's Avatar
Member # 81277
gotta purfact three phase welder setup I thank i wood use enstad....
My Build:
yjwrangler95 is offline   Reply With Quote Quick reply to this message
Old 12-13-2011, 07:35 PM   #155 (permalink)
Member # 157647
And I'm the one that ate to many paint chips as a kid?
Clowns to the left of me and jokers to the right.
HappyTj is offline   Reply With Quote Quick reply to this message
Old 12-16-2011, 04:07 PM   #156 (permalink)
Member # 130731
As a kid???? I thought you carried a fresh bag of paint chips on each run!!!!:-)
Chip Munk is offline   Reply With Quote Quick reply to this message
Old 12-18-2011, 05:37 PM   #157 (permalink)
Member # 119281
You fellas are some funny fawkers. Its cool to have a couple buddies to help with a build. Rigs looking nice.
We have done so much for so long, with so little.....That we can do anything with nothing.
itchy is offline   Reply With Quote Quick reply to this message
Old 12-19-2011, 08:59 AM   #158 (permalink)
Member # 47947
I thought it was the liquid apple pie that caused 'drain bamage' on each run, supplemented by paint chips?
89 YJ, 4 cyl, 5 sp
04.5 Dodge 2500 4x4 QC LB,CTD,6sp
bigmike26 is offline   Reply With Quote Quick reply to this message
Old 12-19-2011, 01:04 PM   #159 (permalink)
Member # 19355
Another Deeetroit baller chiming in.
I told you IN boys we were taking over.
Old 12-19-2011, 01:06 PM   #160 (permalink)
Member # 19355
That is way to high end for the KY Long Rifle........
That dude is using real welding rods.
Your $hit is pieced together with Walmart coat hangers.
Old 12-19-2011, 05:02 PM   #161 (permalink)
Member # 157647
Great 8 coat hangers Bisnitcha.
Old 12-19-2011, 05:44 PM   #162 (permalink)
3j7
3j7's Avatar
Member # 79635
that's the only way we can make our junk hold up...
3j7 is offline   Reply With Quote Quick reply to this message
Old 12-31-2011, 09:58 AM   #163 (permalink)
Member # 154598
I'm hoping you haven't updated because you've been so busy getting this thing built?
Gut-Pile is offline   Reply With Quote Quick reply to this message
Old 12-31-2011, 09:29 PM   #164 (permalink)
Member # 19355
No.....he is just lazy
Old 01-03-2012, 07:14 AM   #165 (permalink)
Member # 81277
Lazy is right..........
Happel and I got most of the skid plate done, got all the front frame plating done, and primed. Wired wheeled all the welds on the frame and re-welded everything as well as finshed welding all the link mounts and cage tie-ins as well as the rear coilover mounts. I also got most of the rear frame painted.
I sent my computer and harness off to Wayne Hartwig for a tune and a rework.
Next up is to get the cage painted, the body set back down and cut the tube for the atlas.........
Pics of the skid plate and trans/transfercase mount.
My Build:
Old 01-03-2012, 08:07 PM   #166 (permalink)
Member # 19355
Looks good.
You need to run some ribbing to help reinforce the skid plate. Primary concern is deflecting up when you drop down on it.
Can't tell what the plan is for the transmission mount but you need to make sure that it WILL NOT move independent from your Atlas support ring.
The ring set up is great for supporting the extra load but can create problems if the system is not set up correctly.
Middel Fangers
Old 01-04-2012, 07:20 AM   #167 (permalink)
Member # 81277
Looks good.
Middel Fangers
What up farm dog........I plan on adding some angle to the skid perpendicular to the frame in the front and rear of the skid. What do you think would be better, box or angle and how much?
It is a two piece skiplate where the other portion attaches at the two vertical tabs on the front of the rear skid and gets bolted to the frame. The front portion can be removed to service the transmission without having to drop the transmision support. .
The mount you see serves as both an atlas support and a transmission mount. The factory 4l60e mount attaches right below the vss between the transmission and the transfercase. This mount eliminates that and supports the atlas as well. Advance Adapters threw it in at no charge when I bought all my adapters.
Thougts?
How is your build coming along?
Middel Fangers
My Build:
Old 01-06-2012, 04:26 AM   #168 (permalink)
Member # 19355
Thougts?
Middel Fangers
I didnt realize it was one mount for the whole set up. Sounds good.
I would use angle. Unlike your wemens - doesnt need to be too thick.
Old 01-06-2012, 09:27 AM   #169 (permalink)
Member # 81277
Well we went out to SFW to work on jeeps and somehow got sidetracked. The night started off with a lot of measuring, a few sodas and a few hot laps through some new wheeling areas..........no tech in this one, not that there is much in here anyway....
The quote of the night....EM "damn man it only took us an hour to roll the damn thing" I guess we weren't hitting it hard enough out of the gate...
My Build:
Old 01-07-2012, 11:31 AM   #170 (permalink)
Member # 19355
Nice bender - i forgot what that thing looked like
Old 01-08-2012, 03:08 PM   #171 (permalink)
Member # 100810
I never knew you could have so much fun with 1 spark plug.
awacjeep is offline   Reply With Quote Quick reply to this message
Old 01-12-2012, 06:45 AM   #172 (permalink)
Member # 81277
Worked on the old girl a little bit last night. Did a little painting, got the wheelbase finally set and and the axles centered ang aligned. I'm at 112 3/4 at full bump. Got a couple things done to the motor and fuel system.
I have to say summit is pretty bad ass, i finallized my summit order Tuesday at 3pm and Wednesday at 6pm the stuff was on my back porch.
It is stupid how much those damn AN fittings cost especially when you start buying -10 stuff.
My Build:
Old 01-13-2012, 01:14 PM   #173 (permalink)
Member # 157647
That has to be a typo.There is no way you were up at 6:45 in the morning.
Old 01-15-2012, 09:12 AM   #174 (permalink)
Member # 157647
Just an update:
Pubes and I went to SFW.
He did some welding on the skid plate.
I drank his beer. That is all.
Stay tuned next week for an all new episode where I do some welding and Pubes drinks beer. Don't miss the never ending excitement.
Old 01-16-2012, 03:53 PM   #175 (permalink)
Member # 81277
Put 8 hours in today. PSC pump us on, RAM is mounted, I raised the trans and transfercase up about an inch to add more clearance between it and the skid. Finished both skid plates. I'll have some pictures tomorrow. I'm going to have to cut the tub over the atlas, hopefully the seat cage will still fit.
My Build:
