High steer arms - tre or heim joints? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-28-2007, 10:14 AM   #1 (permalink)
Member # 83197
I'm getting ready to order me a set of these, and need to know which end is better to use. If I go with the tie-rod ends, I'm going to have to have them taper the holes, otherwise I could use heim joint. How do heims work if you don't have a tapered bolt to keep them tight? Won't they eventually develop play either in the joint or around the bolt hole?
dogsofwar is offline   Reply With Quote Quick reply to this message
Old 01-28-2007, 10:16 AM   #2 (permalink)
Member # 38564
tre's are usually better for vehicles that see a lot of street use. i personally went with tre's because i felt they had more misalignment than similar heims.
xj4life is offline   Reply With Quote Quick reply to this message
Old 01-28-2007, 11:38 AM   #3 (permalink)
rckjeep's Avatar
Member # 9246
Send a message via Yahoo to rckjeep
Ya I also went with TRE's. Any high steer arm will have an option to have a tapered hole. Just decide which TRE to go with first being that they don't all use the same taper. I went with chevy 1 ton TRE's extremely solid and with a 7/8" threaded shank you really can't go wrong. Also Heims are not DOT approved and if your state does inspections they will notice.
_____________________________
Contact me for info about Low Rangers 4WDC
rckjeep is offline   Reply With Quote Quick reply to this message
Old 01-28-2007, 03:20 PM   #4 (permalink)
Member # 85837
Are you talking about the drag link, or the tie rod?? I see that all over, that 7/8" is larger than Jeep uses, but my OEM YJ tie rod's TREs are already 7/8". The drag link is smaller though. I want to build a beefy replacement for the OEM tie rod, but I'm hesitant to buy the 7/8" size TREs and tube inserts because Poison Spyder and such say the 7/8" TREs might have a larger taper than my knuckles.
'93YJ, '02GM 4.3VortecV6, SOA, ARBs, 8.8, WarnHubs, 35" KM2's, YorkOBA, lotsa me welded stuff.
JeeperDon is offline   Reply With Quote Quick reply to this message
Old 01-28-2007, 03:36 PM   #5 (permalink)
Member # 24640
I using TRE's on a set of parts mike arms...I havn't put a whole lot of use on them but I'm happy enough with them that I'm keeping them after I go full hydro next month or so
jmhinescj is offline   Reply With Quote Quick reply to this message
Old 01-28-2007, 03:44 PM   #6 (permalink)
Ford Bigot
FordFascist's Avatar
Member # 31227
Heims will work without a tapered hole to keep them tight, but you need to drill the hole perfectly. With that said, I chose to run Chevy TREs on my highsteer application. I like being able to buy replacements at most auto parts store, it's not easy finding 3/4" heims at the local parts store.
There is also a higher degree of misalignment in most TREs than similar strength heims.
Originally Posted by MtnYota
It sucks I took a dump earlier, now I'll never know if that roll would have caused me to crap my pants
FordFascist is offline   Reply With Quote Quick reply to this message
Old 01-28-2007, 05:15 PM   #7 (permalink)
Member # 1636
I have been running "1 ton" GM TRE/DLE's for the last 2 seasons and honestly I wish I had never touched them. They bend if you look at them the wrong way. I've got a wasted one on my Jeep now. I lost track of how many I bent. I usually just take them to the auto parts store and get them swapped out but I'm getting sick of bending them every other trip.
I'm placing an order for some 3/4 FK heims this week. A quality heim (not a cheap one) will outlast a conventional taper end, and will still be quiet without any slop.
That whole argument about street use is bullshit, I do not agree with it at all. A couple people I wheel with have street/trail rigs with heims on all steering joints (Janster on here being one of them). Both Jeeps pass PA inspection and see regular street use, and both have been running these joints for a few years with no slop or noise.
chris demartini is offline   Reply With Quote Quick reply to this message
Old 01-28-2007, 07:06 PM   #8 (permalink)
LCAC_Man's Avatar
Member # 35307
You can buy a reamer and do it yourself. I just made some progress on my steering this weekend.
Len Barron
LCAC_Man is offline   Reply With Quote Quick reply to this message
Old 01-28-2007, 11:15 PM   #9 (permalink)
Member # 8298
Send a message via AIM to CornbredNE
Are those arms the Hummer clearance arms that you often see on ebay? If so what is your opinion of them? Is the quality good?
David
CornbredNE is offline   Reply With Quote Quick reply to this message
Old 01-29-2007, 06:14 AM   #10 (permalink)
Member # 66280
David
those look like the hummer arms that Harsh Terrain sells, not sure If they sell on Ebay, but I love the harsh terrain 60 arms, they are made well
I am also using GM 1 ton tre's
Just a little buggy
guffey24 is offline   Reply With Quote Quick reply to this message
Old 01-29-2007, 07:37 AM   #11 (permalink)
LCAC_Man's Avatar
Member # 35307
X2, fit and finish was excellent on the Harsh Terrian stuff, I also got the 1" spacers from them so that I didn't have to lower my box quite as much.
Len Barron
Old 01-29-2007, 08:15 AM   #12 (permalink)
Member # 1636
I would put at least 2 more grade 5 bolts on each steering arm
nice work
Old 01-29-2007, 09:55 AM   #13 (permalink)
Member # 83197
How much misalignment do you lose on heims? And what would happen if I tried to drop that side too far, past the point of a heim's movement? Would it break the joint?
Old 01-29-2007, 10:58 AM   #14 (permalink)
LCAC_Man's Avatar
Member # 35307
nice work
I knew one you fawkers would point that out. Still need to get studs ordered up.
And before anyone else says it I know I need a brace from the steering box to the opposite frame rail, it's in work.
Len Barron
Old 01-29-2007, 11:07 AM   #15 (permalink)
Member # 22267
Send a message via AIM to HEEPJEEP
I've never bent a "one ton TRE". You have to make sure to get the shorter shank ones and have then mostly cranked in.
The other prob you have is your tie rod is up front. When you are trying to turn into an obstacle you are putting the ends in compressiong, which is probably farily easy to buckle anything that size with those forces.
I run my tie rod behind the axle with the ram and when I turn into something my tie rod is in tension, and will never have an issue.
I wish there was a stud type thing that someone would make that would incorporate the same taper/ size as a "one ton TRE" but have a stud above with misalignment built in for a Heim to slide over and bolt on.
YJ and Corey-So buy some then. I've always wanted a pony. Ponies are badass. Do I have a pony? No.
HEEPJEEP is offline   Reply With Quote Quick reply to this message
Old 01-29-2007, 02:31 PM   #16 (permalink)
Ford Bigot
Member # 31227
You mean something like this?
http://bcbroncos.com/store/product_i...roducts_id=770
Old 01-30-2007, 02:30 AM   #17 (permalink)
Member # 22267
Yessssssssss..... I love it. Thanks! That it was I would run personally, really nothing to have wiggle and get loose with that piece.
Chris, what size are you running to hold up?
Old 01-30-2007, 06:18 AM   #18 (permalink)
Member # 1636
I run the biggest ones the auto parts store has and they do not hold up.
I don't understand how the tie rod will not be in compression when behind the axle. I bent these ends when my tie rod was behind the axle.
Old 01-30-2007, 06:36 AM   #19 (permalink)
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
He's talking about a situation where you're trying to shove the tire into an obstacle. With the tie rod in front it's pushing to rotate the knuckle in that way which can make the joint buckle/bend easier, where if it's behind the axle it's pulling to rotate the knuckle in that same way so you won't bend the TRE.
Granted though, there are situations where either setup would result in the same thing, depending on whether the front or rear of the tire was wedged.
The Alternative Rocker - Taurus SHO V6-powered, Explorer-framed, TTB-front, RCV'd, YJ-bodied east coast racer
Flying Pig Racing #512
vetteboy79 is offline   Reply With Quote Quick reply to this message
Old 01-31-2007, 06:48 PM   #20 (permalink)
Member # 49203
I heard that heim joints and rod ends weren't "technically DOT approved" for steering, is this bullshit?
33x12.5-15 BFG's, d30 w/ arb, 8.8 w/ arb, Rubicon Express 4.5 XD lift w/ rubicon monotubes, york onboard air.
budmanv6 is offline   Reply With Quote Quick reply to this message
