Alpine Lizard - LQ9 Powered CJ5 - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-05-2018, 09:56 AM   #26 (permalink)
Member # 135533
Originally Posted by Alpine_CJ5 View Post
This is my first time using Boom Mat, but I've use similar undercoatings before like 3M. I used 1.5 cans for 2 thick coats. The coating sprays on really well, but there is a tendency to tiger stripe, so you have to pay attention to even coverage. I sprayed the first coat horizontal and the second coat vertical. I had to cover a small spot a third time to break up a heavy handed spray pattern, but i really like the stuff overall.
Thanks
1989 YJ
Grantski Barney is offline   Reply With Quote Quick reply to this message
Old 11-09-2018, 08:16 AM   #27 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Firewall top coated with matte black duplicolor engine paint. LS in its new home! The tranny mount is bolted into the original spot, and the intake and heads of the LS are VERY close to the firewall. It looks like I have plenty of clearance to the radiator, so Iíll likely be moving the whole assembly 1Ē forward. Iíll also try and raise the motor some to get better oil pan clearance, rear driveline angle, and fan-to-radiator clearance.
@alpine_cj5 on Instagram
Owner of Aired Down Syndicate
@adsoffroad on Instagram
Alpine_CJ5 is offline   Reply With Quote Quick reply to this message
Old 11-17-2018, 04:00 PM   #28 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Belly pan modified to move the drive train 1Ē forward to clear the firewall. The welding tweaked the pan like a potato chip, so I stress relieved it with a ball peen and a needle scaler. I ended up using the floor jack and a 2x4 to bend it back into shape. It got a quick coat of paint. Will install once dry.
Old 11-17-2018, 04:05 PM   #29 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Time to start reinstalling things. The gas tank is in, the battery box is in and the brake booster is in. I ran -6 AN hose from the tank to the fuel rail and back. I installed the filter just before the fuel rail so it would be vertical.
Old 11-17-2018, 04:09 PM   #30 (permalink)
Alpine_CJ5's Avatar
Member # 856318
New engine clearance to the firewall. Perfect.
Old 11-28-2018, 12:05 PM   #31 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Worked on some body mount repair/strengthening, put my fenders on, started laying out the wiring and my intake parts. My engine girdle and mount stuff has been cut out. Just waiting for it to ship to my house.
Old 12-05-2018, 10:46 PM   #32 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Fuse block is finally done. Now to loom it and mount the ECM, TAC box, fuse block and power bus somewhere. I used to have relays dangling everywhere off my firewall. Now they are all organized into this little fuse block.
Old 12-05-2018, 10:50 PM   #33 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Now on to some fab stuff! I sent DXFs to my plasma cut guy and he sent me the first cut of the engine girdle. Looks like the bent pieces has some issues, but the rest of the pieces went together very well. The self jigging all worked flawless so far. Iíve only got one side motor mount tach welded right now. I reordered a second rev of the bent piece that should bend much cleaner.
Old 12-13-2018, 07:50 AM   #34 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Still working on the harness, but switched gears to do a little welding.
Old 12-13-2018, 07:56 AM   #35 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Harness work continued. The harness is loomed. The engine part of it is plugged in and complete. I still have to punch wires through the firewall, hook up the DBW gas pedal, run the fuel pump wire and mount up the fuse block and power bus.
Old 12-13-2018, 08:00 AM   #36 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Speaking of fuse block and power bus, Iím using the original LS battery cable for the driver side power source. Iím incorporating a 200A breaker as well. I think Iím going to fab up a cover to fit over the computer and TAC box and mount the fuse and power blocks.
Old 12-13-2018, 11:44 AM   #37 (permalink)
NERD
gtxracer's Avatar
Member # 25303
Great work! This is really chugging along. I like the relay and fuse block - did you do that yourself or was it a kit? I've looked at doing the same to replace the 20 year old unit.
This is turning out super clean
97 TJ Build:
2013 Raptor SuperCrew Tow Rig
Porsche
Fab Parts:
PNW Shock Tuning:
gtxracer is offline   Reply With Quote Quick reply to this message
Old 12-13-2018, 12:27 PM   #38 (permalink)
Member # 78700
Send a message via Yahoo to sickboyboone
Your gonna be done before me man. I paid a coworker to paint my front frame half while I was hunting. They gave him super high gloss paint so now my shit is shiny and donít match
Sent from my iPad using Tapatalk
I must be sick, I'd almost rather build em than wheel em! almost.
sickboyboone is offline   Reply With Quote Quick reply to this message
Old 12-13-2018, 12:55 PM   #39 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Thanks! I did the fuse block stuff myself. I bought the fuse block with a large assortment of those GM weatherpack connectors in a kit from amazon.
Iím going as fast as my wife will let me. Haha.
Iíve been able to flatten out glossy paint by wiping it with brake cleaner soaked rag.
OR,
itíll all look the same once it gets dirty.
Old 12-13-2018, 01:23 PM   #40 (permalink)
NERD
gtxracer's Avatar
Member # 25303
Slick! Got some links for us?
97 TJ Build:
Porsche
Fab Parts:
PNW Shock Tuning:
Old 12-13-2018, 01:38 PM   #41 (permalink)
Alpine_CJ5's Avatar
Member # 856318
But of course. Here’s all the wire stuff I bought from amazon.
Fuse BLock
Firewall Bulkhead
280 Series Relays
Crimpers
Power Bus
Circuit Breaker
Edit: Cleaned up links.
Old 12-13-2018, 02:22 PM   #42 (permalink)
whitneyj's Avatar
Member # 135947
Love what you've got going on. Thanks for the link for the fuse panel. I've been looking for something like that.
Place banana in your ear.
Observe that there are no alligators around.
Conclude bananas placed in ears keep alligators away.
whitneyj is offline   Reply With Quote Quick reply to this message
Old 12-13-2018, 02:27 PM   #43 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Thanks! And no problem
Old 12-20-2018, 08:11 AM   #44 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Gluing the other motor mount together.
Old 12-20-2018, 08:14 AM   #45 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Doing more welding. Finally getting pretty decent with this setup.
Old 12-20-2018, 08:16 AM   #46 (permalink)
Alpine_CJ5's Avatar
Member # 856318
More electrical stuff. Also got my grille back on.
Old 12-20-2018, 08:21 AM   #47 (permalink)
Member # 120626
dig the build. Makes me miss my 5.
Next time you send out plasma work, shoot me a message. I Noah guy.
mechanicalmongoose20 is offline   Reply With Quote Quick reply to this message
Old 12-21-2018, 07:27 PM   #48 (permalink)
Member # 127171
Attachment 2912274
Why all the nice wiring, and using these instead of heat shrink connectors?
sleepsontoilet is offline   Reply With Quote Quick reply to this message
Old 12-21-2018, 08:22 PM   #49 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Valid question, haha. These are temporary until I get that sheet metal cover I showed a few posts ago made.
Old 12-21-2018, 08:29 PM   #50 (permalink)
Alpine_CJ5's Avatar
Member # 856318
Thanks!
I kinda get the homie hookup right now for plasma, but it canít hurt to get a quote at least. Itís still far from free.
