8.8 axle spline slop - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-12-2016, 09:30 PM   #1 (permalink)
Newbie
Member # 516410
I recently installed an 8.8 with a Detroit locker. I used the original axles until I can upgrade (31 spline). The splines looked pretty good, which is why I thought I could get away with using them for a bit.
My question is about slop. How much should I be able to rotate the drive shaft by hand, back and forth. Pinion/ring gear backlash is correct, gear pattern is good.
The pictures show how much I can rotate the drive shaft back and forth. The other pictures show how far the carrier moves.
81 CJ
victorsam is offline   Reply With Quote Quick reply to this message
Old 05-13-2016, 05:01 AM   #2 (permalink)
Member # 305185
I believe that you're seeing the slop in the Detroit.
There's no way that the axle splines are moving like that...
StanF is offline   Reply With Quote Quick reply to this message
