Breaking in New Front Gears with Locking Hubs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-03-2016, 01:16 PM   #1 (permalink)
Member # 305185
Maybe I'm overthinking this, but how do you break in new front gears on a Dana 44 axle with locking hubs?
The new gears won't turn unless the hubs are engaged. The hubs won't be engaged unless I'm offroad. There's no way to "baby" the gears and break them in as recommended below. And 500 miles of break in, as recommended below would be years of offroad use.
Should I just do a few offroad runs, change the gear oil and call it good?
From the Yukon Manual:
"New Gear Break-In
All new gear sets require a break-in period to prevent overheating damage. Any overloading or overheating will break down the gear oil, which will cause the ring and pinion to fail. This can be determined by inspection and will void the gears’ warranty.
Please follow these guidelines to insure proper break-in.
- Avoid heavy acceleration during the break-in process.
- Drive the vehicle lightly for the first 15 to 20 miles and stop. Let the differential cool before proceeding.
- Avoid heavy acceleration for the first 100 miles.
- Drive the vehicle at least 500 miles before towing to retain the gears’ warranty.
- When towing for the first time, drive for a very short distances (less than 15 miles) with the full load and stop. Let the differential cool for about 20 minutes before proceeding. Repeat this procedure two more times (45 miles total) to fully break in the gears.
- Change the oil after the first 500 miles. This will remove any metal particles and phosphoric coating shed by the gear set during the gears’ break-in period.
These towing instructions may seem unnecessary to most people, but we have seen many differentials damaged from being loaded before the gear set was fully broken-in. "
End of Yukon Manual
StanF is offline   Reply With Quote Quick reply to this message
Old 05-03-2016, 06:55 PM   #2 (permalink)
TxCruzr's Avatar
Member # 9380
Send a message via AIM to TxCruzr
Pretty much. My gear guy said to do a few easy 4wd trips, change the oil, then drive it like you stole it.
There's not a single person on this earth that has done the whole break-in routine for their front axle.
For Sale!!
TxCruzr is offline   Reply With Quote Quick reply to this message
Old 05-03-2016, 07:44 PM   #3 (permalink)
CSP
Member # 1533
You can have the hubs locked and be on the road. Just leave the transfer case selector in 2WD.
CSP is offline   Reply With Quote Quick reply to this message
Old 05-03-2016, 10:39 PM   #4 (permalink)
El Conquistador
Valley Rock's Avatar
Member # 208306
Those guys at the factory must run the piss out of all those new rigs at lunch time every day, before they ship them out to the dealerships .
Valley Rock is offline   Reply With Quote Quick reply to this message
Old 05-04-2016, 08:28 AM   #5 (permalink)
Dugan1's Avatar
Member # 162726
the 500 mile break is just a warranty "gotcha".
I tell my customers to drive for like 5 minutes, let it cool, 10 minutes let it cool then do like a 30 min trip and let it cool without any harsh braking, then drain and inspect for any issues.
You can def tell when someone beat on gears without any sort of heat cycle on them.
MidKnight Fabrications -=- New Castle, DE
https://www.facebook.com/MKFabrications
Dugan1 is offline   Reply With Quote Quick reply to this message
Old 05-05-2016, 09:21 AM   #6 (permalink)
Member # 8093
Hmm, I wonder what the drag strip folks do?
Just your usual stuff.
u-joint is offline   Reply With Quote Quick reply to this message
Old 05-05-2016, 09:24 AM   #7 (permalink)
Dugan1's Avatar
Member # 162726
We use to cruise around a walmart parking lot haha, oh the looks.
Old 05-06-2016, 09:43 PM   #8 (permalink)
CSP
Member # 1533
Gearsets specifically make for drag racing aren't the same as gearsets meant to go down the highway. They make a crapload of noise as part of the tradeoff of being able to take shockloading with no break in required.
Old 05-08-2016, 02:40 AM   #9 (permalink)
Dugan1's Avatar
Member # 162726
Which companies sell those? Ive never heard of drag racing specific gears
Old 05-08-2016, 04:48 PM   #10 (permalink)
Member # 82950
Richmond does I know. I think they classify them as a high nickel gear set. Whatever they call it it's a different alloy. They are softer for impact loading but don't work well in continuous operation cycles like street driving or road racing.
Mike C2 is offline   Reply With Quote Quick reply to this message
Old 05-08-2016, 04:53 PM   #11 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
What differential are you running? Unless it's welded or a spool, you can lock the hubs and drive around town. Better would be to cruise down a dirt road in 4 Hi.
& Blaine
:tank:
Old 05-08-2016, 07:00 PM   #12 (permalink)
DMG
Member # 8145
I have let a rig run for an hour on the lift in 4 high to start the break-in process.
DMG is offline   Reply With Quote Quick reply to this message
Old 05-09-2016, 07:35 AM   #13 (permalink)
billdacat's Avatar
Member # 72617
Strange
http://strangeengineering.net/
Dam... These people make some nice stuff!!!
billdacat is offline   Reply With Quote Quick reply to this message
Old 05-09-2016, 08:05 AM   #14 (permalink)
Dugan1's Avatar
Member # 162726
yea strange makes some killer shit, they have a center diff for top fuels thats like 30k$. Ive just never seen someone offer a gear set they say doesnt require some sort of break in. Even strange doesnt list no break in.
Old 05-09-2016, 08:21 AM   #15 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Search this topic and user name RacingRon. He has run a few gear companies and discussed gear break in.
& Blaine
:tank:
Old 05-09-2016, 11:22 AM   #16 (permalink)
Member # 601322
IMO, it would be better to run with the t-case in 4hi and the hubs unlocked. That loads the gears lightly in the drive direction, while locking the hubs with the t-case in 2wd will load the gears opposite of how they'll be loaded most of the time, so it doesn't provide as much of a useful break-in.
rslifkin is offline   Reply With Quote Quick reply to this message
Old 05-15-2016, 10:02 AM   #17 (permalink)
Member # 102
just lock the wheel
brownbagg is offline   Reply With Quote Quick reply to this message
