TJ Cage Inspiration Thread - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-01-2007, 08:54 PM   #126 (permalink)
Member # 14233
i think this is B pillar triangulation, X behind the seats??.....
spinner is offline   Reply With Quote Quick reply to this message
Old 12-01-2007, 11:05 PM   #127 (permalink)
Member # 26188
Originally Posted by Mr Extreme Jeep View Post
Triangulation in the B pillar is something alot of you dont seem to take seriously. I also see alot of excessive cage work up high. Some of these cages would weigh more than the chassis. COG is too high.
Couple of good dones for inspiration. But there is no such thing as a perfect cage. Or is there?
Mines not done yet, here's where it should be soon. (excuse the crappy chop)
powdr7 is offline   Reply With Quote Quick reply to this message
Old 12-02-2007, 10:14 AM   #128 (permalink)
Member # 14233
found some petter pics
Old 12-02-2007, 10:24 AM   #129 (permalink)
Member # 8108
May I ask why not support the rear u-shaped hoop at the ends better? It would look much better and be stronger if the legs went from the bend starts on the U and went down to the bend starts on the down tubes near the C-pillar area.
570-385-3931--shop
570-385-3932--fax
MADE IN AMERICA---and proud of it!!!
Like us on
Follow us on
We also offer the best service and prices available on:
Advance Adapters
Clayton Offroad Suspension
Raceline beadlocks wheels
ORI struts and Radflo shocks
zachv is offline   Reply With Quote Quick reply to this message
Old 12-02-2007, 04:09 PM   #130 (permalink)
Member # 26188
Something of that sort is in the works. We're messing with ideas on how to get it supported and keep it looking clean. In retrospect, the "U" should have been made a bit bigger and then the tubes going from it down would be done easier and cleaner looking.
It'll probably get a gusset in there, or we'll run a tube down to the rear, or sides.
Old 12-05-2007, 10:23 AM   #131 (permalink)
Member # 14233
TTT for some more fun
Old 12-05-2007, 10:30 PM   #132 (permalink)
hater
Whaley Enterprises's Avatar
Member # 9900
I bought a boat and sailed off in it...
Whaley Enterprises is offline   Reply With Quote Quick reply to this message
Old 01-06-2008, 09:44 PM   #133 (permalink)
Rastus's Avatar
Member # 18861
Send a message via AIM to Rastus Send a message via Yahoo to Rastus
bump for a good thread
Rastus is offline   Reply With Quote Quick reply to this message
Old 01-06-2008, 11:04 PM   #134 (permalink)
OKIE ZUK's Avatar
Member # 14812
A customer wanted me to build him a PSC style cage. The only way I'd do it would be though the dash:
'94 Samurai, EFI, 6.1 t-case, twin sticks, 5.29 locked and shaved Toys, RS9000X's, HS9500i, OBA, Coiled, 36" IROK's, 94" WB, etc, etc.
OKIE ZUK is offline   Reply With Quote Quick reply to this message
Old 01-08-2008, 12:05 AM   #135 (permalink)
Rastus's Avatar
Member # 18861
Ok, question or two for you cage builders..
Is it better for the "B" pillar to be one piece and bring everything to it, or better for the "A" hoop to be one piece and the "B" pillar to be one piece and build to both?
I really like the cage the BTF did for Apeters jeep, and going through all the pics on his build and pic links it looks like the "B" pillar was bent and then all other tube was bent to attach to the "B" pillar.
I'm replacing the cage in my jeep in the next 2-3 weekends and I prefer strength over looks but I'm trying for both.
Old 01-08-2008, 01:30 AM   #136 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Originally Posted by tommaho View Post
Forgot about this. Mine in and done.
That is an awesome cage. Clean, simple and strong. I look at a bunch of cages on Pirate and see way too much irrelevant tubework. Nice strait clean tubework is where its at. Extra bends, "style" etc are a sign of weakness, and require too much additional tubing for strength.
& Blaine
:tank:
Old 01-08-2008, 01:39 AM   #137 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
I do not think that there is any strength difference as long as quality materials and design are used. I have notice I snag less trees and crap when the a and c pillar (or down bars) are continuous.
& Blaine
:tank:
Old 01-08-2008, 12:38 PM   #138 (permalink)
GiS
GiS's Avatar
Member # 31285
95% of Jeeps in this thread do not run a rocker bar....How are you tying the cage into the frame without it? Obviously you could run a 90 deg piece of DOM from frame to flange and sandwich the body...but now you have 2 or 3 horizontal bars extending from the frame for you to get hung up on...Instead of a smooth hoop parallel to the frame, seems to me it would slide better..
Rock Posse Racing #686
Driver: Joey Weber
GiS is offline   Reply With Quote Quick reply to this message
Old 01-08-2008, 04:37 PM   #139 (permalink)
Member # 14233
i have a small piece of tubing bent from the frame to sandwich the body. it is pretty tight to the body, never snagged on it yet. if i was to do it again i would cut the rockers and use tube like you are talking about.....
Old 01-21-2008, 06:11 PM   #140 (permalink)
Member # 17918
Send a message via AIM to imgonnasnap
I finally have something to add, thanks to stinkbug
https://www.pirate4x4.com/forum/showthread.php?t=649141
"Your life is one giant redneck moment"
imgonnasnap is offline   Reply With Quote Quick reply to this message
Old 01-21-2008, 10:03 PM   #141 (permalink)
Member # 63225
It looks a little sparce on that long wheelbase. Is it done?
TeenyCAR is offline   Reply With Quote Quick reply to this message
Old 01-21-2008, 10:09 PM   #142 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
too lazy to look at the other thread. What are the future plans for the rig? If it will remain approximately the height it is (~3") I think it will be fine. Also any pics near the dash? The lack of triangulation anywhere leads me to belive that this will be a low speed rock rig, or it will remain near stock.
& Blaine
:tank:
Old 01-22-2008, 10:39 AM   #143 (permalink)
Member # 17918
Plans not posted in the other thread...
But it is going to be built as a mild wheeler/exploration rig. I'd like to be able to drive it to the trail few hundred miles away, wheel and come home. With that being said its primarily a rock crawler, with the occasional haul ass down the wash. I'm going to add some gussets at some point, but for my uses, I believe it will be enough. deffinitly not as hardcore as some rigs here, but i'm also looking for a wider use than those.
it will be getting at some point:
super 30/44 kit with ARB's
4:1 tcase, sye, cv shaft
35-37 inch tires max
3.5 RE long arm kit
cut whatever sheetmetal to fit the tires, add some tube fenders..
Old 02-23-2008, 06:06 AM   #144 (permalink)
Member # 67642
Originally Posted by Brink_ View Post
Anyone got any more info on these? Very simple set up, I like it.
Don't correct me when I misspell Cabernet Sauvignon. I'm drinking it from a box. You missed your chance to help a long time ago.
Phantom1016 is offline   Reply With Quote Quick reply to this message
Old 02-26-2008, 04:38 PM   #145 (permalink)
Member # 69818
Send a message via AIM to tommaho
If I get your question, here's how I did mine. This was mid-project, but you can see the feet of of the 4 tie-ins up front:
Underneath the 4 feet are plates immediately under-side with tie-ins at about a 45 degree angle into plates welded to the frame. With a BL, they're at roughly the angle of body mounts. I hit them, but they've never given me problems.
FWIW, the X goes right through the floor, welded to frame, and rears are also plated under & tied to frame.
I'm not really sure what my though process was behind putting the effort into the bolt-together plates for 6 points and just cutting the floor for the X. I think it was probably ease of installation since this was my first big (for me) fab project. I like to think it's probably stout enough that it won't matter.
I'm not a welder.
Hip bars are going in when I don't have to drive this thing to work.
Thanks Beat.
Tom
tommaho is offline   Reply With Quote Quick reply to this message
Old 02-26-2008, 05:07 PM   #146 (permalink)
Member # 91657
Do you guys put any rubber between the sandwich plates on the body, or just metal on metal?
chevy79 is offline   Reply With Quote Quick reply to this message
Old 02-26-2008, 07:16 PM   #147 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Mine are metal to metal, with a bushing under the sandwich plate.
& Blaine
:tank:
Old 02-26-2008, 07:19 PM   #148 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
I really like this cage. It looks strong as hell. I think I would have tried to connect the bottom of the X to the b-pillar, but that would only be to prevent cutting the floor. Might have to do some funky bending to get around the seats though. I do think the way the X is done here is stronger though.
& Blaine
:tank:
Old 02-27-2008, 10:42 AM   #149 (permalink)
Member # 40015
I'm not a welder.
Thanks Beat.
Tom
This looks like the cage I built on here. It's good to see ideas floating around.
SLIPKOTJ is offline   Reply With Quote Quick reply to this message
Old 02-27-2008, 09:35 PM   #150 (permalink)
Member # 98135
x2
Epic Failure : When everyday, run-of-the-mill failure just isn't good enough!!
two_much_talk is offline   Reply With Quote Quick reply to this message
