Jevy Runs Deep - 1 Ton YJ Build - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-14-2016, 02:32 PM   #26 (permalink)
Member # 158281
Looks good man! I should of worked on mine this weekend but said fawk it! I'll get more work in next week.....
M&M Offroad chassis, LS1,TH350, Atlas, Tons, 42's
hitman_1b is offline   Reply With Quote Quick reply to this message
Old 02-14-2016, 03:58 PM   #27 (permalink)
WhyJayPA's Avatar
Member # 205248
Haha I almost did the same but I'm keeping the first week in March as my target finish date. I didn't wheel till Memorial Day last year and didn't get out as much as I wanted. Trying to change that this year.
WhyJayPA is offline   Reply With Quote Quick reply to this message
Old 02-15-2016, 06:08 AM   #28 (permalink)
Member # 189899
looks great; now you can do trail 5!
be looking see you in the spring @RC!
[COLOR="Black"].
.[/COLOR]
[COLOR="Black"]_ _______ _ _ _ _ _ _ _ _ _ _ _ _[/COLOR][CENTER]what the hell you lookin' down here for?[/CENTER][COLOR="Black"] _ _ _ _ _ _ _ _ _ _ _ _ _ _[/COLOR]
ecoast is offline   Reply With Quote Quick reply to this message
Old 02-15-2016, 06:36 AM   #29 (permalink)
WhyJayPA's Avatar
Member # 205248
Haha Trail 5 has my name. The leafs just weren't cutting it.
I don't remember who you are though. Mind refreshing my memory? Hahah
Old 02-15-2016, 08:51 AM   #30 (permalink)
Member # 189899
nope; we have not met- yet!
I try to get out once a month; running both a built zuk, and more recently, rear engine zuk tube buggy...
always looking for new company; need 2 rigs to ride @RC!
[COLOR="Black"].
.[/COLOR]
Old 02-15-2016, 11:50 AM   #31 (permalink)
WhyJayPA's Avatar
Member # 205248
Nice! I try to get up to Rausch about once a month since I m only about an hour away. My cousin runs a nice little samurai with us. We're putting a shogun doubler in it right now. It's a capable little thing for only being on 33's.
Let me know when you're headed up to rausch next
Old 02-15-2016, 05:00 PM   #32 (permalink)
Member # 158281
You'll be fine on trail 5 hill climb now! Just hit it harder
Old 02-15-2016, 05:39 PM   #33 (permalink)
WhyJayPA's Avatar
Member # 205248
The video on my instagram shows what happened last time. The rear started hopping and bouncing and i walked the front end off to the right. Left rear came up off the ground and almost rolled. Wifey was scared shitless
Old 02-15-2016, 05:49 PM   #34 (permalink)
Member # 158281
Don't bring up old shit......lol you'll be fine!
Old 02-19-2016, 12:46 PM   #35 (permalink)
WhyJayPA's Avatar
Member # 205248
Back on all 4's for now. Everything is painted, tight, and ready to rock. got some exhaust work, fuel plumbing, and other stuff to do yet but its a roller again.
Boogers
Tried to flex it out in the garage but hit the garage door track before i really got any articulation, but here's the pics anyway.
Old 02-22-2016, 11:06 AM   #36 (permalink)
WhyJayPA's Avatar
Member # 205248
Had some spring issues that needed to be sorted out since I was able to get a better idea of how the coilovers are supposed to be set up (first time 4-linking or using long travel dual-rate coilovers).
I was running at 14" 110 lb. tender spring and a 12" 250lb main spring. My ride height was good but I olny had about 1" of threads left to go lower and the springs dropped out of the upper seat at full droop. See pics.
Ride Height
Full Droop
So I called up Poly Performance and spoke with Andy. Awesome guy and great service. He hooked me up with psrings that should suit me better. I will now be running the same 14" 110 lb. tender with a 14" 130 lb. main spring to keep my ride height and 5" up/9" down all the same or close.
Also finished mounting the RCI 2161a fuel cell and re-installing my back seat.
Lastly, I fabbed up some poor man's air bump wannabe's. Going to use some 2" DOM I have laying around and weld in the caps that Neil "WarH31" cut out for me while he was fabbing parts for the Got Trikes tube bender that we're building.
Old 02-22-2016, 11:45 AM   #37 (permalink)
Member # 14004
Originally Posted by WhyJayPA View Post
Then I mocked up and fabricated a crossmember in order to get the weight of the drivetrain off the skid plate. I didnt feel good about the links being mounted to the skid plate and having it support the drivetrain.
Looks fun! My wife gets out "to take pictures" on exteme stuff like that
Your cross member will turn out better next time if you cut the horizontal pieces corner to corner instead of at 90 degrees. For example, the top of piece 2 should go all the way out to the corners of 1 and 3. This way you end up with a trapezoid instead of a rectangle and you don't have to piece/fill all the corners.
- TBI 304/T18a/D300/60/70/5.86/43's
87 Samurai - GSX carbs/16V 1.6/GRS-II/linked rear/31's
Kreep is offline   Reply With Quote Quick reply to this message
Old 02-22-2016, 11:54 AM   #38 (permalink)
WhyJayPA's Avatar
Member # 205248
Agree with you completely. I noticed this once I laid it out as you see in the pic. Just didn't go back and make it "right". Lesson learned haha.
Old 02-26-2016, 05:45 AM   #39 (permalink)
WhyJayPA's Avatar
Member # 205248
Waiting on springs and limit straps so I started on the frame tie-ins. The compound angles were a pain. Still need to finish the a-pillar tie-ins. I used the Barnes 4WD crossmember bushing kits. Really cannot beat the quality and price that Barnes gives you.
Footplates
C-Pillar
B-Pillar
Limit straps, springs, and A-pillar tie-ins are on the docket for tonight.
Old 02-26-2016, 05:29 PM   #40 (permalink)
Member # 158281
Hmm......gonna have to look at the barnes tie in kits now......
Give me a shout Sunday if you're around. Haven't started on the cage yet. That's next weekends plans.....
Old 02-28-2016, 04:19 PM   #41 (permalink)
Member # 158281
Well......what have you gotten done??
Got the front all put back together and back to roller status after too much paint work. Gonna work out battery box mount and wiring tomorrow. Working the weekend slowed me down! Shoot you a text then
Old 02-28-2016, 04:43 PM   #42 (permalink)
WhyJayPA's Avatar
Member # 205248
More work last night. Limit straps and bump stops are done and it's riding on the new springs from Poly performance. Running 110/130 14" springs in the rear for anyone who's curious about corner weights of a full frame/full body YJ.
Here's my poor man's "air" bumps.
First time out of the garage in a while.
Still had 2" up and some left to go dow
Old 02-28-2016, 08:27 PM   #43 (permalink)
Member # 158281
Looking good man! It'll be done before you know it!!!
Old 02-29-2016, 07:21 AM   #44 (permalink)
WhyJayPA's Avatar
Member # 205248
Hopefully I'll get this thing finished up this week.
Main things that still need to be finished:
A-pillar frame tie-ins
Mount shock reservoirs
Finish exhaust fab
Weld on beadlocks
Replaces D60 and 14B axle seals
Fab trans tunnel/console
Bleed brakes
Hoping to get it all buttoned up by Sunday night. Pics to come.
Old 02-29-2016, 09:51 AM   #45 (permalink)
Member # 5809
whats your up travel with that spring rate?
RoCkSkuLLz is offline   Reply With Quote Quick reply to this message
Old 02-29-2016, 10:04 AM   #46 (permalink)
WhyJayPA's Avatar
Member # 205248
5" up. 9" down.
As you can see, I can go down to about 3" of uptravel with my adjusters. There's plenty of room to adjust rdie height up from there though. I am shy about 12.5 gallons or 80lbs of fuel in the pics. (6lbs per gallon w/ a 15 gallon tank = 95 lbs)
You can see where my adjusters are at in this pic.
Old 02-29-2016, 04:25 PM   #47 (permalink)
Member # 158281
eastcoastgearsupply.com/i-12533854-dana-60-front-axle-tube-seals.html
Get these now! You'll appreciate it later! Saves all the junk getting in the axle tube.
Old 02-29-2016, 04:27 PM   #48 (permalink)
Member # 158281
Don't know why the link isn't posting right. Go to east coast gear supply and look for dana 60 axle tube seals. Do it before you regret it!
Old 02-29-2016, 07:11 PM   #49 (permalink)
WhyJayPA's Avatar
Member # 205248
Mounted the reservoirs and changed out my mock up bolts for the coilovers and B and C pillars to grade 8 yellow zinc.
Reservoirs are mounted with hose clamps welded to the tub. Cheap and easy. Hopefully they hold. If not, then Hitman can say "I told you so".
Old 03-01-2016, 08:32 PM   #50 (permalink)
WhyJayPA's Avatar
Member # 205248
A-pillar frame tie-ins are done and the cage is completely tied into the frame at 6 points. The Barnes 4wd crossmember mounting kits are what I used. They're the cheapest bushing and tab kits I found online and they're beefy. Plus it's nice for us East coast guys to get builder parts in 2 days or less. The Cali boys get all the perks of local businesses.
On to the pics:
