YJ Erection - Page 4 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-14-2008, 12:20 PM   #76 (permalink)
yj_on_rocks's Avatar
Member # 121394
I am in awe at this build. Very well thought out. Great work
About the headers - I've heard of the same length as well, but not the CW or CCW firing.
But another thought - what happens when you want to change wires or plugs. It looks like you'll be pulling the headers?
yj_on_rocks is offline   Reply With Quote Quick reply to this message
Old 10-14-2008, 12:30 PM   #77 (permalink)
]4RunnerKid['s Avatar
Member # 45812
Send a message via AIM to ]4RunnerKid[ Send a message via MSN to ]4RunnerKid[ Send a message via Yahoo to ]4RunnerKid[
looking sick brohams... glad to see you guys are back at it. New Years will be here before we know it
-Mikey-
Party Wagon
locked, geared, caged, topless, dents
2019 Tundra
]4RunnerKid[ is offline   Reply With Quote Quick reply to this message
Old 10-14-2008, 05:15 PM   #78 (permalink)
Member # 8335
Packaging has been a challenge throughout this build, we have been trying our best to minimize conflicts like that. Sometimes they're unavoidable and I'm not too concerned about changing the plugs.
Originally Posted by FrkyMnky1487 View Post
Can you get a picture of the lower link mounts please?
They are Poly Performance high clearance mounts on the frame and regular link bracket on the axle side with Johnny Joints. I don't have any pics of them on hand.
Partially Erect YJ
WideJ is offline   Reply With Quote Quick reply to this message
Old 10-15-2008, 09:09 PM   #79 (permalink)
Member # 62837
This thing is amazing! Everything is so snug and low up front and it looks great.
95 tracker, 31's, rear locker & sas waiting on me
Sold-88 Samurai, 104WB, Locked Yotas, 6.5's, 36's
dabomb5756 is offline   Reply With Quote Quick reply to this message
Old 10-19-2008, 08:08 PM   #80 (permalink)
Member # 8335
Spent the weekend cleaning up the shop, but got a little work done on the YJ as well.
The dimple died strips are going to get boxed in to form gussets of ridiculous hugeness. They may also serve as a headlight mounting convenience.
The driver header has been a HUGE pain in the ass. I fought this thing for a while, but its getting there.
Yes. These can be used to cook bacon.
Behind the scenes the radiator shroud is getting sorted out and I'm starting to figure out the mounting of the steering valve. The engine wiring harness should be in soon as well. The list goes on!
Partially Erect YJ
Old 10-21-2008, 07:59 PM   #81 (permalink)
TRD
TRD's Avatar
Member # 8286
Looks like more scotchbrite is in order. fawkin Gardena
Ryan
Phone: 424-377-0808
Email: [email protected][websiteURL]
Shop
- Custom Spring and Valving Specialists
See what we're up to:
Coilovers, IBP's, Bypasses & Adjustable Shocks In Stock
Now Hiring - Technical Sales Rep
TRD is offline   Reply With Quote Quick reply to this message
Old 10-21-2008, 08:05 PM   #82 (permalink)
Member # 8335
...makes the chassis look like bacon
Partially Erect YJ
Old 10-21-2008, 08:12 PM   #83 (permalink)
TRD
TRD's Avatar
Member # 8286
got ranch?
Ryan
Phone: 424-377-0808
Shop
Old 10-26-2008, 08:54 PM   #84 (permalink)
Member # 8335
Went to a 'Presidents of the United States' concert on Friday in Hollywood. Yes they still exist. Their new music blows. Joose + Jack + Guiness + Miller Light + Corona + Carls Junior = 3.5 gnarly hangover dumps. ...back on track here:
Its about time I give the rear some attention. Pulled it out and started cleaning off brackets.
Heres a wheelbase mockup at full bump - frame is at ride height. Its going to sit at 112".
Rear frame section will get wacked soon.
I'm settled on the radiator location. Should fit right in there w/some dual Spal fans.
The steering cooler is mocked in as well, the tranny cooler needs a home too. Space is filling up fast! Getting oil lines up there is going to be interesting.
TRD banged out welding the last of the header tubes. Final assembly to follow.
Pile-o-header:
Engine cage is moving along. Front gussets are made. Only a few more little details up here. There will be a crossover tube that goes in front of the fire wall, it'll tie into the shock mounts in a V shape.
Partially Erect YJ
Old 11-03-2008, 02:29 PM   #85 (permalink)
Member # 88286
When this rig was 3 linked and the upper link was vertically mounted, how long was the upper link? Also, how much droop did you have with that set-up?
'48 CJ-2A. Cruiser axles, linked, 37s, full hydro.
336wheeler is offline   Reply With Quote Quick reply to this message
Old 11-03-2008, 06:46 PM   #86 (permalink)
chadburgin's Avatar
Member # 18196
Sick ass build man. I was taking notes...Then I realized my skills are not this great so thats pointless...HAHA.
chadburgin is offline   Reply With Quote Quick reply to this message
Old 11-04-2008, 08:07 AM   #87 (permalink)
broke2?'s Avatar
Member # 120359
impressive build, cant wait for more
Inventing new words due to ignorance since 1987.
broke2? is offline   Reply With Quote Quick reply to this message
Old 11-05-2008, 07:37 PM   #88 (permalink)
TRD
TRD's Avatar
Member # 8286
It was the same length it is now, actually it is on the passenger upper. I think it is 34"??
He swapped to a heim with high misalignment spacer and had to run an offset u-joint.
Basically it had plenty of travel in the front. The limit was the shocks.
Thanks for all the compliments!
Ryan
Phone: 424-377-0808
Shop
Old 11-05-2008, 09:00 PM   #89 (permalink)
Member # 120238
cool build, those headers are SICK!!!!
nahmus:no that little nugget of wisdom came right from the retarded circus of my mind.
mountain_yj is offline   Reply With Quote Quick reply to this message
Old 11-07-2008, 07:49 AM   #90 (permalink)
Member # 88286
Thanks man. I'm running a 30" upper but with a Jimmy joint on 16" air shocks- 3" of up/13" droop... we'll see what happens. If worse comes to worse I can always stop them a couple inches shy of full droop.
Old 11-07-2008, 11:42 AM   #91 (permalink)
TRD
TRD's Avatar
Member # 8286
He was running 14" coilovers with 7 up and 7 down (or close to it) but it was pretty tall in the front.
You have more droop than my current rig has travel...
Ryan
Phone: 424-377-0808
Shop
Old 11-09-2008, 07:05 PM   #92 (permalink)
Member # 8335
Work got done in the 'Dena.
Found a set of those spark plug wire insulators. These should do the trick. Tried one on for size...
The time hath come to end an era. <taps playing>
There goes the rest of the frame. I'm going to take to the recycling center and see if they'll give me $5 for it
Rear tub got a little manscaping done too. Cut off just under the tailgate. Sorry Adam, all your nice bodywork is now gone. A sweet dimple died bumper will go there soon.
The B-pillar in on the list. Here is my seat mocked in, this is very close to the final location. The mastercrafts are super comfy
Went out and found some big-boy shocks. These Fox 2.5 14's are going to have to poke thru the hood. The mount required a little creativity, it will come out super clean stay tuned. (I wish I had a band saw)
TRD laid down some TIG welds on the front gussets. Looks super clean as always.
Partially Erect YJ
Old 11-16-2008, 06:28 PM   #93 (permalink)
Member # 8335
It is raining ash in Los Angeles.
Did some work. Cleaned off the old spring hangers to make way for the link brackets. The lower link will be fully outside the frame. Its mocked in with a piece of 1.5" tube I had laying around. The rear axle is sitting at ride height.
TRD cut out the fenders, the shocks will be mounted to the lower link and run up thru the fender.
We found a deal that was too good to pass up. Some dude from AZ sold us a set of 4 shocks.
They are Kuster 3.0" triple bypasses -- 20" stroke, came off an old Walker Evans trophy truck. I'm going to have big travel in the rear now 8) ...the goal is to pull 20" bumped and strapped. 9" up 11" down. These will be used in conjunction with a set of 2.0" dual rate coil overs that are cantilevered off the link.
Of course TRD charged one up and ran it on the shock dyno, heres a plot.
This is where the shock will be at full bump. The upper mounting location will be about head level with respect to the driver.
Partially Erect YJ
Old 11-16-2008, 10:38 PM   #94 (permalink)
Member # 70884
KUSTERS!!!Arguably the shock that started it all.
That is just cool.
-sean- is offline   Reply With Quote Quick reply to this message
Old 11-17-2008, 06:38 AM   #95 (permalink)
Trail Tampon
rajincajingt's Avatar
Member # 27333
wow,
a shock dyno?!?!?
sweet
05 LJ stock
1976 C30 3+3 12V/47RH
instagram: LunchBoxFab
rajincajingt is offline   Reply With Quote Quick reply to this message
Old 11-17-2008, 08:37 AM   #96 (permalink)
pilothillcrawler's Avatar
Member # 76609
Location: Pilot Hill, CA now Woodland, CA; 1 hour further from the con :(
hijack/
Nice avitar racincajint
/hijack
YJ on custom frame 350 sm465 twin stick Dana 300, 35 Spline 60's f/r, arbs f/r, hydro, on 42" IROKS
pilothillcrawler is offline   Reply With Quote Quick reply to this message
Old 11-17-2008, 09:18 AM   #97 (permalink)
TRD
TRD's Avatar
Member # 8286
Originally Posted by rajincajingt View Post
wow,
a shock dyno?!?!?
sweet
Gotta make sure they are doing what you want.
Ryan
Phone: 424-377-0808
Shop
Old 11-23-2008, 09:59 PM   #98 (permalink)
Member # 8335
The rear got linked. All mounts and links are tacked in for now in case something needs to change. The lowers are 2" .250 DOM w/ 1-1/4" heims at the frame end and uniballs at the axle. Lowers will use 3/4" hardware. Uppers are 1-3/4" .120 DOM w/johnny joints.
The truss is started - TRD laid down some beads , it'll get plated in later on. The upper link mounts will get boxed and reinforced too.
Had to do a little trimming to get the uppers to clear
These pics were taken very close to ride height. 8" of up travel appears to be the limit of what my body tub can handle.
Partially Erect YJ
Old 12-30-2008, 09:45 AM   #99 (permalink)
513
Member # 121037
8" inches of uptravel is a hell of a lot for a frame and full body Jeep though
Any updates on this beast? It's been awhile!
513 is offline   Reply With Quote Quick reply to this message
Old 01-16-2009, 09:05 AM   #100 (permalink)
107
christyle's Avatar
Member # 39660
Do I need to come by with some Old E to kickstart some progress on this heap?
christyle is offline   Reply With Quote Quick reply to this message
