CYJ8 "Scrambled" build - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-26-2018, 11:10 AM   #101 (permalink)
Ringer's Avatar
Member # 216542
Originally Posted by gt1guy View Post
Great progress.
I hate filters that mount upside down or even sideways. Just makes a mess.
Agreed, but there is a drain on the bottom that should help minimize the mess, plus not a fluid change that I will be doing weekly.
Ringer is offline   Reply With Quote Quick reply to this message
Old 09-05-2018, 07:40 PM   #102 (permalink)
Ringer's Avatar
Member # 216542
Lots of new parts since I last updated.
14Ē front and 16Ē rear ORIís. The 12ís are for a buddy.
PRP premier fronts and 54Ē rear bench. Big enough for the whole family.
Driveshaft parts and some 2-1/8x.188 tubing.
American Autowire severe duty harness with all sealed connectors.
New toy!
Old 09-05-2018, 08:17 PM   #103 (permalink)
CartoTracks's Avatar
Member # 542161
Nice work! Coming along it looks like.
Those PRP seats look nearly identical to ours. Same colors on every component I think. We love them.
CartoTracks.com
CartoTracks is offline   Reply With Quote Quick reply to this message
Old 11-11-2018, 02:11 PM   #104 (permalink)
Ringer's Avatar
Member # 216542
Rear tube fenders made. I laugh seeing the stock wheel opening. I didnít want a full comp cut, and this was as much as I could leave.
New gauges. Dakota Digital comp cluster
Links are all made up. Used 2Ēx.25 for all of them, and the lowers got slugged with 1.5Ē 7075 solid aluminum. Rear 16Ē struts are mocked up.
Old 11-12-2018, 12:52 PM   #105 (permalink)
gt1guy's Avatar
Member # 236179
Looking fantastic.
Does that Dakota Digital cluster run off the OBDII port?
Kevin
gt1guy is offline   Reply With Quote Quick reply to this message
Old 11-12-2018, 01:42 PM   #106 (permalink)
Ringer's Avatar
Member # 216542
Looking fantastic.
Thanks. The cluster can run OBDII, or standard sensors. There are add on modules to basically make it do anything you want. Iím leaning towards the GPS module that gets you speedo, compass, altitude, and outside temp.
Old 11-21-2018, 12:53 AM   #107 (permalink)
Member # 66137
Originally Posted by Ringer View Post
I knew I recognized Embers. I work in Mentor. Used to live in Hambden.
frank_c is offline   Reply With Quote Quick reply to this message
Old 11-21-2018, 07:10 PM   #108 (permalink)
Ringer's Avatar
Member # 216542
Haha, good eye.
Old 11-21-2018, 07:20 PM   #109 (permalink)
Ringer's Avatar
Member # 216542
Finally got some time to make more progress. All tube fenders bent up. Side steps bent. Rear ORIís installed and test flexed. Need to trim a little more for these big ass 42ís. More to come.
Old 11-22-2018, 11:10 AM   #110 (permalink)
Member # 24895
What sets your build apart from so many others is that clean floor. Keep the updates coming!
b0mb is offline   Reply With Quote Quick reply to this message
Old 11-22-2018, 12:08 PM   #111 (permalink)
Ringer's Avatar
Member # 216542
What I lack in fabrication skills I make up for in janitorial raw talent
Old 11-22-2018, 12:17 PM   #112 (permalink)
gt1guy's Avatar
Member # 236179
Question. What are your rear tube fenders going to connect to? Welded to the side of the tub/armor? Or going through to some other structure?
I spy a door! Eagerly awaiting how you pull off your plans for the rear doors
Kevin
Old 11-22-2018, 08:00 PM   #113 (permalink)
Ringer's Avatar
Member # 216542
I spy a door! Eager awaiting how you pull of your plans for the rear doors
I have 3/16 corner blanks that will get cut to match sheet metal and welded to the body. The rear fenders will then bolt to the corner armor. The fronts are part of the tube chassis. This way fenders will all be black with the chassis and body can be painted itís own color.
Iím excited for the rear doors. Thereís so many things to do. They may come sooner than later as their location and cage location both need to work together for the rear door latches.
Old 11-22-2018, 08:38 PM   #114 (permalink)
NERD
gtxracer's Avatar
Member # 25303
I'd be very interested in hearing your thoughts on the Wright CNC 2x2. I looked at that system before I bought my Langmuir system and both seemed very good. I missed the promo for the Wright CNC but it still looks like a great system for the price.
The severe duty wiring harness is also on my short list if I redo my main box. Very cool kit and looks really well done! Nice work so far, I'm digging your rear frame work and how clean it all comes out.
97 TJ Build:
2013 Raptor SuperCrew Tow Rig
Porsche
Fab Parts:
PNW Shock Tuning:
gtxracer is offline   Reply With Quote Quick reply to this message
Old 12-03-2018, 02:32 AM   #115 (permalink)
Ringer's Avatar
Member # 216542
I will let you know as soon as I make a cut with it... soon! I was crazy busy when I first got it, so I played with all the software for a month. Then I went to cut and nothing. I called Wright, whose tech support seems very good, and it turns out it was wired wrong (pre production batch). I sent my control box to them for testing. They fixed everything and it should be back to me this Tuesday. In my opinion, this issue is part of why I got such a deal on their first batch. All in all Iím still very happy with the purchase. I will post an update when I cut with it.
Old 12-03-2018, 11:22 AM   #116 (permalink)
NERD
gtxracer's Avatar
Member # 25303
More pictures
Thanks for the feedback so far on the Wright CNC.
Is this the pop-up style cap? I was going to use the same one so I'm very interested in seeing how you like it and how well it does when it's mounted flush.
97 TJ Build:
Porsche
Fab Parts:
PNW Shock Tuning:
Old 12-03-2018, 07:12 PM   #117 (permalink)
Ringer's Avatar
Member # 216542
The cap is not a pop up style. I got it from Pacific Customs. The have just about any size or configuration you could need.
Old 12-30-2018, 11:14 AM   #118 (permalink)
Ringer's Avatar
Member # 216542
Started on the cage. Lots to go, but finally looking like something. Cage is all 1.75Ēx120, but I did the B pillar vertical and cross support out of 188.
Old 01-08-2019, 03:39 AM   #119 (permalink)
Ringer's Avatar
Member # 216542
A few more cage pics. A pillars tie through firewall to engine cage. Still need harness bars and X and seat mounts.
Also got the grill drilled out to just run some 4Ē grommet mount leds.
Had to order more tubing that should be in tomorrow to keep going.
Old 01-08-2019, 07:31 AM   #120 (permalink)
today
fredycruger's Avatar
Member # 225557
bad ass work
looking good
fredycruger is offline   Reply With Quote Quick reply to this message
Old 01-08-2019, 08:19 AM   #121 (permalink)
NERD
gtxracer's Avatar
Member # 25303
That’s a good looking cage. I like the firewall pass through and gusseting. Are you going to brace the A pillar to the firewall tube a bit more? Maybe one more diagonal tube down to it from the a pillar node? Everything looks well planned and executed, nice work!
97 TJ Build:
Porsche
Fab Parts:
PNW Shock Tuning:
Old 01-08-2019, 11:05 AM   #122 (permalink)
gt1guy's Avatar
Member # 236179
Are those tube clamps on the A-pillars just above the engine cage tie-in?
Always wondered if they were as strong as a straight tube with no clamp.
Fantastic work.
Kevin
Old 01-08-2019, 11:56 AM   #123 (permalink)
Ringer's Avatar
Member # 216542
Fantastic work.
Yes, those are TMR tube clamps. I see no reason they weaken it. I had to because those points are too wide to remove the cage.
Old 01-08-2019, 11:58 AM   #124 (permalink)
Ringer's Avatar
Member # 216542
Thatís a good looking cage. I like the firewall pass through and gusseting. Are you going to brace the A pillar to the firewall tube a bit more? Maybe one more diagonal tube down to it from the a pillar node? Everything looks well planned and executed, nice work!
Thanks. Yes, there will be more gussets, including tubular handle gussets from A to roof. The center console tubes will tie from the dash bar to B pillar cross bar as well.
Old 01-11-2019, 07:06 AM   #125 (permalink)
Member # 112150
LOL. I've been watching this build and had no ideal it was down the street... A "Hilltoppers" build! love it! keep up the good work. Can't wait to pass this jeep going down the road!
85'scrambler is offline   Reply With Quote Quick reply to this message
