Skinny driveshaft for clearance help! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-26-2016, 08:46 PM   #1 (permalink)
Member # 560130
Im building a buggy and the driveshaft clearance to my front upper 4 link arm is very tight. I need about 12 inches of the shaft to be necked down to 1" diameter to clear the arm and bracket. I was considering getting a piece of solid chromoly bar and sleeving it at both ends so I could weld it into the 2" diameter shaft.
Am I crazy for thinking this is a good idea or is it going to bite me out on the trail. I'm Running a 5.3l roughly 325hp 4l60e trans 241c t case and 513 gears on 39" tires
Dts327 is offline   Reply With Quote Quick reply to this message
Old 05-26-2016, 08:49 PM   #2 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
I'd rather use a 2pc shaft.
& Blaine
:tank:
Old 05-26-2016, 08:51 PM   #3 (permalink)
Member # 560130
I agree but in this particular vehicle it is not very feasible
Old 05-27-2016, 09:24 AM   #4 (permalink)
Member # 13786
OK then how about some more information and a picture
KWTMECH is online now   Reply With Quote Quick reply to this message
Old 05-27-2016, 09:55 AM   #5 (permalink)
Member # 109953
i have a pretty skinny one to clear my starter in my jeep buggy. I think its 1.5 though. only broke it once in that spot. Broke the CV a few times.
AZ Undertakers
ShmUDE is offline   Reply With Quote Quick reply to this message
Old 05-27-2016, 09:59 AM   #6 (permalink)
Member # 392218
we sell a 1.25 .188 wall shaft thats double cardigian style for 280 and has a longer than stock slip yoke
from wild to mild custom built drive shafts for the hard core. 602 997 0906
driveshafter is offline   Reply With Quote Quick reply to this message
Old 05-27-2016, 10:43 AM   #7 (permalink)
Member # 560130
This is basically what needs to happen but alot beefier
Old 05-27-2016, 12:20 PM   #8 (permalink)
Member # 666322
give it a go, most important thing is to get some serious heat into that piece if youre welding 2 inch bar
Suh' Dude
BoyceFab is offline   Reply With Quote Quick reply to this message
Old 05-27-2016, 12:52 PM   #9 (permalink)
Member # 560130
You guys are local to me. I know the shaft i pictured above is buildable but do you think it will be reliable?
