wagoneer Dana 44 help TJ...Just read if u know axles - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-22-2006, 03:45 PM   #1 (permalink)
Member # 62903
Send a message via AIM to prostock3
alright, i have a stock dana 30 on my jeep, its a 2000 TJ. im upgrading a lot of stuff...i have a way to get a dana 44 off a Ruby but i hear its not that much better..its only the housing so ill use my stock dana 30 knuckles and brakes, and by cromly axle shafts if i go down that road...or i can do out and get a dana 44 off a wagoneer and find a way to get it to either stock 5x4.5 or 5x5.5 i need to go with either lug pattern due to my rear axle....i want to keep the stock 60wms i dont want to go full size due to the fact i dont like the look..but im going to run 37's and i have only have heavy foot when im in mudd....or in the sand... by the way i got a 8.8 off an explore in the rear and its 5x4.5 but i belive and correct me if im wrong but an 01 E150 has an 8.8 in the rear and its 5x5.5 so ill just get the axle shaft shorten and resplined..so should i go with the Ruby 44 build? or should i go with the wagonner build?
2009 Twisted Customs buggy----sold
Next buggy build after the garage is finished.
prostock3 is offline   Reply With Quote Quick reply to this message
Old 02-22-2006, 03:51 PM   #2 (permalink)
thump93yj's Avatar
Member # 14874
click here
-clint
Secret black text says... Buy my Stuff!
For Sale:
thump93yj is offline   Reply With Quote Quick reply to this message
Old 02-22-2006, 03:55 PM   #3 (permalink)
bp95yj's Avatar
Member # 36471
not really hardcore but...
the rubi 44 will be weaker, since it has stock dana 30 tubes and outers. It will also not have manual locking hubs.
On the other hand the waggie axle will cost alot, with a bracket kit and swapping the outers over to 5 on 5.5, and regearing (assuming that the rubi is geared correctly)
if you went with the waggie axle you could just get wheel spacer to go to 5 on 5.5, for the 8.8 rather than making custom shafts.
IMO go with the waggie 44, but be prepared to spend some money on all of the items listed above, for the waggie axle
Brandon
Appalachian Offroad
Westminster, Maryland
410-848-2942
95 yj, 104" wb (waggy front and 4 link rear), stock 4.0L, sm465, 4.3 atlas, hp 60, 14bolt, detroits and 5.38's, 39" krawlers on allieds
bp95yj is offline   Reply With Quote Quick reply to this message
Old 02-22-2006, 03:55 PM   #4 (permalink)
Ford Bigot
FordFascist's Avatar
Member # 31227
Get your flame suit on.
Waggy axles are 59.5 and there is no way to convert them to a 5 x 4.5 bolt circle without swapping to late-70s early-80s Dodge D44 drive flanges which suck IMO. Your best bet is a set of Waggy 44's out of a post '80 Wagoneer.
The E150 would either have an 8.8 or a 9.75 rear and have a bolt pattern of 5 x 135mm.
Try searching next time as this sort of question comes up a lot...in the newbie section.
Originally Posted by MtnYota
It sucks I took a dump earlier, now I'll never know if that roll would have caused me to crap my pants
FordFascist is offline   Reply With Quote Quick reply to this message
Old 02-22-2006, 04:51 PM   #5 (permalink)
Member # 24475
Send a message via ICQ to JeffsJeep04 Send a message via AIM to JeffsJeep04
Waggy rear axles are ~59 (80+ that he would be after), but the front is 62". Perfect for a short jeep. Go with the waggy axle.
JeffsJeep04 is offline   Reply With Quote Quick reply to this message
Old 02-22-2006, 05:54 PM   #6 (permalink)
biggin's Avatar
Member # 22183
Send a message via AIM to biggin
Stick with the 30 front. YOU will never break it
biggin is offline   Reply With Quote Quick reply to this message
Old 02-22-2006, 06:18 PM   #7 (permalink)
Member # 62903
oh alright then
Old 02-22-2006, 06:36 PM   #8 (permalink)
Member # 34271
why convert front and rear to 5x4.5. keep the front 6 and get spacers or alloys in the rear to change it to 6
Rizon is offline   Reply With Quote Quick reply to this message
Old 02-22-2006, 06:43 PM   #9 (permalink)
Member # 65100
Send a message via Yahoo to rustywagoneersdotcom
wow, now this is
yawn...
what was i saying?
oh, yeah, hardcore... this aint it...
not flaming... not flaming... will not flame... but dayum, this ain't hardcore
peace, Dave
It's just a good thing we don't get all the government we pay for.
rustywagoneersdotcom is offline   Reply With Quote Quick reply to this message
Old 02-22-2006, 07:12 PM   #10 (permalink)
Member # 44579
You can order new rear shafts from moser withthe 6 bolt pattern to match the front or get ford 5.5" outers for the front and buy new shafts for the rear since the stock flange is not large enough for a 5.5" bolt pattern.
[b][ ] [u]l l l l l l l[/u] [ ][/b]Save your money for gears and swampers then save money on your lift by cutting out your fenders.
TACH329 is offline   Reply With Quote Quick reply to this message
Old 02-22-2006, 10:46 PM   #11 (permalink)
Member # 65809
i just did the waggy front n rear axles in mine i kept it all 6lug . sold the rear dana 44 to cover alot of the building costs of the new rear axle .. now if you keep the rear axle and use adaper / spacers you CANT go from 5 on 4.5 to 6 lug but you can go 5 on 4.5 to 5 on 5.5 and swap out the front waggy parts to make it 5 on 5.5 .. go with the waggy axle you can do more to it then the rubi axle ............
well to convert my waggy d44 to be coil sprung it was 307.00 for the bracket kit from a vendor on this board then another 175.00 for gears and install kit ...depends on how indepth your gonna go with it i also went flat tops & high steer arms , 1.5 dom tie rod , drag link with hiem joints and USA Alloy shafts warn premium hubs & a Power lock... i would guess i have about 1600.00 or more into my front axle..alot of these vendors on here have awesome deals ya just have to check around
CreepyCrawler is offline   Reply With Quote Quick reply to this message
Old 02-23-2006, 07:08 AM   #12 (permalink)
Member # 19579
Aren't there other D44 applications that are already coil sprung??
I'd definately go with something custom - NOT the Rubicon D44 unless you can get one for next to nothing or free.
I would do some research and find out how much it'll cost you to get a Waggy 44 and convert it to coil spring.....and what all needs to be done.
Find out the total cost....If you're NOT doing the fabrication work yourself - it'll get expensive.
I would compare the above 'cost' with the cost of a NEW D44 from one of the axle companies like Currie (for instance). They'll be expensive but you can order anything you want and it'll bolt right in AND have a warrantee.
Izzy II: Lifted, locked, and ready to rock!!
Janster is offline   Reply With Quote Quick reply to this message
Old 02-23-2006, 07:53 AM   #13 (permalink)
ItsaCJ6's Avatar
Member # 6340
Since you have more money than brains. Call currie, order axle, install.
shameless plug.....For the best deal on 8 lug disc brakes click here-->
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote Quick reply to this message
Old 02-23-2006, 08:03 AM   #14 (permalink)
biggin's Avatar
Member # 22183
the r.e. brakets to convert any 44 to tj controlarm/coilsprings are all over ebay. IIRC they were less than $300. Seriously though, I have a freind that wheels hard in a tj with 36 tsl's and the 30 front has never given him any problems. How many times have you broken something on your front?
Old 02-23-2006, 10:48 AM   #15 (permalink)
Member # 19016
Originally Posted by CreepyCrawler
.. now if you keep the rear axle and use adaper / spacers you CANT go from 5 on 4.5 to 6 lug...
Sure you can. MORE makes spacers/adapters that go from 5x4.5" to six lug. They're $250 for the pair and at least 2" wide (each). Not worth it, IMO, but it can be done.
Devin
DevinB is offline   Reply With Quote Quick reply to this message
Old 02-23-2006, 02:39 PM   #16 (permalink)
JnJ
Member # 763
Opps, sorry, I read and I don't know about axles. Oh wait, neither do you.
JnJ is offline   Reply With Quote Quick reply to this message
Old 02-23-2006, 07:19 PM   #17 (permalink)
Member # 65809
hmm when i called a place that makes adaptor to see about getting some they said the 6 lug shares a hole with the 5 on 4.5 and cant be made ..
[Originally Posted by CreepyCrawler
.. now if you keep the rear axle and use adaper / spacers you CANT go from 5 on 4.5 to 6 lug... ]
Devin
Old 02-24-2006, 10:26 AM   #18 (permalink)
Member # 19016
Email to Mountain Offroad:
ME:
Is it possible to go from 5x4.5" to 6x5.5" ? How much would those be? How thick? Thanks again.
MORE:
It is possible to do an adapter for that but it is going to be a 2 piece adapter and would need to be at least 2” thick. The would run you $250 for a pair.
There's a guy on this board that actually has these adapters on his jeep (can't remember his name). I'm not spouting off crap. They CAN BE MADE.
Old 02-24-2006, 10:32 AM   #19 (permalink)
Member # 65809
yeah thats doubling adaptors to make it . its not possible to do it in a 1 piece ... who would want 2 inchs of adaptors anyway
Old 02-24-2006, 10:46 AM   #20 (permalink)
Member # 19016
I didn't realize you were meaning one piece, I thought you were just saying it couldn't be done, period.
2" of adapters would suck, I agree. But some people have them.
Old 03-01-2006, 05:00 PM   #21 (permalink)
Member # 37212
You must be joking right? We pull Jeeps with Broken D30s out of ditches, holes, hills, rocks all the time. There are all kinds of reason not to run that D30.
If it were me, I'd build the Waggy axle. I'd keep the 6 lug and buy stock replacement shafts for your rear that have 6 lug flanges. I think that will be your cheapest solution.
Look up MR. N. His website has all the info you'll ever need on D44 axles. Find a 74 to 76 waggy axle. It will already have flat top knuckles for high steer. You don't have to do that right off but you'll be happy you have them later when you decide to do high steer. You'll have to put new perches on it and make it a spring over too. I can get those axles for $200 up here in Oregon. I'm sure you can find one in a junkyard for $350.
Good luck . . .
Chass
ct
Tuna!
Chass is offline   Reply With Quote Quick reply to this message
Old 03-01-2006, 05:17 PM   #22 (permalink)
Member # 24475
Originally Posted by Chass
...Find a 74 to 76 waggy axle...
Lots of good advice in there, but for his application, I'd look for an 80+. Much easier to bolt flat top knuckles onto an 80+ axle then going through getting a new tcase, re-routing exhaust, and re-doing cross-members.
Old 03-01-2006, 05:29 PM   #23 (permalink)
Member # 62903
thanks everyone...after talkin to some more people about it, im just going full 60 front and a 60 rear or 14bolt
