Steering box input shaft question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-08-2019, 07:36 AM   #1 (permalink)
Member # 873114
Looking at using Herm's steering box upgrade for my 67 CJ5/V6. Herm recommends using the Ford reverse rotation steering gear from 80-97. Every one I looked up has an 3/4" input shaft with a spline count of 29 with a flat. Is this the same as the very common 3/4" steering U Joint with a spline count of 36 by not counting the splines on the flat?
Gkesseru is offline   Reply With Quote Quick reply to this message
Old 10-08-2019, 10:29 AM   #2 (permalink)
NERD
gtxracer's Avatar
Member # 25303
I believe it is. I have a few steering yokes and joints at home I can check. But I believe you are correct. You can count half of the splines on the shaft with the flat and double that number and compare to known spline and diameter options. I think that's what I did while ordering.
97 TJ Build:
2013 Raptor SuperCrew Tow Rig
Porsche
Fab Parts:
PNW Shock Tuning:
gtxracer is offline   Reply With Quote Quick reply to this message
Old 10-10-2019, 02:18 AM   #3 (permalink)
arse_sidewards's Avatar
Member # 256962
Yes. 3/4-36 is what you want.
