Project 127 - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-24-2007, 12:47 PM   #51 (permalink)
miguelitojeep's Avatar
Member # 73093
this is going to be a tank with a jeep front end on it! great build!
Overbuilt 97 Wrangler | 40" Black Labels, 14" Fox Coilovers, Trailing Arm Suspension, Atlas 4.3, Warn Winch, fully caged and tested
#BajaJeep @BajaJeep_mike
miguelitojeep is offline   Reply With Quote Quick reply to this message
Old 10-25-2007, 04:37 AM   #52 (permalink)
pdm
Member # 97355
Exactly!!
*why did i just now find this thread?*
pdm is offline   Reply With Quote Quick reply to this message
Old 11-03-2007, 07:42 AM   #53 (permalink)
Member # 61182
Send a message via AIM to LumberJack5500
Sick buildup man, I may of missed it but how did you get the camo design on all your stuff?
https://www.pirate4x4.com/forum/showthread.php?t=625936
LumberJack5500 is offline   Reply With Quote Quick reply to this message
Old 11-06-2007, 09:16 PM   #54 (permalink)
Member # 46566
TTT for a cool build
CollegeJeeper is offline   Reply With Quote Quick reply to this message
Old 11-07-2007, 02:28 AM   #55 (permalink)
Member # 99991
this is a sick jeep loving it so far.. keep up the good work.. still wondering about your rad setup... how tall you looking to make this one? with the HUGe tires your running I'd imagine it'd be a good 3.5' to the bottom of the frame.. 4 linking it? good luck.. looks great!
killahxftjeep is offline   Reply With Quote Quick reply to this message
Old 11-07-2007, 06:20 AM   #56 (permalink)
Member # 102107
C-Man is offline   Reply With Quote Quick reply to this message
Old 11-12-2007, 06:47 AM   #57 (permalink)
BFJ
Member # 96629
LumberJack,
I'm a sign guy so I can get the Hardwoods vinal for cost.
Its a vinyl is applied to polycarb (lexan) then attached with pop rivets
Very easy, durable and cheap/quick to replace.
I think the tires will be out far enough that I will rarely rub the sides of the chassis.
BFJ is offline   Reply With Quote Quick reply to this message
Old 11-12-2007, 06:52 AM   #58 (permalink)
BFJ
Member # 96629
I'm Keepin it as low as fesible.
bottom of skid plate is 31 and bottom of frame is 33
I'm running the factory tj skid plate
I've been waiting 7 weeks for usa 6x6 to ship rockwell pans!!!!
They came in Thurs. so I got the axles in now and the wheelbase worked out to 130" (thank god for 4 wheel steer!)
I'll post pics this week
Old 11-12-2007, 07:14 AM   #59 (permalink)
Member # 30590
Originally Posted by BFJ View Post
You may want to put a stainless steel isolator between the brass fittings and the aluminum tank to prevent galvanic corrosion.
73jeep is offline   Reply With Quote Quick reply to this message
Old 11-12-2007, 06:22 PM   #60 (permalink)
Member # 51670
First off, friggin cool build! Ive been wondering how it would look to pull off a 4dr wrangler done diffrently than the big red one on here. I like the looks of yours!
Can I go out on a limb here and make a few guesses? I see Texas plates hanging in your garage, Im guessing you are in Texas. And the sign, well, thats a local bank as far as I know, so are you in the Texarkana area? If so I would LOVE to come check this build out as it would probably give me a kick in the nuts to get something done on mine.
If not, dissregard this message as just another Pirate idiot.
Kyle
ElkyRacer is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 07:19 AM   #61 (permalink)
BFJ
Member # 96629
Kyle
I'm in dallas but i bought my rockwell's in texarkanna... red river surplus baby!
Old 11-13-2007, 07:37 AM   #62 (permalink)
BFJ
Member # 96629
h1's recentered and reversed
(yea i know, But I hate the way the front looks!)
Front Axle mocked in
(yea i will be capturing the bolt on the upper and no it doesn't hit the frame)
Link mounts the axle
(yea i will be bracing the uppers alot)
Lastly, you will not find a panhard bar... why? because I haven't put it in yet.
Old 11-13-2007, 08:45 AM   #63 (permalink)
Member # 78458
looks good.. are you planning on moving the steering linkage up higher out of harms way?
jeeper8650 is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 09:28 AM   #64 (permalink)
BFJ
Member # 96629
no but i am going to sleeve it and bang the shit out of every rock i go over!!
Old 11-13-2007, 12:23 PM   #65 (permalink)
Member # 69441
Why didn't you triagulate the lowers? Then you don't need a panhard bar.
Lj stretched Dana 80s 47s coilovers 5.8 aodw 203 205
99grandtj is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 12:43 PM   #66 (permalink)
Trail Tampon
rajincajingt's Avatar
Member # 27333
is that upper link bent???
a panhard bar will be interesting with that huge center section
05 LJ stock
1976 C30 3+3 12V/47RH
instagram: LunchBoxFab
rajincajingt is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 01:13 PM   #67 (permalink)
Member # 56486
This is a sweet build.
Mr. 95YJ is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 01:28 PM   #68 (permalink)
BFJ
Member # 96629
This is the strongest link design
also I enjoy:
sliding on my lowers
Tire rub
having an unprotected transmission pan
Old 11-13-2007, 01:34 PM   #69 (permalink)
BFJ
Member # 96629
The center chunk will have a rock cage in front of the brakes. The panhard will connect to the top of that and the bottom of the frame. Putting it uphigh gives me a high roll center for stablity.
I've done a horrible job of explaining this but i do have a plan so check back in for undates
Old 11-13-2007, 04:27 PM   #70 (permalink)
vintagespeed's Avatar
Member # 25551
Send a message via AIM to vintagespeed Send a message via Yahoo to vintagespeed
what's the deal with the pre-bent upper control arms?
i dig the sheetmetal work!
-jb 'been here awhile.
vintagespeed is offline   Reply With Quote Quick reply to this message
Old 11-13-2007, 08:28 PM   #71 (permalink)
Addicted to Gear Oil
guidolyons's Avatar
Member # 56050
Nuthin' says "Big TexASS Redeck Jeep" like reclining nude trucker chick wheel centers and Realtree Hardwoods Camo
All that sweet fab work and uses a PVC glue can lid...
You know these are only $30...
guidolyons is online now   Reply With Quote Quick reply to this message
Old 11-13-2007, 09:00 PM   #72 (permalink)
Member # 45700
Awesome build, I've been watching this for a while.
Where'd you get the trucker chick gussets? I've been on the lookout for those for a while and haven't seen em yet.
bbaXJ is offline   Reply With Quote Quick reply to this message
Old 11-14-2007, 07:34 AM   #73 (permalink)
BFJ
Member # 96629
Had a buddy cut them and all brackets on his plasma cnc
I can email you the cad file if you're interested
also shawn
@ greatlake offroad (vendor section) can cut anything you want.
Old 11-14-2007, 07:38 AM   #74 (permalink)
BFJ
Member # 96629
Attachment 336259
Yea but where would the tech be in that!!
It might be ugly BUT
You can't accuse me of BOLT ON!!
And nothing says redneck like building a gas tank from the shit in your shed.
Old 11-14-2007, 08:54 AM   #75 (permalink)
Member # 91575
wow thats one kickass build. Keep on goin, im sure its goin to do great on the trail. I think you should paint everything to have a cool affect. Plus it would look clean.
cherokeefreak92 is offline   Reply With Quote Quick reply to this message
