TJ Cage Inspiration Thread - Page 34 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-22-2016, 12:25 PM   #826 (permalink)
Member # 7624
Send a message via AIM to offroadman83
Keep em coming guys.........Ive gotta redo my cage here soon as its just not aesthetically pleasing and really has no rhyme or reason.
2000 tj with stuff
offroadman83 is offline   Reply With Quote Quick reply to this message
Old 04-04-2017, 03:22 PM   #827 (permalink)
Member # 700098
I'm looking for someone to draw a basic LJ cage with 6 points tied in with seat brackets. With so many on these pages it makes it hard to decide which is safe and which ones just look cool. I'm looking for function not form! Any help out there? I have a shop that will bend and weld but they have never done a wrangler just Cherokee's. Help!
06LJR
MACSDAD is offline   Reply With Quote Quick reply to this message
Old 04-12-2017, 12:27 PM   #828 (permalink)
Member # 749641
Has anyone tried mounting the stock back seat facing rearwards (like an old rumble-seat), so they can triangulate the B-pillar area and do a fastback style cage? Then the rear passengers could enter through the tailgate and have the main hoop above them for protection.
jcdj1996 is offline   Reply With Quote Quick reply to this message
Old 04-12-2017, 07:38 PM   #829 (permalink)
Jeepinpickel12's Avatar
Member # 621137
Yeah I had mine rear facing for quite a while. Everyone who road back there loved it. In the stock yj cage there is a bung that can be tapped to mount the belts to the main hoop. But as far as mounting just drill new holes and plate the underside so nothing could pull through and it's got some where solid to bolt down too.
Jeepinpickel12 is offline   Reply With Quote Quick reply to this message
Old 05-27-2019, 06:42 PM   #830 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Bump! Getting ready to do lj length cage. Iím concerned with trying to get the tj door surrounds to fit with a bend at the A pillar even if I notch the clamp. Iíve got a 1.75 x 7.5Ē radius die.
Or do I just notch it like a lot of the tj cages? @Beat95YJ really like you cage poly built what do you think? Also
Pics from earlier in thread for reference.
Old 05-27-2019, 07:12 PM   #831 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Mine had radiused bends. I had a supertop on it and iirc I didnít use the plastic surrounds. I donít remember notching the window surrounds if I used them.
Just starting to think about this for the LJ. I wish Poly or Goatbuilt offered a cage kit.
& Blaine
:tank:
Beat95YJ is online now   Reply With Quote Quick reply to this message
Old 05-27-2019, 07:21 PM   #832 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
I was wondering if you were having a cage built at this time.Do you think the notched A pillar would be a huge step down in strength?
Old 05-27-2019, 07:24 PM   #833 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Not at all. Weld it strong add a gusset/handle. It will do the job.
& Blaine
:tank:
Old 05-27-2019, 07:42 PM   #834 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Awesome thanks. Be easier to get a pillar out of plane too. Cause I ainít that good.
Old 05-28-2019, 10:22 AM   #835 (permalink)
gt1guy's Avatar
Member # 236179
Can you get your hands on a 5.5"radius die set? Makes a big difference and is as tight as you want to go with 1.75"
Kevin
gt1guy is offline   Reply With Quote Quick reply to this message
Old 06-01-2019, 06:45 PM   #836 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
No my buddies bender is 6Ē at itís not tight enough. Iíve ran into this several times with this die. But Iím doing what I discussed up above. Iíll gusset the shit out of it. Iíll post up pictures of the finished product.
Old 06-05-2019, 02:11 PM   #837 (permalink)
Member # 858948
No my buddies bender is 6” at it’s not tight enough. I’ve ran into this several times with this die. But I’m doing what I discussed up above. I’ll gusset the shit out of it. I’ll post up pictures of the finished product.
Is this a Yj tub? Are you going to use a yj windshield?
I'm building a cage in my YJ right now, I plan on using the TJ plastic door surrounds and tj upper doors with yj lowers, but I didn't know how well it meshed together with a YJ windshield. I plan on using a wrap around wind jammer for a tj and a yj bikini top. Kind of a custom cab top so to speak.
Also, since I'm here, my cage is mostly all tacked together, and I have an X brace in the B pillar, but in a moment of weakness(brain fart) I ran the cross bar from the top node to 6 inches above the bottom of the b pillar. I did this to make it easier to weld (the cage isnt gonna be able to be removed the welding will have to be done in the tub).
In hindsight im worried about essentially nullifying the x brace by not having it meet the floor node. This isn't a race jeep and it's not going to have to pass inspection, but what do you guys think?
dustin_the_wind is offline   Reply With Quote Quick reply to this message
Old 06-05-2019, 02:17 PM   #838 (permalink)
Member # 212988
Try to bring the B pillar out at far as possible or else your shoulder may be outside of the "cage" only thing I wish I did differently on mine.
HankScorpi0 is offline   Reply With Quote Quick reply to this message
Old 06-05-2019, 04:17 PM   #839 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
It doesnít fit perfect to the windshield frame as Iím using Cj/yj frame. But should seal better than the top that was on it. Iím going to document the top install well in my build thread as the few that were on here photobucket killed.
Old 07-05-2019, 02:21 PM   #840 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Hereís my somewhat finished cage. Still needs seat belt mounts and c pillar needs to be ran to the frame. I like how the a-pillar transition turned out.
I donít have an x at the b pillar as I have kids. And I didnít want something diagonal between b and c pillars. As on the trail itís easier to get kids and gear out. Far from perfect just rolling it around itís certainly heavier than my old one and stiffer.
Old 07-05-2019, 02:26 PM   #841 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Sorry I did t see your response. Hereís a thread where I document and lj/tj tip on Cj/yj. The angle on the doer opening is the same. The tj/lj windshield is leaned back more. Hence why itís fatter at the bottom of the windshield frame. From what Iíve read the tj door ďhoopĒ for the window is about 1/2Ē taller and thatís what refelects with how my Cj doors meet with door surrounds.
https://www.pirate4x4.com/forum/jeep...ed-please.html
Old 07-09-2019, 06:02 AM   #842 (permalink)
Member # 95086
'97 TJ: "3rd Life Crisis" LS/700R4/Atlas/Tons/42" Trep Stickies
'16 Mega Cab Cummins Tow Pig
ZSavage81 is offline   Reply With Quote Quick reply to this message
Old 07-09-2019, 06:19 AM   #843 (permalink)
Member # 95086
Old 07-09-2019, 03:07 PM   #844 (permalink)
gt1guy's Avatar
Member # 236179
@ZSavage81,
Rig looks great and obviously works. But that B-pillar X would keep me up at night not being connected to the B-pillar itself and having all those bend in it.
The X is the only thing that gives the B-pillar any strength.
I was kind of in the same boat with my JK. Ended up doing a double B-pillar just to have the X with no bends in it.
Kevin
Old 07-12-2019, 02:25 PM   #845 (permalink)
Member # 95086
@ZSavage81,
Cool story, I guess you don't have to ride with me then!
Old 07-13-2019, 10:02 PM   #846 (permalink)
Member # 3056
Your kidding right? That cage is so overkill you'd never have to worry about anything. Most race cars have a lot less
cage than that.
Steve Dalton----------96 Tacoma Truggy...gone but not forgotten!
Now rocking a 2005 TJ Rubicon
TANKOMA is offline   Reply With Quote Quick reply to this message
Old 07-16-2019, 12:43 PM   #847 (permalink)
Member # 29113
Send a message via Yahoo to pitchitpitchit
cage than that.
So what. Everything has room for improvement. His comments were valid.
pitchitpitchit is offline   Reply With Quote Quick reply to this message
Old 07-16-2019, 07:13 PM   #848 (permalink)
Member # 3056
My point is I think sometimes we forget that these are generally slow speed rollovers, we are not crashing at 200mph. And most cages we all build here are so overkill that it boarders on the side of rediculous, even for a 200mph crash. I'm guilty of it too, so I think you missed my point.
Old 07-17-2019, 11:59 AM   #849 (permalink)
gt1guy's Avatar
Member # 236179
My point is simply that we don't always get to pick when/where we roll.
Kevin
Old 02-15-2020, 05:02 PM   #850 (permalink)
Member # 800505
Sweet cage!
I like the gussets between b and c pillar. Im bending up my cage now and love all the ideas on this form.
JeBronco is offline   Reply With Quote Quick reply to this message
