YJ Erection - Page 10 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-05-2010, 08:28 PM   #226 (permalink)
Member # 8335
Originally Posted by Canyonmann View Post
SICK SICK SICK I like it alot.
dude that looks like full compression or close. if that is ride height you cant have much up travel.
Dude for my braked I was going to di the dual diaphragm thing. Why did u use the explorer MC?
Thats about 6" from full bump, it was alot of work to pull it off. Ride height will be 2" higher in front to get 8 up and 8 down.
The explorer m/c should work well since they came with discs from the factory. My stock jeep m/c was not that great with this setup. I didn't want to mess with dual diaphragm setup, maybe if I competed with it I'd consider it.
Partially Erect YJ
WideJ is offline   Reply With Quote Quick reply to this message
Old 07-07-2010, 07:30 AM   #227 (permalink)
Member # 126126
That LCG is awesome,,,,,quit dickin around so we can see it flex.
thanks for the info on the MC
We may not have it all together, but together we have it all. ROCK HARD & ROCK ON OFFROAD BROTHERS!
My Build
Canyonmann is offline   Reply With Quote Quick reply to this message
Old 07-08-2010, 07:57 AM   #228 (permalink)
Member # 8335
Let me clarify - I'm bolting that master cylinder onto the stock vacuum booster. Nothing real special going on there. When you mentioned dual diaphragm I thought you meant two dedicated master cylinders... like one for front and one for rear like the comp guys use. I don't know if the stock jeep vacuum booster is single or dual diaphragm.
Partially Erect YJ
Old 07-08-2010, 09:23 PM   #229 (permalink)
Member # 126126
The booster is much deeper and helps increase stopping power considerably
http://www.restorationperformance.co...6-Power/Detail
My Build
Old 07-18-2010, 06:32 PM   #230 (permalink)
Member # 8335
Hey Corbelli - found a little something that'll bolt a Hemi up to an NV4500
McLean dropped by today and lent a hand - made some angle stiffners that bolt up behind the rear corners.
Wrestled the fawked up body in line with these
All bolted up!
Ghey rotated cel phone pic, but its a sheet metal piece that'll tie in the body to the cage. Should prevent any unwanted vibration and stiffen it up a little.
Partially Erect YJ
Old 07-19-2010, 04:26 PM   #231 (permalink)
Member # 17751
What's the application on that bellhousing. I just did a sbc to nv4500 in my CJ but the next one might get a Hemi
Thanks.
One Way Up Racing Romans 10:9
flexj is offline   Reply With Quote Quick reply to this message
Old 07-19-2010, 04:58 PM   #232 (permalink)
Member # 8335
Thanks.
1994 to 2011 gasser 2500's. The 5.9L has the same bolt pattern as the Hemi.
Partially Erect YJ
Old 07-19-2010, 06:19 PM   #233 (permalink)
Member # 17751
thanks.
nice build, you have much more patience that I have.
Old 07-21-2010, 10:24 AM   #234 (permalink)
Gravy's Avatar
Member # 105716
looking good. The exhuast looks trick
00TJ 35sp60s 106wb
Fabing & Wheeling is about having fun. If not: You're doing it wrong
Gravy is offline   Reply With Quote Quick reply to this message
Old 08-04-2010, 10:18 PM   #235 (permalink)
Travismo's Avatar
Member # 116524
Send a message via AIM to Travismo
you my friend, have too much money
Travismo is offline   Reply With Quote Quick reply to this message
Old 08-08-2010, 09:21 PM   #236 (permalink)
Member # 8335
Partially Erect YJ
Old 08-09-2010, 09:37 AM   #237 (permalink)
Member # 140656
You should leave it just like that.
-Joe
Pirate Joe is offline   Reply With Quote Quick reply to this message
Old 08-09-2010, 09:55 AM   #238 (permalink)
8APrius's Avatar
Member # 150157
I think you could get it lower
8APrius is offline   Reply With Quote Quick reply to this message
Old 08-09-2010, 03:39 PM   #239 (permalink)
Member # 8335
Yeah, leave it here and claim 6" of up travel.
Ride height is 10" up from here!
Partially Erect YJ
Old 08-15-2010, 05:32 PM   #240 (permalink)
Member # 8335
For the first time in 2.5 years the Jeep saw the light of day. Not under its own power it took three of us to wrestle it onto the trailer.
Thanks to Ryan and Wyatt we got the rigs moved to the new shop.
I'm 5'11" standing next to it at full bump.
Passenger side lower link is temporary
Partially Erect YJ
Old 08-15-2010, 08:35 PM   #241 (permalink)
Member # 126126
That thing is bad ass looking,,,,,,,,,,,I luv it!! but I dont understand the design. I will need to see it work to comprehend just exactly how that thing will articulate. Just doesn't look practical. LCG holy FAWK!!
My Build
Old 08-15-2010, 08:43 PM   #242 (permalink)
Member # 8335
Pics were taken at full bump. For transporation it was lowered to its bump stops. Actual ride height is 8" taller up front and 10" taller in the rear. It'll all make sense.
Partially Erect YJ
Old 08-15-2010, 08:45 PM   #243 (permalink)
Member # 135736
So whats your belly height going to be with 8" up? What size tires are those again? (to lazy to look )
COPPERHEAD42 is offline   Reply With Quote Quick reply to this message
Old 08-15-2010, 08:55 PM   #244 (permalink)
513
Member # 121037
Absolutely sick Hurry up and get this thing done you're so close!
Matt - Dreaming of AZ wheeling.
513 is offline   Reply With Quote Quick reply to this message
Old 08-15-2010, 09:12 PM   #245 (permalink)
Member # 8335
Thanks! I'm trying to get this thing knocked out.
Belly is 18" to 19" depending on how agressive I get on the skid system. Tires are 40's.
Partially Erect YJ
Old 08-16-2010, 06:45 PM   #246 (permalink)
Member # 17751
My 4 yr old daughter would say that this jeep looks happy. It's always smiling
Old 08-16-2010, 07:09 PM   #247 (permalink)
gots_a_sol's Avatar
Member # 46168
that pic makes it look like its sticking its tongue out at you
-Joe
'00 Excursion - cummins/nv4500, 05+ coil suspension/dana 60
'54 International R112
gots_a_sol is offline   Reply With Quote Quick reply to this message
Old 08-16-2010, 08:53 PM   #248 (permalink)
Member # 6170
Even has eyebrows.
Looks sick greg!
Kevo
Ghetto Fab. is offline   Reply With Quote Quick reply to this message
Old 08-22-2010, 06:37 PM   #249 (permalink)
Member # 8335
Moving shops is alot of work!
Things are finding their home slowly. I might be able to actually do some work on the rig again soon.
Partially Erect YJ
Old 09-05-2010, 10:13 PM   #250 (permalink)
Member # 8335
Installed my new Pacific Fab wiring harness. It is very well thought out.
OLD
NEW
It comes with a fuse block, ignition relay, and dual fan relays. Very cool setup. Most important its LABELED
After I layed it out I noticed an unused sensor behind the intake. I think it is oil pressure... can anyone confirm this? (kind of hard to see in the pic...)
Also, I have done nothing with the steam ports. Any thoughts on plugging them?
It is the little tube in the pic.
Partially Erect YJ
