Tacking caps on axle joints... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-23-2012, 07:42 PM   #1 (permalink)
KBR97's Avatar
Member # 139668
I've been doing some reading about the D30 and have come across many suggestions to throw a tack weld on the caps to keep them from popping out of place. What I didn't read is if its ok for a DD, or should this be only done on trail rigs.
Any thoughts?
KBR97 is offline   Reply With Quote Quick reply to this message
Old 04-23-2012, 07:46 PM   #2 (permalink)
Mr. DJ
DJ404564X4's Avatar
Member # 85595
I had Randy do it to my CTM's in my 60. Seems to have worked on his first Bomber, for four years of KOH.
MY BUILD
04 Rubicant Ultra4
My precious.... 72 K5 Blazer
web wheeler...
DJ404564X4 is offline   Reply With Quote Quick reply to this message
Old 04-23-2012, 07:55 PM   #3 (permalink)
Banned
Member # 189895
I really seems to be a problem with the TJ shafts. You can put a couple tacks on each side if you want. I haven't had any problems, but maybe my time is coming.
mwstudt is offline   Reply With Quote Quick reply to this message
Old 04-23-2012, 08:04 PM   #4 (permalink)
flatblack51's Avatar
Member # 121033
the caps are small if you have access to a tig have at it, a mig might do some damage to the needle bearings if it's to hot.
Thank you to My sponsors:
Pro Comp tires
PRP Seats
Maximum Transmissions
Goatbuilt
Trail Ready Beadlocks
Yukon Gear and Axle
ADS Racing Shocks
WARN Ind.
Socal Print Shop
Broadsword Racing
#4889
flatblack51 is offline   Reply With Quote Quick reply to this message
Old 04-23-2012, 09:27 PM   #5 (permalink)
2kdstj's Avatar
Member # 177849
Look at Iron Rock Off Road. They sell weld on "tabs" that cover the end caps. They call them almost alloy axle tabs. I put a set on my D30 shafts. Looks like it will keep the ears from oblonging and ripping open.
2kdstj is offline   Reply With Quote Quick reply to this message
Old 04-23-2012, 10:13 PM   #6 (permalink)
Mr.N's Avatar
Member # 1635
I tacked my u-joint caps on my 44 well over 5 years ago.
Make sure to not add much heat, and packed them with grease.
I might not wheel as hard as some, but running bald 38" I never broke one of the Spicer u-joints.
I did break a rear mini spool & axle shaft on the 9". Plus a few drive shafts and I forget how many rear pinion u-joints.
Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html
Mr.N is offline   Reply With Quote Quick reply to this message
Old 04-24-2012, 07:02 AM   #7 (permalink)
KBR97's Avatar
Member # 139668
And this is on vehicles that see a lot of street time? I can't see any reason why it would make a difference but just want to make sure.
Old 04-24-2012, 09:11 AM   #8 (permalink)
Member # 103689
It wouldn't make a difference on street.
'94 yj punished regularly.
'91 f250 pulls it home after i break it.
1tuffyj is offline   Reply With Quote Quick reply to this message
Old 04-24-2012, 09:53 AM   #9 (permalink)
KBR97's Avatar
Member # 139668
Ok. I had a feeling it wouldn't make a difference, but wanted to make sure before going ahead with it.
Old 04-25-2012, 01:08 PM   #10 (permalink)
Member # 189683
Any thoughts?
My recommendation: run big u-joint (760x) shafts with good Spicer joints. The almost alloy "strap" kits are the best option, but tacking the caps will help as well.
I would do several tacks, as I have broken countless tack welds, and started spinning/shooting caps. As others mentioned, do not add too much heat. I have cooked the grease out of them before.
Byron XSPower Batteries
4xspower.com 888.497.7693 Ext. 1213
Byron@XSPower is offline   Reply With Quote Quick reply to this message
Old 04-25-2012, 01:47 PM   #11 (permalink)
Member # 189683
Any thoughts?
No issues for a DD if done correctly.
Old 04-25-2012, 02:08 PM   #12 (permalink)
Member # 203732
after breaking the tacks on my 44 i bought chromo shafts wich are machined to accept full circle snap rings (could make stock ones work too with a lil grinding) no problems since and can still pull apart for servicing.
MEAKIN is offline   Reply With Quote Quick reply to this message
Old 04-25-2012, 02:30 PM   #13 (permalink)
Member # 13731
I've done it for years on D44 -- the only problem I ran into was getting the axle shaft into or out of the knuckle if I left the welds to tall. It also made it very hard to get a broken shaft out of the knuckle if the welded caps stayed in place and the ears on the shaft flared out...
uglyscout is offline   Reply With Quote Quick reply to this message
Old 04-25-2012, 02:37 PM   #14 (permalink)
J20
i really dont care..
J20's Avatar
Member # 84186
Send a message via MSN to J20
id did this also on my DD xj.......them i went to chromos and stopped having the spining cap problem
@gingerj20
#gingercomms
J20 is offline   Reply With Quote Quick reply to this message
Old 04-25-2012, 02:44 PM   #15 (permalink)
KBR97's Avatar
Member # 139668
I'm going to at least get the outer stubs with the big joints. Also do a re-gear (4.56) and lockers over the summer. If I have some money left over maybe I can get the inners too.
Axles and re-gearing is pretty expensive so I have to stay budget minded. I might even skip the selectable rear locker for now, and just get a front locker. That will save me quite a chunk of money that I can put towards labor. I've been putting all this off for a while but it needs to be done.
Old 04-25-2012, 07:34 PM   #16 (permalink)
KBR97's Avatar
Member # 139668
Just scored a HP30 on craigslist for $60
Old 08-14-2012, 04:18 PM   #17 (permalink)
Member # 84464
any more feedback on the "almost alloy" caps from iron rock?
kinda looking for 'i still break joints all the time' or 'it solved my problem' sorta reviews
God Bless America
mike_belben is offline   Reply With Quote Quick reply to this message
Old 08-14-2012, 10:46 PM   #18 (permalink)
Member # 184176
Seems pretty legit to me.
I just tacked my caps. The only thing I didnt like about it is when I had a ujoint break I couldnt really tell because of the caps tacked on.
The setup is cheap enough if it doesnt work, not much lossed... But if it helps out then your savin some serious cash by fixing your breakage problem cheap enough.
[SIZE="4"][COLOR="Red"]Id rather go fishing for a day than to have crabs for a life.[/COLOR][/SIZE]
frankensteinxj is offline   Reply With Quote Quick reply to this message
Old 08-15-2012, 05:42 AM   #19 (permalink)
OffTopic's Avatar
Member # 175071
I had a busted u joint as well. Didnt know it cause the caps were tack welded on. Unless u joint is serviceable I wouldn't tack them. The heat from weld will do away with the little bit of grease that's in the caps which will lead to premature wear over short period of time.
Sent from my PG86100 using Tapatalk 2
OffTopic is offline   Reply With Quote Quick reply to this message
Old 08-15-2012, 06:53 AM   #20 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
The iron rock caps I think would put more heat into the cap then a few tack welds. Also I'm not sure on a regular 44 that you could get the axle shafts through thr knuckle. I've tacked them in the past. And right now I've ground my stock shafts to accept full snap rings so far so good.
Old 08-15-2012, 04:57 PM   #21 (permalink)
Member # 84464
well, im gonna give em a try on my HP30. i have several sets of complete inner and outer spares so i wont have to try changing a joint to get home if one does go. ill go easy on the amperage.
my truck doesnt really get driven enough to wear out joints, and id rather them be solid that cored for grease ports.
God Bless America
Old 08-15-2012, 07:49 PM   #22 (permalink)
Member # 199169
Tacked the caps on my d30 when I replaced the u-joints, no problems so far and they've been like that for awhile now.
Building a Sami buggy - "Just the tip"
untchabl is offline   Reply With Quote Quick reply to this message
Old 06-09-2013, 04:24 AM   #23 (permalink)
Member # 232926
Anbody got any feedback on the IRO tabs? I'll be putting New 760's in my D30 soon and am wondering if the IRO tabs add strength, or should I just machine for clips and tack weld.
Offroadordnance is offline   Reply With Quote Quick reply to this message
Old 06-09-2013, 08:44 AM   #24 (permalink)
Member # 85837
I can't see buying simple tabs like those. If you have to weld, you have metal working tools. If I was interested in that concept, I'd just weld on a 3/4" wide 1/8" thick self made strap.
'93YJ, '02GM 4.3VortecV6, SOA, ARBs, 8.8, WarnHubs, 35" KM2's, YorkOBA, lotsa me welded stuff.
JeeperDon is offline   Reply With Quote Quick reply to this message
Old 06-09-2013, 08:45 AM   #25 (permalink)
Member # 182723
I messed up a shaft (ended up egging the yolks? from the caps spinning out tacked the next set went on one trip and broke the yolks off the shaft. Never noticed any difference on road though id do it
kris97ranger is offline   Reply With Quote Quick reply to this message
