Fuel pressure regulator for 4.0 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-05-2016, 09:26 PM   #1 (permalink)
Member # 193548
Hey guys,
Installed my fuel cell and my 255lph Walbro pump and am looking for recommendations on a fuel pressure regulator. It's in a TJ so have the non return fuel rail (and due to being in Australia don't want to swap) so need a regulator that will join to the return fitting on the tank. I know a ZJ filter/regulator is an option but am running all 8AN fittings so far and don't really want the plastic barbs. Happy to pay the money for a quality item that isn't going to break.
Cheers,
Tom.
cj10camper.blogspot.com.au
Motas is offline   Reply With Quote Quick reply to this message
Old 07-05-2016, 09:32 PM   #2 (permalink)
Member # 193548
Although, a little more research tells me the pre update XJs may have had a fuel rail with a return line? If this is the case I could get one locally. Would they be a direct swap and cause no issues on a TJ?
Cheers!
Old 07-06-2016, 06:46 AM   #3 (permalink)
Here's Johnny!
frostytj's Avatar
Member # 12867
Not sure about pre updated XJs but YJs have a built in regulator on the fuel rail and bolt onto a TJ. You'll need to run a return line back to the tank. I ran one for a while without any issues.
Buddy uses a Mallory 4305M regulator at the TJ fuel rail/firewall and return line to the tank without issues.
Buy the ticket, take the ride.
frostytj is offline   Reply With Quote Quick reply to this message
Old 07-06-2016, 07:12 AM   #4 (permalink)
Member # 53641
I ran the Aeromotive #13101 on my 97 TJ with no fuel rail return. Regulator has return that I plumbed back to my fuel cell. Set regulator at appx. 45psi and that was 15 years ago. Still runs same parts to this day without issue.
jeepkevin is online now   Reply With Quote Quick reply to this message
Old 07-06-2016, 06:03 PM   #5 (permalink)
Member # 193548
I'm running new fuel lines anyway so that's not a problem. The reason I want to do this is so its ready for a new motor down the track and I don't have to run an extra return line etc. Simply a matter of swapping the lines to the fuel rail and adjusting the pressure.
However YJs do not exist over here so I can't really get one. I've actually bought a pre update XJ fuel rail though which i found out does have a return line. Would there be any problem with blocking the inbuilt regulator and running an external one? Any ideas how I might block the inbuilt one?
Thanks, Tom.
