STEERING HELP!?!? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-28-2014, 03:59 PM   #1 (permalink)
Member # 204044
Send a message via Yahoo to Dezrtracer32
STEERING HELP!?!?
I have a 91 Xj And the steering wheel has alot of play to it. I can literally move it around while driving. Also the ignition lock cylinder can be a pain to turn if I don't have it at the right angle. It has tilt wheel and I've been told some bolts over time loosen up. And I need special tools. Any info on this problem would be greatly appreciated
Dezrtracer32 is offline   Reply With Quote Quick reply to this message
Old 03-28-2014, 04:21 PM   #2 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Is it the tilt column, the box or the linkage?
Have somebody turn the wheel back and forth while you look for the slop under the front end. Pry gently on tre's to see if they are tight.
& Blaine
:tank:
Old 03-29-2014, 06:08 PM   #3 (permalink)
Member # 40450
You have been told correctly. There are 3 bolts down inside the tilt steering column that will work loose over time and cause the problems you're having. You need a steering wheel puller, some snap ring pliers and some patience to fix the problem.
There are a ton of "how to" Youtube videos if you search "loose tilt steering column". The process for a GM column will be the same.
MDMIKE is offline   Reply With Quote Quick reply to this message
