231 rqnge fork - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-04-2013, 06:12 PM   #1 (permalink)
Member # 46229
231 rqnge fork
I am changing the input gear from my broken 87 231 (21 spl) into my spare 98 231 (23spl) to make the 98 231 a 21 spline input. I noticed the 87 has a stamped steel range fork and the 98 has a cast aluminum one. I have searched to see if one range fork is more desirable than the other, but have not found any info. My personal opinion would be to use the steel fork over the aluminum one. Is one fork better than the other or are they even interchangeable?
A stupid man's report of what a clever man says is never accurate because he unconsciously translates what he hears into something he can understand.
FF3PM is offline   Reply With Quote Quick reply to this message
Old 05-04-2013, 09:10 PM   #2 (permalink)
Member # 46175
The aluminum for is more rigid.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST
Specializing in Axles and Transfercases
Mh4Runner is offline   Reply With Quote Quick reply to this message
Old 05-05-2013, 04:06 AM   #3 (permalink)
Member # 66452
Send a message via AIM to jeep795
I don't see why it would matter. It's not subject to alot of force and those plastic pads do all the work...
jeep795 is offline   Reply With Quote Quick reply to this message
Old 05-05-2013, 06:26 AM   #4 (permalink)
Member # 46175
Never had a bent aluminum one, and it also doesn't rely on the little round bushings where the shift rail sticks through it.
If you think they do not see any force, then you probably haven't considered the leverage that the shifter and linkage have over it, and the occasional time where the range clutch and the teeth in is about to engage aren't lining up.
Since he has the choice between the two, I would run the aluminum 17833 fork every time.
