78 jeep cherokee tracking issue - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-29-2013, 07:06 PM   #1 (permalink)
Member # 208824
Although its not unibody I have a question that hopefully someone here can help me answer. I have a 4" BDS Spring lift and just recently moved my shackles on front of vehicle to rear. I positioned my shackle mounts in frame with. 125" dom and new urethane bushings all the way around. Built fixed mounts for front out of 3/8 plate. Everything is great except the axle tracks left and right badly. My best guess is I need a track bar (doesnt have one). Prior to this reversal I had wornd out bushings and lighter mounts
and shackles. Why do I now have this problem. Thanks for input
Frostbit169 is offline   Reply With Quote Quick reply to this message
Old 04-30-2013, 07:38 AM   #2 (permalink)
Moderator
ashmanjeepXJ's Avatar
Member # 10249
Did you shim your leaf spring perches for the change in angle? what is your caster angle set to?
If your caster is off the axle will wander all over, it will not want to return to center when you let go of the wheel and will do other strange things.
Dave
AZ Undertaker
ashmanjeepXJ is offline   Reply With Quote Quick reply to this message
Old 04-30-2013, 06:20 PM   #3 (permalink)
Member # 208824
Caster is 5 to front pinion angle is 10. I built my fixed mounts to maintain same angles I had before. I forgot to point out I extended my axle forward 5" during this process. My main issue is the amount of travel the axle has from left to right when wheel is turned from a dead stop
