CYJ8 "Scrambled" build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-30-2017, 08:40 AM   #1 (permalink)
Ringer's Avatar
Member # 216542
Figured I'd start a build thread here. My last jeep was a 2dr JK stretched, 4 linked, coilovers, etc... Then we had twins. Now with 3 kids I needed a new ride to fit all the family in. Bear with me, as garage time is limited with three boys 3 and under! Here is my twisted plan:
-88 YJ tub stretched 24" to CJ8 length. Stretch is in the door frame opening. This will be a four door, with no body B pillar, and the rear doors being suicide. The front doors will close into the rear similar to an extended cab pickup. Looks weird as shit with no doors on it.
-CJ front clip and tailgate
-LS1 from 1999 Corvette with 4L80e
-Atlas 2 speed 4.3:1
-ORI Struts: 14" front and 16" rear
-Four linked front and rear with full hydro
-Goat Built subframe with remainder being custom tube chassis
-Fusion 4x4 kingpin 60 front ARB, 5.38, Chromo, etc...
-Fusion 4x4 60 rear ARB, 5.38, Chromo, etc..
-Trailready beadlocks
-42" Maxxis Trepdors
-PRP Premium front seats with 54" rear PRP bench
You get the idea, typical family truckster
Pictures to follow.
Ringer is offline   Reply With Quote Quick reply to this message
Old 11-30-2017, 08:49 AM   #2 (permalink)
Ringer's Avatar
Member # 216542
Donor jeep came out of Kansas
Out with the old
Frame table I built using some 2x6x1/4 wall. Legs are adjustable basement "jacks" that allow me to fine tune the level of the table as I roll it around the shop. Casters are rated to 1000lb ea and locking.
Got the tub back from sandblast. Need a new driver floor pan, fix B pillar rust under where factor roll cage sat, and needs a new rear corner. Not too bad.
Donor LS1
Starting the stretch and boatsides. Used telescoping tubing welded down each side to keep everything straight.
New floor supports I bent up from some 14ga
New 16ga floor pan I bent up in the cheapo HF brake and bead roller
Start of repair panels for the B Pillar
Sadly that brings me up to date. More to come.
Old 11-30-2017, 09:26 AM   #3 (permalink)
GTOffroader's Avatar
Member # 34347
Those sliding braces are brilliant.
Also, I'm impressed the Harbor Freight Bead Roller worked on 16g. Nice work.
1958 Willys CJ-3B "Pile'o'parts"
1952 Willys CJ-3A "Farm Jeep"
GTOffroader is offline   Reply With Quote Quick reply to this message
Old 11-30-2017, 09:44 AM   #4 (permalink)
gt1guy's Avatar
Member # 236179
If this project comes out half as clean as your JK did, it's going to be sweet.
Enjoy not having the JK electronics to deal with.
Kevin
gt1guy is online now   Reply With Quote Quick reply to this message
Old 11-30-2017, 10:17 AM   #5 (permalink)
Snooty Poser
BeatCJ's Avatar
Member # 83100
Really nice work on the floor pan.
I bet your cage will be interesting looking, too.
When holding a cat by the tail, you will learn things that cannot be discovered any other way
Originally Posted by PONY_DRIVER
The older I get the more I realize mayhem is for young people who don't have to get up and go to work in the morning.
BeatCJ is offline   Reply With Quote Quick reply to this message
Old 11-30-2017, 11:03 AM   #6 (permalink)
Ringer's Avatar
Member # 216542
The square tubing worked great. It has a .010" gap between the two and kept everything perfectly in line.
I had to beef up the HF stuff from the way it comes, but it does the job.
Thanks. The JK was fun, but I will definitely not miss the electronics, or not a single straight panel on them
Old 11-30-2017, 11:12 AM   #7 (permalink)
Member # 214628
Work looks excellent, will be following this one.
Trazer75MT is offline   Reply With Quote Quick reply to this message
Old 11-30-2017, 11:52 AM   #8 (permalink)
GFY Racing's Avatar
Member # 136091
Location: Back in the good 'ol U S of A after three long deployements!
Sub'd. This looks like it's going to be a badass build.
Fighting for the right for SORRY PIECES OF SHIT to protest at soldier's funerals.
1989 XJ on 35s Work in Progress
GFY Racing is online now   Reply With Quote Quick reply to this message
Old 11-30-2017, 12:20 PM   #9 (permalink)
Member # 229453
sub'd.
watched your build on jkowners. So I'm really interested on where you take this one.
k1973 is offline   Reply With Quote Quick reply to this message
Old 11-30-2017, 12:25 PM   #10 (permalink)
Member # 208624
WOW!!! Definitely keeping an eye on this one. Anxious to see more on the suicide doors.
Mountain Havoc Alum - '16
3rd place passenger seat ballast and pointer of rocks
93_Fummins is offline   Reply With Quote Quick reply to this message
Old 11-30-2017, 12:49 PM   #11 (permalink)
ANGER IS A GIFT
Dookey's Avatar
Member # 23680
In for the updates!
TRAIL WORTHY FAB
| 316.337.5311
Old 12-01-2017, 07:59 PM   #12 (permalink)
Member # 153714
excited to see how you do the doors. I have kicked the same idea around for years. Really glad you are doing it
Tyler99TJ is offline   Reply With Quote Quick reply to this message
Old 12-02-2017, 06:31 AM   #13 (permalink)
Ringer's Avatar
Member # 216542
Originally Posted by Tyler99TJ View Post
excited to see how you do the doors. I have kicked the shame idea around for years. Really glad you are doing it
Iíve thought of it for years as well, and from all my searching itís never been done. It will be something different. Most four door CJ/YJ/TJ conversions look awkward in my opinion and I didnít want to use a JKU. Hopefully it doesnít end up looking like shit!
Old 12-07-2017, 09:47 AM   #14 (permalink)
Member # 459658
8
Great Start
1952 m38, 1985 cj7, 1985 cj8, 2010 JKU Rubicon
cj8man is offline   Reply With Quote Quick reply to this message
Old 12-07-2017, 10:20 AM   #15 (permalink)
Member # 142223
Great job with the HF bead roller. I think it looks much more "factory" than the flat floors I usually see on here. Did it make a big difference in rigidity?
Syrings72 is offline   Reply With Quote Quick reply to this message
Old 12-07-2017, 01:44 PM   #16 (permalink)
Ringer's Avatar
Member # 216542
Thanks. Using the bead roller on panels makes a huge difference in rigidity. I need to get a motor and foot control on mine because bigger panels like this by yourself with the hand crank are a pain in the ass.
Old 12-07-2017, 02:25 PM   #17 (permalink)
tjjared413's Avatar
Member # 46942
looking great man keep up the good work!
04 tj to hang out at the malls and 15 F350
tjjared413 is offline   Reply With Quote Quick reply to this message
Old 12-07-2017, 05:42 PM   #18 (permalink)
SnailMan's Avatar
Member # 79690
Damn I'm definitely in for this one!! Great work so far excited to see how the doors work might steal that! I also think 4 door CJ YJ TJs look funky as hell. Looking forward to seeing the finished work!
Keep up the fight for this life, we only do it once! Wheel on buddy! - "T"
Rest in Peace Buddy!!
SnailMan is online now   Reply With Quote Quick reply to this message
Old 12-07-2017, 07:27 PM   #19 (permalink)
Member # 133593
Subscribed, its looking great so far.
1998 XJ thats too mild for Pirate .!.. :D ..!.
Cage,35's,4.88's,front truss,zip locker,4.5" longarm
DutchVDub is offline   Reply With Quote Quick reply to this message
Old 12-07-2017, 07:40 PM   #20 (permalink)
gt1guy's Avatar
Member # 236179
You might enjoy these two videos. Lazze talks about wheeling to stretch the metal before running a bead. It makes sense and the video shows that the results are much flatter.
Part 1: https://www.youtube.com/watch?v=3XBxVtocDqc
Part 2: https://www.youtube.com/watch?v=mTjPZ9ljZ10
I've been watching a lot of his vids lately.
Kevin
Old 12-08-2017, 08:17 PM   #21 (permalink)
Ringer's Avatar
Member # 216542
Great videos. Guy knows his stuff!
Old 12-11-2017, 07:51 AM   #22 (permalink)
Ringer's Avatar
Member # 216542
Iíve got a ways to go till Iím ready for them, but four of these bad boys showed up today
Old 12-11-2017, 02:59 PM   #23 (permalink)
Ringer's Avatar
Member # 216542
Pure beef right there! Fusion 4x4 kingpin 60. Specs: 70.5Ē WMS, 5.38 gears, ARB, Chromo 35 spline shafts, knuckles keyed and six ARP studs for high steer, big brakes, pinion angle, caster, and diff location all custom to my specs.
Anyone looking for an axle, give these guys a call. Dan and the team are great. My matching rear 60 is coming soon.
Old 12-12-2017, 06:38 PM   #24 (permalink)
Ringer's Avatar
Member # 216542
Boat sides built from 16ga and tacked in, B pillar repair panels built, new drivers floor pan, new rear corner, drop down tailgate in. Still need to do raised rear wheel wells and finish weld. Then onto rear doors.
The boatsides will have 2x2 square in the pocket that a step will be built off of and tubing tying to rest of tube chassis. It also will have cage bolting to it allowing everything to be tied together.
Old 12-13-2017, 10:51 AM   #25 (permalink)
gt1guy's Avatar
Member # 236179
Looking really good.
Are those Solid knuckles?
Kevin
