YJ Erection - Page 8 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-18-2010, 12:35 PM   #176 (permalink)
Member # 8335
Originally Posted by downtowncb View Post
Good job on your build. Do you have any photos of your power steering pump mount? I'm swapping a 5.3 into my ZJ and I had to move the power steering pump up out of the way of the steering box in a similar manner. Thanks.
I raised it a little, but the pump is very close to stock location. I'd look for an aftermarket solution before building one, its a pain.
This is the best pic I could find. I used a couple spare holes in the block and just threw something together. To line it up I clamped a square tube to the crank pulley and PS pulley, got it where I needed it, then got out the cardboard & made a template.
Partially Erect YJ
WideJ is offline   Reply With Quote Quick reply to this message
Old 02-18-2010, 01:23 PM   #177 (permalink)
Member # 25360
That's going to be a mean machine.
I just got the LQ9/TH400/Atlas mocked in last night and I am amazed at how far back the LS motor can go against the firewall. I mounted it as tight to the firewall as possible and as high up as it would go and link clearance looks like it will be awesome.
1989 Wrangler -- Working on it
- 6.0 LQ9
- TH400
- AtlasII 3.0
- Ford D60's w/ 5.38's (chromo 35spline throughout with rear ARB)
- 39" Red Labels
BamaScout is offline   Reply With Quote Quick reply to this message
Old 02-19-2010, 02:15 PM   #178 (permalink)
Member # 8335
Got the rear shocks mocked in. 14" coilover and 14" bypass mounted on the lower link.
Suspension cycles 20". 10" up and 10" down.
This is full droop.
Driveshaft BARELY works, but somehow does.
More to come soon.
Partially Erect YJ
Old 02-21-2010, 08:33 PM   #179 (permalink)
Member # 8335
I'm converting the front hubs to 5 on 5.5 from 8-lug.
Got these sweet custom hubs, they use stock Ford bearings and 1/2-ton brakes. I had them machined for 9/16" studs.
Got some Reid Racing knuckles as well. These are great quality. I'm rebuilding the king pins while its all apart.
We figured out the rear frame section this weekend. Thanks to the band saw and some strategically sheared 1/8" cold rolled strips the pieces came together cleanly. I am sick of hole sawing
Rails were assembled on a flat table. TRD laying down some clean TIG welds...
Side
Bottom
Built another to match and burned them in.
We are very close to having a rolling chassis.
Partially Erect YJ
Old 02-21-2010, 09:13 PM   #180 (permalink)
TRD
TRD's Avatar
Member # 8286
Your camera sucks!
Ryan
Phone: 424-377-0808
Email: [email protected][websiteURL]
Shop
- Custom Spring and Valving Specialists
See what we're up to:
Coilovers, IBP's, Bypasses & Adjustable Shocks In Stock
Now Hiring - Technical Sales Rep
TRD is offline   Reply With Quote Quick reply to this message
Old 02-21-2010, 09:19 PM   #181 (permalink)
Member # 1792
What was the point of building the frame rails out of sheet?Other the the over use of dimple dies.Plain old rectangle tubing works fine and doesn't let crap in.
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers. Kid's '70 Jeepster D44/14bolt FF.
Cheepin is offline   Reply With Quote Quick reply to this message
Old 02-21-2010, 10:27 PM   #182 (permalink)
Member # 8335
Rectangular tube would have worked. These fabricated frame rails let crap out and blow rectangular tube out of the water in coolness factor.
Didn't you see all the drain holes on the bottom?
Partially Erect YJ
Old 02-22-2010, 09:59 AM   #183 (permalink)
Member # 71311
But crap doesn't get in in the first place if the frame is enclosed
downtowncb is offline   Reply With Quote Quick reply to this message
Old 02-22-2010, 10:09 AM   #184 (permalink)
Member # 76694
Side
Cool.
<--- Build Thread :D
sne97hd is offline   Reply With Quote Quick reply to this message
Old 02-22-2010, 10:10 AM   #185 (permalink)
Member # 8335
Ok leave my swiss cheese frame alone
There was enough oil & grime in my stock "enclosed" frame to catch on fire when plasma cutting through it.
Partially Erect YJ
Old 02-22-2010, 11:06 PM   #186 (permalink)
onesun06's Avatar
Member # 69163
You are definitely going to need some u-joint coolers with that much movement at the driveshaft.
Looks awesome Greg. I want to see your C/O and bypass mounts when you get em done. Are they still gonna be near your dome?
-Scott
onesun06 is offline   Reply With Quote Quick reply to this message
Old 02-22-2010, 11:45 PM   #187 (permalink)
Member # 8335
The shocks will be under the fender wells. It'll have a fully functional bed area with full size spare tire mount. No huge holes in the floor if all goes well.
Partially Erect YJ
Old 02-23-2010, 06:02 AM   #188 (permalink)
cavaliers1323@aol.co's Avatar
Member # 69669
Not all builds take the easiest approach, and doing it this way has it's benefits. Besides that shit is
Guess you've never cut one open...
Serving Central VA Since 1910
93 YJ N/A 383 on 'pane 405hp/435tq NV4500 6.34:1 231/300 10.88:1 Locked Tons 5.38's 40's 108" WB Gettin' There :grinpimp:
cavaliers1323@aol.co is offline   Reply With Quote Quick reply to this message
Old 02-23-2010, 04:30 PM   #189 (permalink)
Member # 81189
Wow... that's alot of steel. Lots of stuff packed into small places! LOVE IT!
Great job, welds are bitchin. Trusses are huge!
Never seen upper links that straddle the engine =)
'88 Jeep MJ 1-ton buggy
barillms is offline   Reply With Quote Quick reply to this message
Old 02-23-2010, 05:59 PM   #190 (permalink)
107
christyle's Avatar
Member # 39660
Your mom's lower links often straddle my engine
christyle is offline   Reply With Quote Quick reply to this message
Old 02-28-2010, 08:11 PM   #191 (permalink)
Member # 8335
Got the rear bupmer installed. Its 2x4x3/16.
Sweet bumper gussetts:
Coil over & bypass mounts on the links. BAM
Floor pockets for upper links are boxed in now. Driveshft will need a pocket as well.
The C-pillar and rear deck hoop are fully welded in. These have been tied into the rear bumper.
A cross member behind the seats was added as well. The rest of the back of the Jeep will be built off this piece.
...and obligatory full bump shot
TRD must have welded 20 linear feet this weekend!!
Partially Erect YJ
Old 03-01-2010, 08:16 AM   #192 (permalink)
Member # 25360
Looking good! Tons of work coming together on that ride. I wish I had those skills.
- 6.0 LQ9
- TH400
- AtlasII 3.0
- 39" Red Labels
Old 03-01-2010, 04:08 PM   #193 (permalink)
Member # 69669
don't really know what else to say
Old 03-07-2010, 08:02 PM   #194 (permalink)
Member # 8335
Fender bars in. The shocks mount off of them.
Kind of had a 2 steps forward one step back weekend. Mounted the shocks (shown here) but had to cut them out since the tire just rubbed on the bypass shock at full stuff.
Partially Erect YJ
Old 03-08-2010, 01:07 PM   #195 (permalink)
Jodisbadassjeep's Avatar
Member # 108738
B-Pillar tie-in, it'll get reinforced.
Cut the rear floor out. Really cleaned it up back there.
My blank canvas, haha...
Back hoop turned out nice. C-pillar ties into the back corners.
Back corner plates They're fully boxed in.
Head-on cage view
Rear wheel well at ride height. Lost of room there for 10" of UP.
See that's the proper way to tie a cage in. I've seen many ways that have huge problems. Nice work.
"FREEDOM ISN'T FREE" Yj 406 sbc 575hp 580tq TH350 NP205 HP44 frt and HP 9' rear. 14" King Coilovers.
Jodisbadassjeep is offline   Reply With Quote Quick reply to this message
Old 03-08-2010, 01:09 PM   #196 (permalink)
Member # 25360
Amazing amount of quality work in this Jeep. Can't wait to see the finished product. Are you going to race it?
- 6.0 LQ9
- TH400
- AtlasII 3.0
- 39" Red Labels
Old 03-08-2010, 02:15 PM   #197 (permalink)
Member # 8335
Thanks!
No plans to race it. Building is expensive enough, plus I couldn't stomach potentially destroying this rig for a single day of racing. Buuuut who knows what this thing will end up doing
Partially Erect YJ
Old 03-21-2010, 08:26 PM   #198 (permalink)
Member # 8335
Got a good portion of the rear chassis done this weekend.
Air bumps are mounted now. The bumps are notched into the frame rail and vertical tube for tire clearance. Should be solid.
Played Connect the Dots. Tire at full stuff in these pics - verifying everything fits.
Another marathon TIG welding weekend for TRD. Busted it out as always. I've never seen so much out of position welding (thats what she said).
More
This is close to ride height - notice the air bump strike pad under construction.
This is what we came up with for shock mounts. They fit under my "fender well." Should be very clean. No holes cut in the floor for shocks!!
On deck: Mount seats, finish exhaust, etc etc.
Partially Erect YJ
Old 03-21-2010, 08:40 PM   #199 (permalink)
Member # 6170
Looks good G!
Thats nice of you to let TRD practice his welding on your ride!
I've noticed my "to do" list seems to be getting shorter, yours too?
Kevo
Ghetto Fab. is offline   Reply With Quote Quick reply to this message
Old 03-21-2010, 08:47 PM   #200 (permalink)
Member # 8335
Originally Posted by Ghetto Fab. View Post
Looks good G!
Kevo
Yup TRD will have a mile of welds on this by the time its done! Just bought another 10 lb of welding wire.
The list is getting shorter, might fit on a single sheet of paper now
Get your junk rolling!
Partially Erect YJ
