1972 CJ-5 Buildup Project - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-20-2006, 10:51 AM   #126 (permalink)
pmaddy's Avatar
Member # 3781
Few more pics. Cut some slots in the tailgate ribs so I could bend it to follow the cage line.
pmaddy is offline   Reply With Quote Quick reply to this message
Old 05-20-2006, 10:52 AM   #127 (permalink)
pmaddy's Avatar
Member # 3781
another
Old 05-20-2006, 10:55 AM   #128 (permalink)
pmaddy's Avatar
Member # 3781
side
Old 05-20-2006, 10:57 AM   #129 (permalink)
pmaddy's Avatar
Member # 3781
nutha
Old 05-20-2006, 10:58 AM   #130 (permalink)
pmaddy's Avatar
Member # 3781
yup
Old 05-20-2006, 11:05 AM   #131 (permalink)
pmaddy's Avatar
Member # 3781
Bring on the Big Daddy
Going to swap out the trusty 304 for this 1977 401 I picked up. Will be sending my Howell fuel injection back for some rework to accomodate the big daddy. If anyone's interested in a 304 with around 30,000 miles let me know. It is built to stock specs with exception of an RV Cam.
Anyone running a howell efi on a 401, curious if should go with a bigger throttle body all together or just upgrade to larger injectors on the 304 throttle body? Any advise or experience?
The 401 internals are currently stock but down the road I am going rebuild for some horsepower and don't want to be swapping throttle body's so I would like something that is flexible enough to accomodate both setups.
Old 05-20-2006, 06:54 PM   #132 (permalink)
Member # 45206
Man your rig is killer, nice work.
74 CJ5- The BarnBurner
#1 Z71 is offline   Reply With Quote Quick reply to this message
Old 05-20-2006, 09:32 PM   #133 (permalink)
RG
Member # 20020
Sweeet!
It's about time you updated some pics. It looks better than you described. Really nice lines.
Keep it up! You (unlike myself) are in the home stretch.
Regards, RG
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety."
Benjamin Franklin
RG is offline   Reply With Quote Quick reply to this message
Old 05-20-2006, 10:03 PM   #134 (permalink)
bronko's Avatar
Member # 18748
Damn nice CJ can't wait to see it painted.
Bummin around in a SAS'd 88 Toy w/ a 3.4 :flipoff2:
bronko is offline   Reply With Quote Quick reply to this message
Old 05-20-2006, 11:22 PM   #135 (permalink)
WA-HCRC's Avatar
Member # 39184
whats the CFM rating on your current throttle body? it just meters air, so more probably wouldnt hurt, am i correct? what are the size incriments that howell jumps? man, your gonna cry the first time you wreck a rear quarter panel.
WA-HCRC is offline   Reply With Quote Quick reply to this message
Old 05-21-2006, 01:26 AM   #136 (permalink)
Member # 67882
Hey pmaddy what seats are does ????
120 fabrication
Two fj40s on 60s
fj40forlife is offline   Reply With Quote Quick reply to this message
Old 05-21-2006, 03:58 AM   #137 (permalink)
LCAC_Man's Avatar
Member # 35307
Originally Posted by pmaddy
Another of the 1.5 inch .120 tubing that will be my shackle hanger.
The measurement from spring hanger bolt center to shackle hanger bolt center ended up being 42.5 inches. Not sure if this is stock YJ measurment but I wanted my shackles to sit at about 30 degrees. I couldn't have them sitting at too much more of an angle or my spring on the shackle side would hit the frame at full compression. Planning on running a 6.5 inch shackle.
How did this setup work for you, are you happy with your shackle angle?
Looking at doing the same thing on my Commando I'm running RE 1.5" YJ SOA springs and was thinking in the 43" range, my 5.3 will be lighter but I've got more sheetmetal hanging up there and have an 88Lbs winch going up front too.
Len Barron
LCAC_Man is offline   Reply With Quote Quick reply to this message
Old 05-22-2006, 03:36 AM   #138 (permalink)
beyer05's Avatar
Member # 27999
Love your rig man.
As for the throttle body, I will bet they suggest a larger one (454) as they did when I asked the same question.
beyer05 is offline   Reply With Quote Quick reply to this message
Old 05-22-2006, 06:41 AM   #139 (permalink)
Member # 30549
I hope you are boxing that frame?
79 CJ-5,Stroked Axle Breakin Dodge 408 on pane,435,205,Rockwells,Hummers,47LTB's,home built
792.5cj5 is offline   Reply With Quote Quick reply to this message
Old 05-22-2006, 08:42 AM   #140 (permalink)
pmaddy's Avatar
Member # 3781
Its already boxed up past the upper link mounts but I do intend to box it the rest of the way.
Thanks for the info on the throttle body beyer05.
Those seats are PRP competition High Backs purchased from one of the vendors on the board. Go check out that thread for exact specs and colors.
Old 05-22-2006, 08:43 AM   #141 (permalink)
pmaddy's Avatar
Member # 3781
I haven't run it yet so I realy can't say. I was limited by my clearance under the frame rail but we will see how it works out.
Old 05-31-2006, 03:42 PM   #142 (permalink)
Member # 15424
You do very good work and that jeep is sexy. I dont know if you have thought about this already, but the tubing that runs parallel to the body is really taking away from the beautiful body work. I did notice that you put another parallel section of tube in above the tailgate, so I wonder if you have thought about it already. Seeing how it is just tacked at this point, would it still be an option at all, to tuck that tubing down lower with the tub? Just my .02, as I could certainly never do as good of a job as you in the first place.
90YJ | HDOR | WEBILT | ID4x4A
gripguru is offline   Reply With Quote Quick reply to this message
Old 06-01-2006, 09:56 AM   #143 (permalink)
WWDD?
Sluice Sally's Avatar
Member # 12133
Send a message via AIM to Sluice Sally
Very cool! My hubby is building a '71 for me. Looks like yours will be on the trail before mine though
~Jen Lillund
KI6TMA
"Chicks Dig Band-Aids"
Sluice Sally is offline   Reply With Quote Quick reply to this message
Old 06-10-2006, 04:14 PM   #144 (permalink)
Member # 4658
any updates?
TBM Jeep is offline   Reply With Quote Quick reply to this message
Old 06-20-2006, 12:42 AM   #145 (permalink)
Member # 12429
You've done some since i`ve seen it last!!! more than i've done on my junk
Update?S?!
Todd W is offline   Reply With Quote Quick reply to this message
Old 06-20-2006, 04:10 PM   #146 (permalink)
Member # 41947
I like the way you mounted your coils, looks clean! I am wondering about the bar that you mounted them to on the top. Are you going to add any support to it? Is it regular DOM (.120 wall)? I would worry about it bending. I am trying to figure out how I am going to do mine.
Great looking build!
iispms is offline   Reply With Quote Quick reply to this message
Old 06-20-2006, 04:49 PM   #147 (permalink)
Member # 50279
How tall is the rear seat, compared to your kids? I like the angled roll bar look best, but will they have some growing room?
18to80DDC is offline   Reply With Quote Quick reply to this message
Old 07-29-2006, 11:53 AM   #148 (permalink)
pmaddy's Avatar
Member # 3781
Well it's been awhile and here's the progress I have made.
- Plumbed all my Brakelines. Kiethflux in the vendor section offers a 5 line kit that comes with all mounting brackets and hardware. His kit is top notch and is money well spent. You won't find much better customer service either, great vendor. Here is a link. https://www.pirate4x4.com/forum/showthread.php?t=291865
- ADCO drivelines did a nice job on my rear shaft. 1410's on each end. 3 inch 3/16 wall tubing with a long slip.
- Pulled my 304 to make room for the 401 I have been pulling together.
- Started mocking up fuel cell.
- It took a few trips back and forth to finally figure out the my dana 60 has 10mm 150 pitch banjo bolts on the calipers. Kinda wierd.
Old 07-29-2006, 12:00 PM   #149 (permalink)
pmaddy's Avatar
Member # 3781
Keiths brake lines are real nice. Props on a sweet product.
Few shots of line routing.
Old 07-29-2006, 12:05 PM   #150 (permalink)
pmaddy's Avatar
Member # 3781
Kit comes with a brackets for eveywhere your lines mount.
You can kinda see the ADCO driveshaft in there.
