YJ Erection - Page 7 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-08-2009, 12:26 PM   #151 (permalink)
Member # 62686
Any update on this beast?
FrkyMnky1487 is offline   Reply With Quote Quick reply to this message
Old 11-08-2009, 02:13 PM   #152 (permalink)
Member # 8335
Got happy with the cut off wheel and the sawzall. ...and you thought body lifts weren't cool any more.
We cut the body off in the rear and are raising it 4". This will allow me to run my 10" of up travel and retain some sort of tub.
A crappy mock-up pic
Busted out some sheet metal skillz (or lack thereof )
These pieces match the inside profile of the YJ door opening.
Welding
More to come, passenger side is next. The rear corners will get skinned, etc.
Partially Erect YJ
WideJ is offline   Reply With Quote Quick reply to this message
Old 11-08-2009, 03:16 PM   #153 (permalink)
Member # 113337
Why are going with 10" of uptravel?
rockinCJVA is offline   Reply With Quote Quick reply to this message
Old 11-08-2009, 09:02 PM   #154 (permalink)
Member # 8335
to match my 10 inches of down
Partially Erect YJ
Old 11-08-2009, 11:18 PM   #155 (permalink)
Member # 62686
Damn, nice update although not what I was hoping to see. I guess I should have expected it when you picked up the bypass shocks. I was curious to see how low you could go and still keep the top similar to what TennyCar did. I just got through mocking mine up today and am hoping to get around a 22" belly with at least 7" up and still maintain the stock soft top.
Old 11-09-2009, 11:46 AM   #156 (permalink)
Member # 8335
You should be good with those numbers and retaining the tub skin. I have a 19" belly (22" to the frame) and 10" of up. That gives you about 5" more to play with than I had at full bump.
Partially Erect YJ
Old 11-14-2009, 08:14 AM   #157 (permalink)
Member # 25360
Wow, very nice build. I like the no compromise approach. When's it gonna be done?
1989 Wrangler -- Working on it
- 6.0 LQ9
- TH400
- AtlasII 3.0
- Ford D60's w/ 5.38's (chromo 35spline throughout with rear ARB)
- 39" Red Labels
BamaScout is offline   Reply With Quote Quick reply to this message
Old 11-15-2009, 07:36 AM   #158 (permalink)
Member # 8335
Here is a sneak peak at what we got done.
Tub is clearanced for the 40" goodyear at full bump - articulation. Rear half of the cage is coming together. There is a hoop running level with the top of the tub that ties the B-pillar in with the down bars.
Looks fast just sitting there.
Partially Erect YJ
Old 11-15-2009, 01:30 PM   #159 (permalink)
Toyoland66's Avatar
Member # 35163
badass build
1979 FJ40
Toyoland66 is offline   Reply With Quote Quick reply to this message
Old 11-20-2009, 10:47 PM   #160 (permalink)
Member # 8335
I love my bandsaw.
That is all
Partially Erect YJ
Old 11-21-2009, 12:12 AM   #161 (permalink)
107
christyle's Avatar
Member # 39660
Did you draw that in solidworks?
Lookin sweet. I may have to come back to make sure you kids are getting work done.
christyle is offline   Reply With Quote Quick reply to this message
Old 11-21-2009, 04:49 PM   #162 (permalink)
tmaddox4x4's Avatar
Member # 108799
Any pics of rear shock mount yet? Nice build, alot of good ideas.
tmaddox4x4 is offline   Reply With Quote Quick reply to this message
Old 11-22-2009, 11:29 AM   #163 (permalink)
107
christyle's Avatar
Member # 39660
Shock mount depends on the rear cage section. Ideas are changing, so is the mount design. The cage is getting worked on some more today.
Old 11-22-2009, 06:14 PM   #164 (permalink)
Member # 8335
B-Pillar tie-in, it'll get reinforced.
Cut the rear floor out. Really cleaned it up back there.
My blank canvas, haha...
Back hoop turned out nice. C-pillar ties into the back corners.
Back corner plates They're fully boxed in.
Head-on cage view
Rear wheel well at ride height. Lost of room there for 10" of UP.
Partially Erect YJ
Old 12-03-2009, 09:56 PM   #165 (permalink)
Member # 8335
Santa came early
King 2.5" 3-tube bypasses - 14" stroke
Sadly the Kusters will not be used. These will package up much more cleanly.
Partially Erect YJ
Old 12-21-2009, 10:17 PM   #166 (permalink)
Member # 8335
WHITE FENDERS BRO
While TRD was doing work on the Toyota I goofed around with the new hood and came up with this:
Cleaned it up a bit. The hood even latches to the grille
...and some old-school inspiration
Partially Erect YJ
Old 12-21-2009, 10:27 PM   #167 (permalink)
kwrangln's Avatar
Member # 6971
I gotta hand it to ya man, this has got to be the baddest heep build I've seen in a long time. Too many end up giving up the tub for tube, keeping the heep look is a challenge, and one you are pulling off nicely.
Keep it coming.
I'm the "tack tack tack" welding nazi.
:flipoff2:
"I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside
kwrangln is offline   Reply With Quote Quick reply to this message
Old 12-22-2009, 12:08 AM   #168 (permalink)
Member # 148578
i can only see red crosses. not pics
d.k.v is offline   Reply With Quote Quick reply to this message
Old 12-22-2009, 06:24 AM   #169 (permalink)
107
christyle's Avatar
Member # 39660
Sucks for you...i see em just fine
Old 01-10-2010, 10:28 PM   #170 (permalink)
Member # 8335
No real updates - but I'll throw up some pics anyway
Got a can of clear enamel and shot the front bumper area. I'm down with the bare metal look. I painted a small tube and put it in the back of TRD's truck as a weathering test. I'm a little wary of using clear for my entire chassis. We'll see.
Building braided stainless steel lines with AN fittings is a huge pain in the ass. I started with the return line from the reservoir to the pump. ...starting to get the hang of it.
Partially Erect YJ
Old 01-11-2010, 03:04 AM   #171 (permalink)
Member # 71311
Good job on your build. Do you have any photos of your power steering pump mount? I'm swapping a 5.3 into my ZJ and I had to move the power steering pump up out of the way of the steering box in a similar manner. Thanks.
downtowncb is offline   Reply With Quote Quick reply to this message
Old 02-18-2010, 07:36 AM   #172 (permalink)
Member # 25360
any updates?
- 6.0 LQ9
- TH400
- AtlasII 3.0
- 39" Red Labels
Old 02-18-2010, 08:16 AM   #173 (permalink)
107
christyle's Avatar
Member # 39660
He decided to buy this instead of finishing his project
https://pirate4x4.com/forum/showthrea...autiful+toyota
Old 02-18-2010, 11:26 AM   #174 (permalink)
Member # 25360
WTF would he want that?
- 6.0 LQ9
- TH400
- AtlasII 3.0
- 39" Red Labels
Old 02-18-2010, 11:28 AM   #175 (permalink)
Member # 8335
Well not quite, but that rig is a hell of a deal.
The rear shocks have a home and the rear suspension has been cycled to ensure everything clears. Its capable of pulling 20" at the axle, split up & down. Will be closer to 18" bumped & strapped. Driveshaft angle is a little scary at full droop, but will work. I'm looking at at least 5" of driveshaft plunge. Hopefully a HAD can accomodate.
I'll post up a pic or two when I find my memory card reader
Partially Erect YJ
