YJ Erection - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-16-2009, 09:35 AM   #101 (permalink)
Triple-D TJ's Avatar
Member # 120265
Sweet build, I bet those headders will make this beast sound sick.
Monday is an awful way to spend 1/7 of your life.
Triple-D TJ is offline   Reply With Quote Quick reply to this message
Old 01-16-2009, 06:41 PM   #102 (permalink)
Member # 80641
Any updates?
1986 M1009, 6.2 diesel w/turbo, tons, ARBs, 37s
offroadjunkie is offline   Reply With Quote Quick reply to this message
Old 01-18-2009, 09:33 PM   #103 (permalink)
Member # 119684
Hey Greg,
Nice to see your working on your Jeep. I thought you would have had it running by now. Could have fooled me : ) J/K. When do you plan on having everything finished? Right now we have some new products to sell and hopefully soon we can get them listed up on here with our new website. Hope everything is well.
Jeff Robert
518-872-0421
JeffreyRobert is offline   Reply With Quote Quick reply to this message
Old 03-12-2009, 01:44 PM   #104 (permalink)
513
Member # 121037
Updates??
513 is offline   Reply With Quote Quick reply to this message
Old 03-13-2009, 09:49 AM   #105 (permalink)
Member # 48100
I can't wait to see how this turns out with such a low stance. Great work.
2008 Jeep Unlimited X
My 1 ton TJ Build
tweba99 is offline   Reply With Quote Quick reply to this message
Old 03-13-2009, 09:52 AM   #106 (permalink)
107
christyle's Avatar
Member # 39660
Project has been abandoned in favor of rediculous road trips and fixing Toyota shop-mates for the time being. Work should be resuming very soon.
christyle is offline   Reply With Quote Quick reply to this message
Old 03-14-2009, 09:32 PM   #107 (permalink)
Member # 8335
Its been a while since I've updated this - been busy the last few months.
The front shock mounts got rethought. They are a work in progress. They'll get plated & dimple died.
I finally got the radiator shroud and fans done. The shroud is aluminum, the sheet metal guys at work helped me out on this one... Its 3/4" deep and reinforced with some aluminum angle inside.
Tight squeeze. It should clear everything.
I threw the coolers up in front to see what I'm dealing with. They just take up too much space, so I'm considering moving the tranny cooler to behind the passenger with its own dedicated fan. Hopefully its not too loud.
Partially Erect YJ
WideJ is offline   Reply With Quote Quick reply to this message
Old 03-14-2009, 09:51 PM   #108 (permalink)
Member # 70884
glad to see it's going again.
-sean- is offline   Reply With Quote Quick reply to this message
Old 04-30-2009, 07:32 PM   #109 (permalink)
513
Member # 121037
Anything to share with us? I've enjoyed this build, hate not seeing any updates
Old 05-07-2009, 10:05 AM   #110 (permalink)
Member # 8335
I have a pile of bling parts and no progress to speak of. I have been very busy the last few months. Too many of my friends are getting married!! I hope to get some momentum on this build starting this weekend.
Partially Erect YJ
Old 05-07-2009, 05:09 PM   #111 (permalink)
Member # 81935
that shit is hot.......now get to work!
[SIZE="5"][FONT="Comic Sans MS"][COLOR="DarkRed"]Keen Motorsports #125 [/COLOR][/FONT][/SIZE]
[SIZE="2"][COLOR="Lime"]Thanks to our sponsors: Appalachian Offroad Inc and Clayton Offroad Manufacturing[/COLOR][/SIZE]
[QUOTE=zachv;11186975]I bet that will be the first rig ever with King coilovers and a C-channel truss!! :flipoff2:[/QUOTE]
backyard wrenchers is offline   Reply With Quote Quick reply to this message
Old 05-08-2009, 10:50 AM   #112 (permalink)
Member # 120626
amazing build.....can you say front end STUFF!! any idea about the weight??Looks sweet!!!!
mechanicalmongoose20 is offline   Reply With Quote Quick reply to this message
Old 05-08-2009, 01:05 PM   #113 (permalink)
Member # 8335
I estimate it will be in the 4000lb to 4500lb range. I'd like to think it will be closer to 4k but only time will tell. This RIG will be very stable.
Partially Erect YJ
Old 05-08-2009, 06:12 PM   #114 (permalink)
TRD
TRD's Avatar
Member # 8286
The time has come to resume the project. Look to see some more progress on the tube car this weekendstein.
Ryan
Phone: 424-377-0808
Email: [email protected][websiteURL]
Shop
- Custom Spring and Valving Specialists
See what we're up to:
Coilovers, IBP's, Bypasses & Adjustable Shocks In Stock
Now Hiring - Technical Sales Rep
TRD is offline   Reply With Quote Quick reply to this message
Old 05-10-2009, 05:12 PM   #115 (permalink)
Member # 8335
FYI a Harbor Freight 20-ton shop press is 23.5" wide between the H frame. A Northern Tool press brake is 24" wide.
Anyway - the lower radiator mounts are done. The new press brake came in handy. I goofed around with the driver side header a little... its coming.
Also, I picked up a new intake. This unit is a mass air flow sensor built into an air filter. It all mounts directly to the throttle body. I had 5.25 inches of clearance. This assembly is 5" deep. Running this filter setup requires a smaller idler puller below the filter for it to clear.
Everything fits like a glove. The steering cooler and trans cooler will go in font of the radiator. No coolers & fans behind the seats for me!!
Partially Erect YJ
Old 05-10-2009, 05:15 PM   #116 (permalink)
Member # 8335
It NOT a car
Go take your Toyotacar Jeeping.
Partially Erect YJ
Old 05-17-2009, 09:56 PM   #117 (permalink)
Member # 8335
The goal is to fit all accessories under the hood. Its getting tight.
The accumulator fits nicely between the radiator and motor
No two piece front driveline for me It somehow fits. The 1350 joint at the Tcase might not have enough travel. I'm considering a toyota joint for clearance purposes. A 1410 may not fit under the floor.
...cutoff wheel arts & crafts. A band saw would be nice. Anyone want to give me one?
These will be front upper shock mounts one day.
Partially Erect YJ
Old 05-18-2009, 01:58 PM   #118 (permalink)
pilothillcrawler's Avatar
Member # 76609
Location: Pilot Hill, CA now Woodland, CA; 1 hour further from the con :(
What size of Ron Davis radiator did you use? I am about to get one now and was wondering what size would cool best?
YJ on custom frame 350 sm465 twin stick Dana 300, 35 Spline 60's f/r, arbs f/r, hydro, on 42" IROKS
pilothillcrawler is offline   Reply With Quote Quick reply to this message
Old 05-18-2009, 02:57 PM   #119 (permalink)
Member # 8335
Well the bigger the better. ...but mine is a 26x16 dual pass.
I would call Ron Davis and have them help you select one. They have some selection software that calculates the size of radiator you need based on power, type of driving, etc. Compare that to what you have space for and presto -- your radiator is selected. I'm on the edge of what is adequate for a 500 hp setup - supposedly.
Partially Erect YJ
Old 05-20-2009, 05:59 AM   #120 (permalink)
Member # 132284
subscribed!
JeepMadness1979 is offline   Reply With Quote Quick reply to this message
Old 05-20-2009, 08:08 AM   #121 (permalink)
tw89yj's Avatar
Member # 52621
where did the air filter come from
tw89yj is offline   Reply With Quote Quick reply to this message
Old 05-20-2009, 09:37 AM   #122 (permalink)
Member # 8335
Street & Performance, Inc.
www.hotrodlane.cc
Its a mass air flow sensor & filter combo. You can get the filters in different depths. Its a little pricey but a very clean alternative to having a gnarly 90 degree elbow and intake tube running everywhere.
FYI the idler pulley must be swapped out for a smaller one for the filter to fit. They sell those too - along with all kinds of other stuff I can't afford.
Partially Erect YJ
Old 05-31-2009, 06:04 PM   #123 (permalink)
Member # 8335
We had been putting off the driver side header for a few months now... the tubes are all welded up, "just" needs assembly. The outlet of the header is very close to the exhaust ports. It was a huge challenge to get it to work.
TRD is doing work on the header here laying down some beads.
Now ready for the collector to get welded on.
...and installed
The exhaust will BARELY fit through the little space between the upper link, driveshaft, frame, body, oil pan, and bellhousing. 8O A short flex coupling will be attached directly to the header so the rest of the exhaust can be rigid mount to the frame.
My new press brake is coming in handy. One of those things where you wonder how you ever lived without it.
The re-beginning of a rear truss.
Here are the lower radiator mounts. Just two little trays.
At full bump the steering ram is very close to the radiator. --> you see the general theme here...
For that sweet air filter I had to change the idler pulley out. Check out my one bling pulley
I threw the Stak shifters in. I think the setup is kinda cheesey but it will do for now. Maybe cable shifters one day...
Next the rear truss will get finished, engine cage finished, and accessories mounted. The list is still long, but we're checking things off.
Partially Erect YJ
Old 06-01-2009, 08:21 AM   #124 (permalink)
Member # 76609
sweet as usual
Old 06-07-2009, 08:15 PM   #125 (permalink)
Member # 8335
Some progress to report:
The engine cage saga continues...
Rear truss. Fawk all you guys with CNC tables This was done the old fashoined way.
Front.
The back is a single piece, it will get bent over the tops of the upper link mounts - should be super clean. Its the mothership
Partially Erect YJ
