Project Yellow Jacket - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-30-2011, 07:51 AM   #126 (permalink)
Member # 68995
Sick build! Love the way that it turned out!
98 TJ, 35s, locked D30 and 8.8, 4.56s
UTWeezul is offline   Reply With Quote Quick reply to this message
Old 05-19-2011, 03:39 PM   #127 (permalink)
Member # 151432
Originally Posted by Team Willys View Post
Awesome rig man. I have to agree that this is one of the cleanest "big jeeps" I have seen.
As far as the ORIs... what are your lower pressures set at? I run 100 PSI in mine (the minimum recommended) and they are great on the trail, nice and soft for crawling, but body roll is an issue on the street and jumping it is... eh... They bottom out pretty hard and I have 5" of up travel, even with small jumps (a few feet in the air) it still lands hard.
I thought about raising the lowers' pressure just a touch, maybe 115 PSI or so. I know with 150 PSI (maximum is 200) they tend to bounce driving down the road; learned that from a customers rig. I was dealing with ORI directly when I bought mine, so I called for a suggestion and their response was that you cannot drive them on the street. I asked why, and was told simply because they were not designed for that. No help from them at all. So basically, I was just curious as to what you run and if you noticed any bouncing on the road at that pressure. Did you take any oil out of the uppers?
I just got my ori struts for my project and I got lucky and got them from a good source who has used them before. (007rockstar on here) It sounds to me like your running on the 2nd stage of the compression dampening all the time.
They are supposed to be installed so that half the shaft is exposed. You said you have 5 inches exposed? Charlie (rockstarmetalworks) who I got mine from said they will ride terrible like that. I wanted to install mine at 5 inches to take advantage of the built in bump stop.
If you moved one of your mounts further apart you would get out of the 2nd stage of compression and likely get the air bag ride you want.
So on a 14 inch 7 would be exposed. 3/4 of a inch of shaft isnt useable and the bump stop thats built in is a progressive deal that starts working a few inches before the last 3/4 where its solid.
ALSO not sure where you guys are getting your gas pressures from. I have the manual right here and its 35psi minimum and 600psi maximum.
All of this is on the ori site also in your manual if you still have it.
I just came accross this thread by doing a search looking for ideas on mounting my ORI's...
faziom is offline   Reply With Quote Quick reply to this message
Old 07-30-2011, 05:43 PM   #128 (permalink)
Member # 116336
October's issue of Petersen's 4 Wheel & Offroad:
2004 Jeep, 404s, 14" ORIs, 3-link front / 4-link rear, 241 t-case, 42" Rockers / 16.5" H1 rims
withinfocus is offline   Reply With Quote Quick reply to this message
Old 07-31-2011, 06:51 AM   #129 (permalink)
Member # 126126
Originally Posted by withinfocus View Post
This has been quiet for a little while but it's actually almost complete now. Went and got a big new radiator (with transmission cooler) from Howe along with an electric fan (which took three weeks because Howe lost some staff):
The radiator is all mounted up:
Now it's time to pull all the tubework for full welding and paint. The skid plate needs a little more work but otherwise the suspension is pretty much ready to go. The fuel system which was a tight fit with my tall tank and arched rear seat is complete and ne 6eds to be routed to the engine. Steering is almost done and the orbital and shaft being the only things that need to get put in. Steering and brake lines need to get in too. Driveshafts (including a crazy two-piece one for the front) have been ordered from Carolina Driveline and should be here soon.
I hope you didnt poke those plastic threaded rods through that nice new aluminum radiator. If you did take the time to find another way to mount the tranny cooler. You also need some space between the radiator and the cooler so they dont help heat each other up. I myself have done it wrong so many times im an expert.
We may not have it all together, but together we have it all. ROCK HARD & ROCK ON OFFROAD BROTHERS!
My Build
Canyonmann is offline   Reply With Quote Quick reply to this message
Old 08-17-2011, 05:28 AM   #130 (permalink)
Member # 17223
Send a message via AIM to tunedportcj5
See the 1/4" bolts going through the sides of the cooler? Its mounted to the grill support "V". It doesn't come close to that nice radiator...
www.terratraction.com
tunedportcj5 is offline   Reply With Quote Quick reply to this message
Old 04-09-2012, 08:24 AM   #131 (permalink)
Member # 116336
Forgot to keep people up to date on where I've been with this thing. Went to Gulches in Waterloo, SC a few weeks ago:
Some simple climbs / descents:
http://youtu.be/3L2VaioQ4T0
http://youtu.be/CxNdYPIdgKA
Long run up a pretty steep rock face (and had transmission shifting issues):
http://youtu.be/b_Od8cigkh8
Old 06-15-2012, 11:19 AM   #132 (permalink)
Member # 51899
Teets!!
The sky was your playground . . .
P.A.O
stjjames is offline   Reply With Quote Quick reply to this message
Old 06-15-2012, 09:26 PM   #133 (permalink)
Member # 161126
sweet build, this thing is killer! can you post a picture of your rear bumper?
slednecks1124 is offline   Reply With Quote Quick reply to this message
Old 12-08-2014, 06:52 AM   #134 (permalink)
Member # 116336
Been a while since my last update! Haven't changed a ton, just been wheeling it and seeing what needs to be changed / fixed.
Current look:
Running 42" Pitbull Rockers now, decided the Boggers were too heavy and I wanted more lateral traction. On the list to change:
- new rims, H1s are getting warped and want something lighter
- master cylinder upgrade
- raise the ORIs about 2" for better handling
Old 12-08-2014, 01:52 PM   #135 (permalink)
LADIESMAN217's Avatar
Member # 168821
I was the one that posted your pic on Instagram this morn. I've always drulled all over this thing looks sweet on the pitbulls! Where do you go wheeling at?
LADIESMAN217 is offline   Reply With Quote Quick reply to this message
Old 12-10-2014, 07:44 PM   #136 (permalink)
Member # 205276
you mention that your h1 rim or getting warped ? (inner bead ,the rim ...)
mark v is offline   Reply With Quote Quick reply to this message
Old 12-11-2014, 05:05 AM   #137 (permalink)
1TONZR2's Avatar
Member # 40567
Send a message via AIM to 1TONZR2
I think most of the issue with them is the previous owner of those wheels had them widened for some reason and the welding on the centers really look subpar....so who knows how well they are actually centered. Time for some lighter trail readys or race lines!
96 ZR2 HP60,14B, 5.13s,locked ,F/R tri'ed 4 link,16" SAW COs and 4" SAW bumps front, 16" ORIs rear,RCI fuel cell, Truggied out, 42" PitBull Rockers & TR beadlocks, 5.3L Vortec w/LS6 cam/springs, 231/205 doubler, 1410s, 9.5ti
Over the Top Offroad
1TONZR2 is offline   Reply With Quote Quick reply to this message
Old 12-11-2014, 06:22 AM   #138 (permalink)
Member # 116336
Recent trips have been AOP, Harlan, Morris Mountain, and Choccolocco.
Old 12-11-2014, 09:25 AM   #139 (permalink)
Member # 467881
what do you run for tire pressure....in those videos it looks like your tires aren't flexing at all.
99 Tjuggy 60's, atlas, 40's
05 WK HEMI 2" lift & 32's
spyder05 is offline   Reply With Quote Quick reply to this message
Old 12-11-2014, 09:43 AM   #140 (permalink)
Member # 116336
They're pretty high in those. Because the rims are banged up they leak at low-pressure and so I kept the driver front and passenger rear at 20+. Normally I'll drop down to about 12 though, especially with the new Rockers.
Old 12-11-2014, 09:50 AM   #141 (permalink)
1TONZR2's Avatar
Member # 40567
Once you get some new rims, you can run 5-8 without issues
Old 12-11-2014, 02:35 PM   #142 (permalink)
TN-D90's Avatar
Member # 85510
Be careful running rockers below 10psi, I've sliced my rockers sidewalls often running lower than 10. Really sucks to because they will actually work at those pressures. Above 10 they hold up a little better
1989 Jeep YJ- "Black Label"
TN-D90 is offline   Reply With Quote Quick reply to this message
Old 05-12-2015, 02:17 PM   #143 (permalink)
Member # 116336
Got some new rims:
Kept the Unimog bolt pattern, TrailWorthy had a new set of 12-bolt H1s pretty much ready to go. Standard rock rings, powdercoated yellow and black.
Old 12-05-2015, 10:14 AM   #144 (permalink)
Member # 323409
Awesome rig! Did the mog axles already have the disc conversion and if so, do you know where or who made them? Building similar rig, 03 TJ with 404's also in Jan.
4wdoutfitters is offline   Reply With Quote Quick reply to this message
Old 12-06-2015, 04:45 AM   #145 (permalink)
Member # 116336
Thanks. Drum-to-disc and torque tube-to-pinion conversions came from Exaxt, not that big a deal to do, just more parts to buy.
