CJ unlimited, or LJ7 build - Page 14 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-06-2019, 04:27 PM   #326 (permalink)
Member # 191
Boone does your employer show at Tulare?? Are you going?
--Ive been going to Ag Expo since 1981. wouldn't miss it.
--Sherpa
[QUOTE][i]Originally posted by LAME [/i]
[B]
The guys designing cages for the D9 dozer on your Christmas list are going about this a bit differently way then a few rednecks, too much beer, and a JD2:D [/B][/QUOTE]
SHERPA is offline   Reply With Quote Quick reply to this message
Old 02-10-2019, 12:54 PM   #327 (permalink)
Member # 78700
Send a message via Yahoo to sickboyboone
--Sherpa
I will be there not sure what day. I canít do all 3 this year Iím behind at the shop. We donít have a booth but I help out my buddies at the gold country hydraulics booth
I must be sick, I'd almost rather build em than wheel em! almost.
sickboyboone is offline   Reply With Quote Quick reply to this message
Old 02-10-2019, 12:56 PM   #328 (permalink)
Member # 78700
Originally Posted by 46WILYZ View Post
Great looking build! I am getting ready to build my 5.3 exhaust and your exhaust design would work great for my rig. Where did you get your y pipe with the v band? or did you build it? I've found some online, but none that are as narrow as yours.
Vibrant motor sports. I got it from summit. It was expensive but I would not be able to make it work without that narrow one. Get high quality 90s mine were thin. The 45s I got were much nicer and way more money
Old 02-10-2019, 01:03 PM   #329 (permalink)
Member # 78700
Best I got. Didnít take many pics from KOH drive the jeep in some desert stuff when I found a problem with my brakes. The fronts were loading up till they locked. Had to crack bleeders. Iím guessing something in the stock proportioning valve was sticking. Killed my wheezing plans. I went by wilwood to see if they had one and they didnít. Pointed me to a place that might and they were closed up already. Damn thing gets it with that motor, but Iím under geared even with that hp. Makes my trans not shift well. I think Iím gonna find a 400 turbo to put in it. Gonna link the rear too. It gonna be nuts. Also needs sway bars something fierce lol
Old 02-10-2019, 08:32 PM   #330 (permalink)
46WILYZ's Avatar
Member # 141981
Send a message via ICQ to 46WILYZ
Thanks, I get to try and fire it (LM7) up for the first time tomorrow! Then swap the front axle, oil pan, and then I can build the exhaust.
KK6MWD "46WILYZ previously known as 1946cj2"
pirate4x4.com/forum/showthread.php?t=968398
46WILYZ is online now   Reply With Quote Quick reply to this message
Old 02-12-2019, 07:40 AM   #331 (permalink)
1tonhammer's Avatar
Member # 688946
Power steering cooler and trans cooler mounted
There she is, the whole package
Headers are tight but they are gonna work. Hopefully get to motor mounts this week
I missed it, what radiator are you using? those seats are pimp, as is the rest of the rig
1tonhammer is offline   Reply With Quote Quick reply to this message
Old 02-12-2019, 07:46 AM   #332 (permalink)
Member # 78700
I used a universal from be cool then build brackets and shroud. At this point I wish I would have gotten one from Novak or somewhere that fit a bit better, although I needed room for all the hoses I got running into the grill
Sent from my iPad using Tapatalk
Old 02-18-2019, 09:42 PM   #333 (permalink)
Member # 78700
Well, I took the jeep to the desert, Spangler hills outside of ridgecrest this weekend. Drove it through the desert with some bikes and rzrs over to jawbone canyon store, bout a 60 mile trip. Jeep did ok, had some heating issues. Drove it back to camp on the highway. this thing will do 80 on the highway with no issues. Drives great. Will need a sway bar in front though. Rear end bucks pretty hard on big whoops, Iím gonna get new shafts for my FOAs and use them in the rear to link it. Drinks a lot of fuel now. Overheating issue should be fixed, found out my fan was turning the wrong way, fuckin rookie mistake. Need to fix my steering so I get my full radius, I got a plan should work. All in all some good seat time.
Old 02-18-2019, 09:52 PM   #334 (permalink)
Member # 78700
Can you tell it was cold lol
Old 02-19-2019, 08:15 AM   #335 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Nice man!
What kind of heating issues did you have?
I don't think you can just bypass the heater circuit like you did. I think that always makes the LS run hot.
@alpine_cj5 on Instagram
Owner of Aired Down Syndicate
@adsoffroad on Instagram
Alpine_CJ5 is offline   Reply With Quote Quick reply to this message
Old 02-19-2019, 12:13 PM   #336 (permalink)
Member # 78700
Originally Posted by Alpine_CJ5 View Post
Nice man!
I was under the impression that blocking it made it run hot and bypass was ok...
found my fan was running wrong way and this fan can only be used as a puller due to blade design
Old 03-09-2019, 06:10 PM   #337 (permalink)
Member # 78700
Not much to post, seems to be stayin WAY cool now.
Climbed this chunk of concrete. Gonna try and go out tomorrow and try to say dry.
Got more steering now. Making use of all 8Ē of stroke on my assist cylinder.
Insert stroke jokes here....
Still if I had 1/2 inch more stroke Iíd have sick steering
Ask my wife
Old 03-15-2019, 06:22 AM   #338 (permalink)
scO44's Avatar
Member # 16080
What pitman arm are you running?
-Ghost ride the whip while you ride tha strip..
scO44 is offline   Reply With Quote Quick reply to this message
Old 03-15-2019, 07:14 AM   #339 (permalink)
Member # 78700
A flat one from psc. Drill your own hole kinda thing
Old 03-15-2019, 07:19 AM   #340 (permalink)
Member # 78700
Finally got my bumpstops in the front. Ordered limit straps. Once they are in Iím done with the front. Time to start my trailing arms for the rear
Old 03-15-2019, 08:31 AM   #341 (permalink)
scO44's Avatar
Member # 16080
I take it you are running less than 1-1 pitman arm to steering arm ratio? Are you getting enough throw with that setup? Your draglink mount hole must be 8Ē out?
Thanks
Old 03-15-2019, 09:57 AM   #342 (permalink)
Member # 78700
Thanks
Itís a fairly long pitman, I had it tied in to the tie rod bolt on top of the high steer arms, I moved it inward and now I can get steering from stop to stop. Problem is my assist cylinder is and 8Ē and my tie rod moves more like 9Ē because of where itís mounted. So my cylinder is actually whatís limiting me. If I want more, Iíll have to get a 10Ē cylinder and build an internal stop for it.
Old 03-15-2019, 11:46 AM   #343 (permalink)
scO44's Avatar
Member # 16080
Gotcha, I was looking at doing the same thing mounting on the tie rod bolt. Problem is the pitman would need to be around 7.5Ē cl. Iíll probably just drill and mount further back on the arm like you did.
Old 03-19-2019, 09:31 PM   #344 (permalink)
Member # 78700
Little performance report. Went out Sunday, few hours and never got over 195. And the bumpstops; HOLY FUCK! They made such a difference it was amazing. Lightened my spring rate a tad when I put em in. Itís amazing. I never would have thought man. Itís like a triple rate spring and no harsh bottom outs now Iím so stoked. Iím ordering up part tomorrow for the rear trailing arm setup, I already started on the ruffstuff trailing arms.
Old 03-26-2019, 12:55 PM   #345 (permalink)
Member # 78700
Went out again Sunday had a good time buried the jeep in the mud.
Old 04-24-2019, 09:09 AM   #346 (permalink)
Member # 78700
Went to the hammers last week. Chocolate thunder whipped my ass. Broke a rear axle yoke at the axle and a front stub shaft.
Old 04-26-2019, 09:58 PM   #347 (permalink)
Member # 78700
I know not much ďtechĒ anymore but I feel like all my FANS need an update! So started tearing front end down.... from the looks of it Iíll just start breaking ring and pinions
Little more beef ?????
Old 05-30-2019, 08:19 AM   #348 (permalink)
Member # 28880
I might have missed it somewhere on the thread, but what fuel pump are you running? Is it in tank?
Harry Johnson is online now   Reply With Quote Quick reply to this message
Old 05-30-2019, 08:25 AM   #349 (permalink)
today
fredycruger's Avatar
Member # 225557
thanks for update
fredycruger is offline   Reply With Quote Quick reply to this message
Old 05-30-2019, 08:46 PM   #350 (permalink)
Member # 78700
Running an external walbro and a corvette filter. I got it from Warr performance in Fresno CA
