TJ Cage Inspiration Thread - Page 19 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-09-2011, 05:56 PM   #451 (permalink)
Member # 174088
Originally Posted by Beat95YJ View Post
Just get the Poly kit.
Since Poly no longer makes a full TJ/LJ cage if you were in my position would you just reuse the stock rear half of the LJ cage and add to it?
Your custom Poly Cage is sweet by the way. I might just end up driving to CA to get them to build me one like yours.
I still can't find out how thick the wall is on the tubing of the rear half of the factory LJ cage. Any ideas?
CTDJeeperman is offline   Reply With Quote Quick reply to this message
Old 02-09-2011, 06:10 PM   #452 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
I would run the add on kit before I bought two kits. Through the dash is important.
Poly has built 2 cages for me and some for my friends. Can't argue with the quality.
& Blaine
:tank:
Old 02-12-2011, 04:27 PM   #453 (permalink)
Member # 41337
Send a message via AIM to jeeppowermj
Anybody have any picsof a tj with no windshield and a cage that is raked back and has twin b pillar tubes like Tim camerons fat girl buggy. The copperhead Tj is close to what I'm looking for but just trying to get a little more rake on it.
[COLOR="DarkGreen"]Beat Leafsprung XJ[/COLOR]...[COLOR="Yellow"][COLOR="Orange"][COLOR="Yellow"]junk 1ton TJ in the works[/COLOR][/COLOR][/COLOR]
jeeppowermj is offline   Reply With Quote Quick reply to this message
Old 02-12-2011, 04:41 PM   #454 (permalink)
Member # 122014
I got my ideas here......
RandyYJ is offline   Reply With Quote Quick reply to this message
Old 02-12-2011, 09:27 PM   #455 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
that is really too close. But you could lower the seats a little or make sure your sholder straps are REALLY tight.
Action Fab is offline   Reply With Quote Quick reply to this message
Old 02-13-2011, 06:44 AM   #456 (permalink)
wallysheata's Avatar
Member # 21191
Sounds like my rig which is posted a few pages back in this thread.
wallysheata is online now   Reply With Quote Quick reply to this message
Old 02-13-2011, 02:06 PM   #457 (permalink)
upsidedown's Avatar
Member # 41781
Quote: "Ok guys I hope that the pics help - - this is what I am building -- as it is right now I have 2 inches from the top of my head to the bottom of the tube. However, there are no tube directly over my head - - so there is 3.75 inches from the top of my head to where the aluminum roof will be - - Do you all think that this will be enough room or am i going to crack my dome piece???"
I think that may be too close to your head. Hit a few good bumps and you will wish you had more room. I would leave 4-5 inches with padding on the tubing if it is positioned above your head. If you can move tubing forward or backward to position it so it is not directly above your head then you are better off in my opinion.
My B pillar spreader was above my head and I positioned it 5 inches toward the rear of the jeep to avoid smacking my head on it. Clifton Slay did the same on his LJ roll cage then runs a gusset from the vertical B pillar to the horizontal B spreader.
What if you let someone else taller drive your rig? May have issues.
98 TJ stretched to LJ, D60 Detroit, D70 ARB, Atlas 5.0, 4.6 Stroker, 38.5 SSR's
upsidedown is offline   Reply With Quote Quick reply to this message
Old 02-13-2011, 03:53 PM   #458 (permalink)
hurleygo3's Avatar
Member # 80862
I run no windshield and have some rake, but a single tube b piller.
Mike Johnson #43 7 time EMC KOH finisher, 6 top 5's
hurleygo3 is offline   Reply With Quote Quick reply to this message
Old 02-14-2011, 06:40 AM   #459 (permalink)
Blackjeep2's Avatar
Member # 98545
thanks for the reply upsidedown - - I am closer now to having this cage done - - I don't think that I am going to have a problem with head room now. I have almost 4 inches and there are no tubes directly over my head. If I put the ballistic tube clamps on it to make it more easily removable I can raise it more if i feel the need.
Blackjeep2 is offline   Reply With Quote Quick reply to this message
Old 02-14-2011, 07:09 AM   #460 (permalink)
Member # 47997
Who built this? I really like the way it looks.
Originally Posted by BENNY87 View Post
Heres mine..
Michigan
strangler is offline   Reply With Quote Quick reply to this message
Old 02-18-2011, 06:21 AM   #461 (permalink)
Member # 120695
Mine's pretty simple. Kinda hard to see, but there's cross bracing that goes from the harness bar down directly to the frame. Still need to tie seats into it. Just waiting on new seats.
05 one ton tj on leafs:flipoff2: 107"wb, 5.13's, 42 iroks, and a purple cage.
southernwonton is offline   Reply With Quote Quick reply to this message
Old 02-22-2011, 02:40 PM   #462 (permalink)
Member # 169579
can you still use your stock soft top? im getting ready to redo my factory junk cage and make one but i still drive the jeep to work every now and then and on the road sometimes so i want the top to still work.
apisonjeepwheeler is offline   Reply With Quote Quick reply to this message
Old 02-22-2011, 02:59 PM   #463 (permalink)
Member # 8108
The key to getting a TJ stock soft top to work with a new cage is to make sure the B-pillar is in the exact same location as stock for the bow mounts, and the windshield spreaders from the B-pillar to the windshield need to be in the same location and diameter for the door surrounds. If you can buy a new top, the Supertops use all new mounting points and are not cage dependent so you have much more flexibility in mounting locations.
570-385-3931--shop
570-385-3932--fax
MADE IN AMERICA---and proud of it!!!
Like us on
Follow us on
We also offer the best service and prices available on:
Advance Adapters
Clayton Offroad Suspension
Raceline beadlocks wheels
ORI struts and Radflo shocks
zachv is offline   Reply With Quote Quick reply to this message
Old 03-05-2011, 03:45 PM   #464 (permalink)
Member # 119281
There havent been my pics of how the cages are being tied into the frames. I dont want my cage to be bolted to the body, or to have the tub sandwiched between the cage plates, and was thinking of using the tube clamps at all six mounting points. (http://www.atozfabrication.com/store...p-Coupler.html) That way it can be removed easily. Guess my question is; would this be an acceptable, and safe way to mount the cage? Just seems like a cleaner way than using the plates, but I've never seen it done. This way I could just hole saw the tub, drop the tube thru the floor and weld it to the frame, and then use the tube clamp up top in the interior side where it would all come together.
We have done so much for so long, with so little.....That we can do anything with nothing.
itchy is offline   Reply With Quote Quick reply to this message
Old 03-06-2011, 03:08 PM   #465 (permalink)
Member # 62840
Originally Posted by JrP View Post
Here is mine. Started by Liquid Iron and changed by A to Z fabrication.
What was changed and why?
SpoolinU is offline   Reply With Quote Quick reply to this message
Old 03-07-2011, 10:36 AM   #466 (permalink)
Bushwhacker's Avatar
Member # 9138
Send a message via ICQ to Bushwhacker
This is one I'm almost finished with. She is going to Moab next week so I had to get what I could in and will fill in the rest when she gets back.
Removable front feet.
WEROCK Judge
RROCK Legends Competitor
97 TJ buggy,4.0,727,Atlas,D60,14B
Bushwhacker is offline   Reply With Quote Quick reply to this message
Old 03-07-2011, 10:53 AM   #467 (permalink)
B.A.R.K's Avatar
Member # 8540
For installation purposes or DD'ing?
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB
Nothing is stronger than stupid...
B.A.R.K is offline   Reply With Quote Quick reply to this message
Old 03-07-2011, 11:10 AM   #468 (permalink)
Member # 9138
Makes removal and installation alot easier. Its going to have to come back out again for more work and final paint. It will all be tied to the frame eventually.
WEROCK Judge
Old 03-07-2011, 11:55 AM   #469 (permalink)
Member # 66217
Has anyone run across a rear view mirror that will attach to the role cage? I currently have a 1.5” dia vertical tube that splits the windshield and would like to mount a rear view mirror to it but can’t find one. I would like to install one that is shaped somewhat like a stock mirror but something that doesn’t attach to the windshield anymore but to the cage. Thanks.
hierks is offline   Reply With Quote Quick reply to this message
Old 03-07-2011, 04:50 PM   #470 (permalink)
Rugger99's Avatar
Member # 22646
Randy...you need some door bars brother.... Hows the leg and will we be seeing you in April at Chocolocco?
" Never underestimate the power of idiots in large groups"
Rugger99 is offline   Reply With Quote Quick reply to this message
Old 03-20-2011, 03:29 PM   #471 (permalink)
Member # 125138
Not a TJ just a plain old YJ
YJ-N-WV is offline   Reply With Quote Quick reply to this message
Old 03-21-2011, 12:20 PM   #472 (permalink)
rkik's Avatar
Member # 34591
Mine that Dave at Gulf Coast Crawl Shop in Houston built ... it just went to get powder coated.
rkik is offline   Reply With Quote Quick reply to this message
Old 03-21-2011, 12:38 PM   #473 (permalink)
B.A.R.K's Avatar
Member # 8540
One of the first cages in this thread that I wouldn't want to change. Great design
What is the story for 1" tube out back and the welded eyelets?
Old 03-21-2011, 12:57 PM   #474 (permalink)
miguelitojeep's Avatar
Member # 73093
Bitchin' design
eyelets prob for harnesses and 1"tubing probably for rack? me likey a lots!
Overbuilt 97 Wrangler | 40" Black Labels, 14" Fox Coilovers, Trailing Arm Suspension, Atlas 4.3, Warn Winch, fully caged and tested
#BajaJeep @BajaJeep_mike
miguelitojeep is offline   Reply With Quote Quick reply to this message
Old 03-21-2011, 04:32 PM   #475 (permalink)
jeep09's Avatar
Member # 143697
Simple dual purpose weekend warrior cage, its also my air tank for OBA. It holds 4.7 gallons
____________________
2017 Jimmys Buggy
12v Chase Truck
LS Jeep on Tons
Team 4485 Genright
jeep09 is offline   Reply With Quote Quick reply to this message
