4.0 problem Help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-16-2016, 05:19 PM   #1 (permalink)
adam36830's Avatar
Member # 132434
4.0 problem Help
Hello all,
I have a 97 ZJ with a 4.0. I bought it not running and have been able to get it to crank and run just not run very well. Looking for a little help.
Symptoms: Cold cranks and idles between 1k and 500 for about 20 seconds and then dies (idle jumps between 500 and 1k). When I'm able to start driving the ZJ before it dies it will run great through 1st and 2nd. When it gets to overdrive it boggs down and starts to spudder some and a huge lose in power. Currently no codes are showing when I do the key trick. Only 12 and then 55.
Things I have done up to this point:
Removed the throttle body and cleaned it.
Replaced the IACV
Replaced the Air Intake Temp Sensor (was getting a code 23)
Replaced CKPS
Replaced Camshaft Position Sensor
Replaced the PCM
Replaced All wires and spark plugs
Replaced Rotor cap and rotor button have
Any help will be greatly appreciated and thank you all.
85 yota-LQ4/4L80e/NP203/NP205/5.71/exo Build Thread: toyota-truck-4runner/980213-my-85-toyota-build
adam36830 is offline   Reply With Quote Quick reply to this message
Old 02-16-2016, 05:49 PM   #2 (permalink)
Weasel's Avatar
Member # 5639
throttle position sensor?
Kindness doesn't condemn or condone
Just Add Lightness
Weasel is offline   Reply With Quote Quick reply to this message
Old 02-17-2016, 10:25 AM   #3 (permalink)
Dunes & Forest
fantic238's Avatar
Member # 142612
check your fuel pressure, chances are the fuel pump turns slowly and is dying
Find your own tranny pics you sick fuck.
fantic238 is offline   Reply With Quote Quick reply to this message
Old 02-17-2016, 02:18 PM   #4 (permalink)
adam36830's Avatar
Member # 132434
should i check this while it is running? It hold 40lbs when I turn in over before it dies
Old 02-17-2016, 02:20 PM   #5 (permalink)
Member # 85771
fuel pump?
Make Forums Great Again!
Old 02-18-2016, 01:35 AM   #6 (permalink)
Dunes & Forest
fantic238's Avatar
Member # 142612
Pull the gauge up to the windshield under the wiper and go test drive it, if the pressure drops below 30 psi when the engine bogs the pump is shot.
Old 02-18-2016, 01:38 AM   #7 (permalink)
Dunes & Forest
fantic238's Avatar
Member # 142612
If it isn't the fuel pump next step I would check the vacuum line to the MAP sensor.
Old 02-18-2016, 02:33 PM   #8 (permalink)
adam36830's Avatar
Member # 132434
Thanks guys. I will test all of these in the morning. Working the dreaded second shift.
Old 02-21-2016, 11:27 AM   #9 (permalink)
Member # 67606
Got an '02 that would bogg down after warmup. I removed/bypassed the cat and fixed it
Kickin'Chicken is offline   Reply With Quote Quick reply to this message
Old 02-21-2016, 01:59 PM   #10 (permalink)
adam36830's Avatar
Member # 132434
weekend update
so i replaced the TPS and check fuel pressure again. held 50 psi even under load. also looked at the MAP sensor vacuum hose. Looked to be in could condition. Still clueless.
Old 02-22-2016, 02:11 AM   #11 (permalink)
Dunes & Forest
fantic238's Avatar
Member # 142612
Do you have a factory service manual? I would at this point check the distributor indexing.
You need to place the engine at TDC and set the distributor rotor at 4 o'clock (or opposite).
Timing a 4.0L - JeepForum.com
The distributor gear might be off 1 tooth.
Old 02-22-2016, 07:55 AM   #12 (permalink)
Member # 114810
I've had similar issues with a 4.0 yj due to clogged fuel injectors. It sat for a few years and the fuel filter rusted, allowing the rust into the fuel rail upon starting it.
Pull the fuel rail and injectors. see if a bunch of crap is sitting between the injectors and rail. I had to remove the regulator and flush the rail a few times.
engnmonkey is offline   Reply With Quote Quick reply to this message
Old 02-22-2016, 08:06 AM   #13 (permalink)
Member # 17768
Had a similar issue, remove the cat or test with a infared temp gun (to see if it's clogged). The innards of the converter break apart and clog the exhaust.
antelopeXJ is offline   Reply With Quote Quick reply to this message
Old 02-24-2016, 06:51 PM   #14 (permalink)
Member # 613514
You can pull the front O2 sensor and that'll allow it to breathe enough to see if it's a cat issue. I had the same problem where it would run fine until it got on the highway, then fall flat on its face. Pulling the O2 sensors let it run well enough for me to get it home and work on it.
If you do end up replacing the cat, I'd go OEM unless you plan on selling it within a year. I've not had much luck with longevity with either the aftermarket cheapie or high performance cats.
Apodyopsis is offline   Reply With Quote Quick reply to this message
