Mild LJ Build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-13-2019, 11:59 PM   #1 (permalink)
nkldrgr's Avatar
Member # 44053
Mild LJ Build
Well, since LJs seem to be so popular these days, I figured I'd post mime.
I picked up this 2005 Jeep LJ (non 'con) and decided I build it. I decided to do a one-ton swap. I'm using an '88 Ford F-350 Dana 60kp and a 2007 14 bolt.
It only take two things to fly: airspeed and money.
nkldrgr is offline   Reply With Quote Quick reply to this message
Old 11-14-2019, 12:05 AM   #2 (permalink)
nkldrgr's Avatar
Member # 44053
Some progress from the front axle
Old 11-14-2019, 12:08 AM   #3 (permalink)
nkldrgr's Avatar
Member # 44053
Dana 60 in the Jeep
Old 11-14-2019, 12:12 AM   #4 (permalink)
nkldrgr's Avatar
Member # 44053
Removed one of the rear cross members in order to move the fuel tank back. It was really easy and gave me room to move the rear axle back.
Old 11-14-2019, 12:14 AM   #5 (permalink)
nkldrgr's Avatar
Member # 44053
Got the rear axle home. Damn, it took a long time to cut off all of those GM brackets.
Old 11-14-2019, 12:17 AM   #6 (permalink)
nkldrgr's Avatar
Member # 44053
More progress on the rear end.
Old 11-14-2019, 12:21 AM   #7 (permalink)
nkldrgr's Avatar
Member # 44053
I threw in some 5.13 gears and an Eaton E-Locker to round out the axles. It's turning 37" Maxis Trepadors on Method trail series. Next week I'll start on the bumpers and sliders. Then tub corners and tube fenders.
Trevor and the crew at WFO Concepts really helped me along the way. I can't recommend them enough.
Old 11-14-2019, 08:23 AM   #8 (permalink)
Member # 31211
Looks good. Looks like a nice truss/swap system from WFO. What did you do about the standard lug pattern on the 60 vs metric on the 14 bolt?
charlieboyd65 is offline   Reply With Quote Quick reply to this message
Old 11-14-2019, 10:45 PM   #9 (permalink)
nkldrgr's Avatar
Member # 44053
The 2007 GM 14 bolt is not metric. It's still 8x6.5. Pretty awesome when you get a stout axle with factory disc brake and an e-brake. And it'll match an older Dana 60.
Old 11-15-2019, 09:02 AM   #10 (permalink)
Newbie
g23crawler's Avatar
Member # 136736
What 4 link/skid plate is that?
g23crawler is offline   Reply With Quote Quick reply to this message
Old 11-15-2019, 10:36 AM   #11 (permalink)
nkldrgr's Avatar
Member # 44053
It's a Rubicon Express pan. I'm NOT using the rear upper link mounts. I used some brackets from WFO Concepts that are much stronger and allow more triangulation.
Old 12-11-2019, 12:36 AM   #12 (permalink)
nkldrgr's Avatar
Member # 44053
I finally finished my front bumper. Its nothing special. Unfortunately, shipping one to Sitka is more expensive than the bumper costs in the first place
