YJ pitman arm, straight one? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-04-2014, 11:03 AM   #1 (permalink)
Member # 71020
looking for a pitman arm that will work on YJ steeering box that is straight and possibly longer. the stock one has slight bends in it. having issue with the draglink contacting the tie-rod w/ my high steer set up.
11' Dmax tow pig and a hoopty YJ wannabe trailer slut
rebeljeeper is offline   Reply With Quote Quick reply to this message
Old 03-04-2014, 11:57 AM   #2 (permalink)
Member # 103343
clicky clicky
jeep with stuff
itsneverfinished is offline   Reply With Quote Quick reply to this message
Old 03-04-2014, 12:03 PM   #3 (permalink)
Member # 108388
Search under my name and steering...I posted up some pics and info on steering for a yj...Your gonna probably need a 80's waggy arm and move your box with a reloaction bracket...If your swapping to 44's or 60's your gonna need the waggy arm so you'll get full left to right steering anyways.
RGRHASH is offline   Reply With Quote Quick reply to this message
Old 03-04-2014, 07:37 PM   #4 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Yep waggy arm box forward.
Old 03-04-2014, 09:14 PM   #5 (permalink)
Member # 118235
Another option is an arm from a 2WD Ford Ranger. They are straight, but ~0.5" shorter than a stock YJ arm. The Ranger arm is clocked different so you'll need to file out the four small keyways.
metalmulisha68 is offline   Reply With Quote Quick reply to this message
Old 03-06-2014, 08:15 AM   #6 (permalink)
Member # 71020
RGRHash that looks almost exactly like my set up.
do you know if you can get those waggy arms at napa or is that a pick&pull item?
Old 03-06-2014, 10:04 AM   #7 (permalink)
NorCal_Chris's Avatar
Member # 140551
Wfo concepts sells the waggy arms , also sells them with the gm draglink taper if wanted
adfasd
NorCal_Chris is offline   Reply With Quote Quick reply to this message
Old 03-06-2014, 11:15 AM   #8 (permalink)
Member # 108388
I did the pick & pull ang got 2 of them for $20 total...Waggy's are pretty common in texas junkyards...I think you could find one near you pretty cheap.
Old 03-12-2014, 01:31 PM   #9 (permalink)
Member # 71020
got a waggy arm works good, thanks guys
Old 03-17-2014, 02:21 PM   #10 (permalink)
Member # 71020
RGRHASH what front spring are you running?
