Poison Spyder goes to KOH with DJ!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-03-2011, 12:24 PM   #1 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
After spending the last four years pitting for Ridgway in KOH, I thought I’d give it a shot from the drivers seat for the 2012 4Wheel Parts Every Man Challenge
in the Stock Mod Class.
Larry McRae and the crew at Poison Spyder were quick to step up and help me with some of the parts I needed.
The Jeep was heavy and needed to go on a diet, and I needed some other key parts to make it race ready.
The specs on my Jeep
2004 Jeep Rubicon, stock motor, trans and transfer case which is 4 to 1
Poison Spyder rear Crusher Corners with a 3” flare.
Poison Spyder Rocker Knockers with Sliders
Poison Spyder Comp Cage, well what’s left of it..
14 Bolt with Detriot, Solid hubs, Dutchmans and 5:13s
Flanged.
Ford Dana 60 Ball Joint front with Solid knuckles, spindles, and diff cover.
Superior Front Shafts
CTM joints
16 by 2.0 Fox Coilivers in the rear limited to 14”
14 by 2.0 Fox Coilovers up front
1.25 Currie Johny Joints
Raceline Monsters
Custom Splice Rope
37” Good Year MTR’s
And stuff……
The victum before the knife...
He had 40's in this picture...
MY BUILD
04 Rubicant Ultra4
My precious.... 72 K5 Blazer
web wheeler...
DJ404564X4 is offline   Reply With Quote Quick reply to this message
Old 12-03-2011, 12:26 PM   #2 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
One of the first things to go was my old Poison Spyder tube fenders.
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-03-2011, 12:32 PM   #3 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Then a trip to Poison Spyder to pick up some light weight goodness...
First up were some of their new Aluminum DeFenders - Negative Flares
Which I had sanded down with some 180 grit and then applied a flat clear coat..
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-03-2011, 12:37 PM   #4 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
A quote from their web site about the Defenders.
Increased clearance for larger tires and suspension articulation. The wheel opening is approximately 4" wider than the stock Jeep fenders, and about 2-1/2" wider than old school tube fenders.
Some mock up shots
The inner fender well will be moved back, and the supplied battery box installed.
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-03-2011, 12:48 PM   #5 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Next up to keep things cool under the hood...
Hood Louvers
Which also got the flat clear coat treatment...
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-03-2011, 12:51 PM   #6 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
The Hood Louver kit came with a nice template to line everything up. I used the windshield bumpers to help line it up...
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-03-2011, 12:56 PM   #7 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
The factory rear tailgate weighs about 37 pounds...
To combat that I also got a TrailGate. Mine is the solid mount bolt on kit. There is a swing open kit avalible too.
And yes, it got flat clear too...
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-03-2011, 01:14 PM   #8 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Agian to save weight over the factory hard door, I got some Crawler Door Skins. Not sure how much factory half doors weigh but i'm guessing at least 50 pounds. I also have a limited amount of space for sponsor stickers so these help with that too.
Plus, they just look cool....
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-03-2011, 01:18 PM   #9 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Yep, they got the clear treatment too... see a pattern developing here??
Simply take your old vinyl door skins and user the frame from them..
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-03-2011, 01:24 PM   #10 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Some mock up posser shots...
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-03-2011, 02:27 PM   #11 (permalink)
UCTJ's Avatar
Member # 51571
Cant wait to see it finished!
[B][COLOR="DarkOrange"]2012 Dodge 3500
[/COLOR][/B]
[B][COLOR="DarkOrange"]97 TJ 60/14 Atlas 40" Maxxis 106" WB[/COLOR][/B]
UCTJ is offline   Reply With Quote Quick reply to this message
Old 12-03-2011, 03:01 PM   #12 (permalink)
Member # 136981
A nice and sloppy template. Unless they fixed it recently, it doesn't line up with all of bumpers, windshield nozzle and hood loop. You have to pick one and go with it. Stupid sloppiness on a simple little thing. At least the actual louvers line up right.
[B]#feelthejohnson[/B]
biffgnar is offline   Reply With Quote Quick reply to this message
Old 12-03-2011, 03:15 PM   #13 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
I find the comments on tube fenders ironic.
& Blaine
:tank:
Old 12-03-2011, 04:39 PM   #14 (permalink)
Member # 99513
Your rig is looking killer DJ!! I wish I could be out there to see it in person and drink a beer with you.
Good luck at the race. Hope you do well and make it to the big show.
Swapping Front ends:
Motorcycle stuff.
[SIZE="5"][COLOR="Red"][B]NEW BEGINNINGS:[/B][/COLOR][/SIZE]
jpfrk2001 is offline   Reply With Quote Quick reply to this message
Old 12-03-2011, 05:17 PM   #15 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
I agree, that was for the steel version. I fixed it toapply to both styles.
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-04-2011, 04:28 PM   #16 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Poison Spyder 3 Way spare tire strap.
Spare all nice and comfy in it's new home.
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-04-2011, 04:30 PM   #17 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
What i like to call the spares "ANRGY CHAIR"..!
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-04-2011, 10:01 PM   #18 (permalink)
Member # 63333
How are you going to run the tailgait with all that tube?
Morton IL, 93 YJ
TSEJEEPERS is offline   Reply With Quote Quick reply to this message
Old 12-06-2011, 02:21 PM   #19 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Yaaaa, I might not run a tailgate...
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-17-2011, 06:12 PM   #20 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Oh, and I made sure my fenders fit...
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-17-2011, 06:31 PM   #21 (permalink)
Member # 92462
No wonder you needed to save on weight with the aluminum pieces......with all that tube work, its going to be a heavy pig!
tystick18 is offline   Reply With Quote Quick reply to this message
Old 12-31-2011, 12:21 PM   #22 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Ooops, kinda got busy...
I used the template, and my windshield bumpers to line it up.
Mraked where holes were needed..
Broke out some tape and a cut off wheel, and went at it...
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-31-2011, 12:24 PM   #23 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Removed the factory battery tray and installed the supplied tray from Poison Spyder.
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-31-2011, 12:26 PM   #24 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Doors are all done...
MY BUILD
04 Rubicant Ultra4
web wheeler...
Old 12-31-2011, 12:27 PM   #25 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
Doors and fenders installed...
MY BUILD
04 Rubicant Ultra4
web wheeler...
